Data Node Configuration Settings Reference
The file datanode.conf is the Data Node configuration file. When you install and configure the Graylog Data Node, we recommend that you follow the instructions provided in Graylog Data Node. For additional configuration options available via this file, consult the tables below.
Configuration Database Connection Properties
These properties define connections to the MongoDB database, which stores cluster configuration metadata.
| Parameter | Type | Required | Default Value | Description |
mongodb_max_connections
1000
Increase this value according to the maximum connections your MongoDB server can handle from a single client if you encounter MongoDB connection problems. |
mongodb_uri
mongodb://localhost/graylog
MongoDB connection string. See the MongoDB documentation for details. To secure this connection with a user name and password, see Configure Graylog to Use MongoDB Password Authentication. |
mongodb_version_probe_attempts
0
This defines the number of attempts the search version probe should run before giving up. Default 0 means retry indefinitely until a connection can be established. |
Core Graylog Cluster Settings Properties
These properties define important cluster identification and security elements that must be set.
Data Tiering Properties
These properties define where data is stored for the data tiering feature.
String |
No |
None |
Azure Storage account name for searchable snapshots. An Azure repository requires this setting plus either |
String |
No |
None |
Azure Storage account key for searchable snapshots. Use this or |
String |
No |
None |
Azure shared access signature (SAS) token for searchable snapshots, used in place of |
Path |
No |
None |
Google Cloud Storage credentials file, in JSON format, for searchable snapshots. The path can be absolute or relative to the |
Boolean |
No |
Enables the HDFS repository for searchable snapshots. |
node_search_cache_size
String |
No |
10gb
Cache size for searchable snapshots. Data Node reserves this space automatically on nodes with the search role when any snapshot repository is configured. See s3_client_* and path_repo configuration options. |
path_repo
List |
No |
None | Filesystem path where searchable snapshots should be stored. |
s3_client_default_access_key
String |
No |
None | S3 repository access key for searchable snapshots. |
s3_client_default_endpoint
String |
No |
None | S3 repository endpoint for searchable snapshots. |
s3_client_default_path_style_access
Boolean |
No |
true
S3 repository path-style access for searchable snapshots. |
s3_client_default_protocol
String |
No |
http
S3 repository protocol for searchable snapshots. |
s3_client_default_region
String |
No |
us-east-2
S3 repository region for searchable snapshots. See the AWS documentation for available regions for configuration. |
s3_client_default_secret_key
String |
No |
None | S3 repository secret key for searchable snapshots. |
Networking Properties
These properties relate to communication between Graylog nodes as well as between Graylog and external environments.
bind_address
String |
Yes |
0.0.0.0
HTTP bind address. The network interface used by the Graylog Data Node to bind all services. |
datanode_http_port
Integer |
Yes |
8999
HTTP port. The port on which the Data Node REST API is listening. |
enabled_tls_protocols
Set |
No |
None | Allowed TLS protocols for system-wide TLS-enabled servers (e.g. message inputs, HTTP interface). Setting this to an empty value leaves it up to system libraries and JDK to chose a default. |
http_certificate
String |
No |
None | Relative path (to config_location) to a keystore used for OpenSearch REST-layer TLS. |
String |
No |
The HTTP keystore alias name. The default is found in the first alias. |
http_certificate_password
String |
No |
None | Password for a keystore defined in . |
http_enable_gzip
Boolean |
No |
true
Enable GZIP support for HTTP interface. This compresses API responses and helps to reduce overall round trip times. |
http_max_header_size
Integer |
Yes |
8192
The maximum size of the HTTP request headers in bytes. |
http_publish_uri
URI |
No |
None | This configuration should be used if you want to connect to this Graylog Data Node's REST API, and it is available on another network interface than $bind_addressss like, for example, if the machine has multiple network interfaces or is behind a NAT gateway. |
http_thread_pool_size
Integer |
Yes |
64
The size of the thread pool used exclusively for serving the HTTP interface. |
indexer_jwt_auth_token_caching_duration
Duration |
No |
60 seconds
Communication between Graylog and OpenSearch is secured by JWT. This configuration defines the interval between token regenerations. |
indexer_jwt_auth_token_expiration_duration
Duration |
No |
180 seconds
Communication between Graylog and OpenSearch is secured by JWT. This configuration defines the validity interval of JWT tokens. |
opensearch_http_port
Integer |
No |
9200
HTTP port on which the embedded OpenSearch listens. |
opensearch_network_host
String |
No |
None | Binds an OpenSearch node to an address. Use 0.0.0.0 to include all available network interfaces, or specify an IP address assigned to a specific interface. |
opensearch_transport_port
Integer |
No |
9300
Transport port on which the embedded OpenSearch listens. |
transport_certificate
String |
No |
None |
Relative path (to config_location) to a keystore used for OpenSearch transport-layer TLS |
transport_certificate_alias
String |
No |
The transport keystore alias name. The default is found in the first alias. |
transport_certificate_password
String |
No |
None |
The password for a keystore defined in transport_certificate. |
Performance Tuning Properties
These properties allow you to affect the performance of your Graylog installation.
