Ubuntu Installation: Multiple Graylog Nodes
This installation guide covers installing Graylog on Ubuntu 22.04 or 24.04 on a multi-node cluster consisting of more than one Graylog and MongoDB node and more than one Data Node. A generally recommended cluster design that supports most medium-to-large scale deployments is our Conventional model, which is composed of three Graylog and MongoDB nodes and three Data Nodes; however, this installation guide can generally be followed at any scale cluster.
Hint: If you are instead deploying a single-node Graylog instance, see Ubuntu Installation: Single Graylog Node.
This article will guide you through installing three services that comprise the Graylog stack: MongoDB, Graylog Data Node, and Graylog.
Prerequisites
  • Verify that all required ports are open. We assume in the following steps that firewalls are disabled and traffic can flow across all necessary ports.
  • A load balancer with a DNS record assigned for Graylog is encouraged for this deployment type.
  • We strongly recommend the use of an XFS file system for storage.
  • Review the Conventional architecture diagram and our recommendations for resource allocation before you begin installation.
Warning: This installation guide does not configure security settings. Before deploying Graylog to users or ingesting production data, secure all components in the Graylog stack. This includes restricting network access, preventing public internet exposure of internal services, enabling encryption, and configuring authentication and authorization. For detailed guidance, see Secure Your Graylog Environment and Network Connectivity and Firewall Requirements.
Server Timezone
To set a specific time zone on a Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
Copy
sudo timedatectl set-timezone UTC
Configuration and Service Files
Before you begin the process of installing Graylog and its required components, it is important to note that there are multiple configuration files and service files included in the Graylog and MongoDB operating system packages that should be adjusted during the initial deployment process to optimize your system performance. For your reference, the files mentioned in this installation guide for each service are as follows:
Install MongoDB
MongoDB is a NoSQL database designed to store and manage data in a flexible, scalable, and high-performance manner. As a part of the Graylog stack, MongoDB serves as the metadata database for the system.
The official MongoDB documentation provides a helpful tutorial on installation with Ubuntu. Additionally, we recommend you review their guide for setting up a MongoDB cluster. For information on installing MongoDB for use with Graylog, we recommend you generally follow the process below.
Hint: This guide assumes you are installing MongoDB 8.0. Review the compatibility matrix for versions of MongoDB supported both by your chosen Graylog and operating system versions.
  1. Begin on a selected node in your Graylog/MongoDB cluster and install gnupg and curl:
    Copy
    sudo apt-get install gnupg curl
  2. Import the MongoDB public key:
    Copy
    curl -fsSL https://www.mongodb.org/static/pgp/server-8.0.asc | \
       sudo gpg -o /usr/share/keyrings/mongodb-server-8.0.gpg \
       --dearmor
  3. Create a list file for MongoDB:
    Copy
    echo "deb [ arch=amd64,arm64 signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg ] https://repo.mongodb.org/apt/ubuntu noble/mongodb-org/8.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-8.0.list
  4. Reload the local package database:
    Copy
    sudo apt-get update
  5. Install the latest stable version of MongoDB:
    Copy
    sudo apt-get install -y mongodb-org
  6. Hold the currently installed version of the MongoDB package to prevent it from being automatically upgraded to a newer version when updates are installed:
    Copy
    sudo apt-mark hold mongodb-org
  7. Open the MongoDB configuration file:
    Copy
    sudo nano /etc/mongod.conf
  8. By default, MongoDB only listens locally.You must modify either the bindIp or bindIpAll setting in the MongoDB configuration file so that the port binds to an interface address or a host name or listens on all interfaces. See the example configurations below.