opensearch_heap
String |
No |
1g
OpenSearch heap memory. Initial and maxmium heap must be identical for OpenSearch; otherwise the boot fails. |
Performance Monitoring and Logging Properties
These properties control configuration of metrics and logging that Graylog performs.
opensearch_logger_org_opensearch
String |
No |
INFO
Configures verbosity of embedded OpenSearch logs. Possible values |
opensearch_logs_location
Path |
Yes |
datanode/logs
Logs directory of the embedded OpenSearch. |
opensearch_plugins_security_audit_type
String |
None |
None | Configures OpenSearch audit log storage type. See the OpenSearch documentation for more information. |
process_logs_buffer_size
Integer |
No |
500
The number of log entries the OpenSearch process should hold in memory and make accessible for Data Node via API calls. |
Search Backend Configuration Properties
These properties affect how the backend search service is configured, such as where data is stored and node roles.
clustername
String |
No |
datanode-cluster
Name of the cluster on which the embedded OpenSearch forms. Should be the same for all data nodes in one cluster. |
initial_cluster_manager_nodes
String |
No |
None | Comma-separated list of OpenSearch nodes that are eligible as manager nodes. |
node_roles
List |
No |
cluster_manager,data,ingest,remote_cluster_client
The Data Node's roles. If nothing is defined, Data Node uses cluster_manager,data,ingest,remote_cluster_client. If roles are not defined but a snapshot repository is configured, the search role is also automatically added. |
opensearch_config_location
Path |
Yes |
datanode/config
Configuration directory of the embedded OpenSearch. This directory is where the OpenSearch process stores its configuration files. |
Warning: Each start of the Data Node regenerates the complete contents of the configuration directory! |
opensearch_configuration_overrides_file
Path |
No |
None |
The path to the file with configuration properties overriding default OpenSearch parameters. Required format is a Java properties file. If the path is relative, Data Node tries to resolve the file relative to the configured path. |
Warning: Overriding OpenSearch configuration parameters is not supported and may break in any future release. See Configuration Overrides for more information. |
opensearch_data_location
Path |
Yes |
datanode/data
Data directory of the embedded OpenSearch. Contains OpenSearch indices. It may be pointed to an existing OpenSearch directory during in-place migration to Data Node. |
opensearch_discovery_seed_hosts
List |
No |
Provides a list of the addresses of the leader-eligible nodes in the cluster. Automatically sets to all nodes if not configured. |
opensearch_location
String |
No |
dist
Directory where Data Node searches for an OpenSearch distribution. |
User Experience Properties
These properties affect the user experience in the Graylog web interface.
opensearch_indices_query_bool_max_clause_count
Integer |
No |
32768
This setting limits the number of clauses a Lucene Boolean query can have. |
Miscellaneous Properties
These properties affect Graylog elements not directly relevant to other categories.
shutdown_timeout
Integer |
No |
30000
How many milliseconds should the Data Node wait for termination of all tasks during the shutdown. |