    To listen on all interfaces:
    Copy
    net:
      port: 27017
      bindIpAll: true
    To bind to a specific interface, like 192.168.50.71:
    Copy
    net:
      port: 27017
      bindIp: 192.168.50.71
    To bind to a host name, like graylog01:
    Copy
    net:
      port: 27017
      bindIp: graylog01
  9. Create the MongoDB replica set in the MongoDB configuration file:
    Copy
    replSetName: "rs0"
  10. Enable MongoDB and start the service:
    Copy
    sudo systemctl daemon-reload
    sudo systemctl enable mongod.service
    sudo systemctl start mongod.service
  11. On the leader node only, initiate the replica set. In the following example command, graylog01, graylog02, and graylog03 represent the host names of the Graylog/MongoDB nodes. You must update them to reflect the host names or IP addresses of your Graylog/MongoDB nodes:
    Copy
    sudo mongosh
    rs.initiate( { _id : "rs0", members: [ { _id: 0, host: "graylog01:27017" }, { _id: 1, host:"graylog02:27017" }, { _id: 2, host: "graylog03:27017" } ] })
  12. Repeat all of the above steps for your additional MongoDB nodes.
Warning: You must complete the installation on all nodes to ensure proper functionality. The deployment will remain incomplete until all nodes have the service installed!
Install Data Node
Data Node is a component in Graylog's architecture designed to handle log ingestion, processing, and indexing, and manage communication with OpenSearch for storing and querying logs efficiently. As noted in the Conventional architecture, the Data Node service should be maintained on its own cluster, separate from Graylog and MongoDB.
Warning: The following guide will walk you through installing Graylog for use with Data Node as your search backend. Do not install OpenSearch directly! For information on deploying Graylog with self-managed OpenSearch, see Installing Graylog.
To install Data Node, we recommend you follow the process below:
  1. Install the Data Node package on a select node in your Data Node cluster:
    Copy
    wget https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.deb
    sudo dpkg -i graylog-7.2-repository_latest.deb
    sudo apt-get update
    sudo apt-get install graylog-datanode
  2. Ensure that the Linux setting vm.max_map_count is set to at least 262144. To check the current value:
    Copy
    cat /proc/sys/vm/max_map_count
    To increase the value:
    Copy
    echo 'vm.max_map_count=262144' | sudo tee -a /etc/sysctl.d/99-graylog-datanode.conf
    sudo sysctl --system
  3. Create your password_secret. This is a secure, randomly generated string used to encrypt sensitive data within the system:
    Copy
    openssl rand -hex 32
    Hint: This command uses OpenSSL, a toolkit for TLS/SSL protocols and cryptography, to generate a secure random password. See the OpenSSL documentation for more information.
  4. Open the Data Node configuration file:
    Copy
    sudo nano /etc/graylog/datanode/datanode.conf
  5. Add the password_secret value to the Data Node configuration file. Note that you must add this same value to the Graylog server configuration file in a later step since it is crucial that this value be the same for the Graylog node.
  6. Ensure the heap settings are set to half your system memory, up to a max of 31 GB. To do so, you will need to add the following configuration property to your Data Node configuration file. For example, if you have 16 GB of RAM, you would set it to 8 GB, like in the example below:
    Copy
    opensearch_heap = 8g
    Warning: This configuration property is not included in the datanode.conf by default! It must be added to the file manually.
  7. Configure the MongoDB connection string in the Data Node configuration file. In the following example command, graylog01, graylog02, and graylog03 represent the host names of the MongoDB nodes. You must update them to reflect the host names or IP addresses of your MongoDB nodes:
    Copy
    mongodb_uri = mongodb://graylog01:27017,graylog02:27017,graylog03:27017/graylog?replicaSet=rs0
    Hint: This example connects to MongoDB without authentication. To connect with a user name and password instead, see Configure Graylog to Use MongoDB Password Authentication.
  8. Enable Data Node and start the service:
    Copy
    sudo systemctl enable graylog-datanode.service
    sudo systemctl start graylog-datanode
  9. Follow all of the above steps for each additional Data Node with the exception of generating the password secret. The value you first generated and configured must be the same for each additional node.
Install Graylog
After Data Node installation is complete, you must install the core Graylog service. Our recommended cluster architecture denotes that the Graylog and MongoDB services are installed on the same nodes.
To install Graylog, we recommend you follow the process below:
  1. On a select node in your Graylog/MongoDB cluster, install the Graylog package.
  2. Use the following command to create your root_password_sha2. This is the password for the root administrator account for the Graylog interface. Make sure you record this password as you will need it to log into the Graylog interface after preflight configuration:
    Copy
    echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
    Warning: Do NOT attempt to log into Graylog for the first time using the password you generated in the steps above! You must complete the preflight login with the credentials found in the log file after first starting the Graylog service. You will be able to login to Graylog with your generated password after the preflight is complete. See The Web Interface for more information.
  3. Open the Graylog server configuration file:
    Copy
    sudo nano /etc/graylog/server/server.conf
  4. Enter the value you created for the root_password_sha2 in the previous step into the Graylog configuration file.
  5. Retrieve the password secret from the Data Node configuration file as indicated in steps 3-5 of Install Data Node and add it to the password_secret property in the Graylog configuration file.
  6. Make the following additional adjustments to your Graylog configuration file to optimize the performance and integration of your Graylog cluster.
    1. Set the http_bind_address value in the Graylog configuration file to the public host name or a public IP address on which the Graylog web and API server will listen for incoming HTTP requests. (This property is commented out by default and listed beneath the # HTTP settings section of the configuration file):
      Copy
      Hint: More information about these settings can be found in The Web Interface.
    2. Configure the MongoDB connection string. In the following example command, graylog01, graylog02, and graylog03 represent the host names of the MongoDB nodes. You must update them to reflect the host names or IP addresses of your MongoDB nodes:
      Copy
    3. Configure the external URI. The http://graylog.user.com/ value equals the DNS record set on your load balancer:
      Copy
      http_external_uri = http://graylog.user.com/
    4. Adjust your journal settings. We recommend you configure your journal settings' max age to 72 hours and the size to your expected total log volume over a 72-hour period divided by the number of nodes in your cluster. So, if your expected daily log volume is 30 GB, your max size over 72 hours would be 90 GB. And if there are three Graylog nodes in your cluster, then you would divide 90 GB by 3, resulting in 30 GB, as in the example below:
      Copy
      message_journal_max_age = 72h
      message_journal_max_size = 30gb
    5. On the follower nodes only, ensure that the setting is_leader is set to false.
      Copy
      is_leader = false
      Hint: The setting is_leader is set to true by default!
  7. Open the graylog-server file found by default at /etc/default/:
    Copy
    sudo nano /etc/default/graylog-server
  8. In the graylog-server file, adjust your heap settings to half the system memory up to a max of 16 GB for the Graylog service, as recommended in Additional Configuration. It is recommended that you set the minimum and maximum values to be the same, so if you are setting your minimum to 2 GB, like shown in -Xms2g, and your maximum to 2 GB, like shown in -Xmx2g, the setting may look like:
    Copy
    GRAYLOG_SERVER_JAVA_OPTS="-Xms2g -Xmx2g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow"
  9. Enable Graylog and start the service:
    Copy
    sudo systemctl enable graylog-server.service
    sudo systemctl start graylog-server.service
  10. Follow all of the above steps for each additional Graylog node with the exception of generating the root administrator password. The value you first generated and configured must be the same for each additional node.
Once installation is complete, proceed to the following section on the preflight login to access the Graylog web interface!
Preflight Login
After installation is complete, immediately proceed to The Web Interface for information on completing the preflight process and logging into Graylog for the first time. This preflight login will require the initial login credentials found in the log file after first starting the Graylog service!
Troubleshooting and Common Issues
The following section outlines troubleshooting steps for common issues to assist you in resolving potential challenges you may encounter.
Issue: Network Connectivity Issue During MongoDB Installation
It is possible you may receive a network connectivity issue while you are initiating the replica set for MongoDB. This may be related to your DNS and/or your TCP port or network configuration.
Solution: Modify Firewall and/or DNS Settings
If you encounter this issue, we recommend you test whether the required port TCP/27017 is open. You can use telnet or nc (Netcat) to test:
Copy
nc -vz <node_ip> 27017
