Compatibility Matrix
The following compatibility matrix specifies version compatibility for integration with supported software dependencies for Graylog Open, Graylog Enterprise, and Graylog Security.
Compatibility for Graylog
Graylog requires the following version compatibility for MongoDB:
Hint: This matrix supports Graylog for use with Data Node. If you are running Graylog with self-managed OpenSearch, see your compatibility requirements.
Graylog Version
Minimum MongoDB Version
Maximum MongoDB Version
6.0.x
5.0.7
7.x
6.1.x
5.0.7
7.x
6.2.x
5.0.7
8.2.x
6.3.x
5.0.7
8.2.x
7.0.x
7.x
8.2.x
7.1.x
7.x
8.2.x
7.2.x
7.x
8.3.x
Supported Linux Operating Systems
Graylog offers official DEB and RPM package repositories for the following supported Linux operating systems:
Operating Systems
Versions
Debian
12
Ubuntu
22.04, 24.04
RHEL (AlmaLinux, Rocky Linux)
8, 9
SUSE Linux Enterprise Server
15
Supported Docker Images
We recommend you begin by reading Containerized Deployment to familiarize yourself with the Compose file necessary to deploy Graylog in a Docker container. We have also provided step-by-step instructions for running Graylog in Docker once you are ready to begin set up. Note that Graylog provides official Docker images.
Compatibility for Graylog Open and Enterprise with OpenSearch
If you are using Graylog with self-managed OpenSearch, Graylog Open and Graylog Enterprise require the following version compatibility for software dependencies:
Graylog Version
Minimum OpenSearch Version
Maximum OpenSearch Version
6.0.x
5.0.7
7.x
1.1.x
2.15.x
6.1.x
5.0.7
7.x
1.1.x
2.15.x
6.2.x
5.0.7
8.2.x
1.1.x
2.19.6
6.3.x
5.0.7
8.2.x
1.1.x
2.19.6
7.0.x
7.x
8.2.x
1.1.x
2.19.6
7.1.x
7.x
8.2.x
1.1.x
2.19.6
7.2.x
7.x
8.3.x
1.1.x
3.7.x*
*OpenSearch 3.x is supported for new installations and for upgrades of existing self-managed deployments if there are no incompatible indices. Indices created under an OpenSearch version older than 2.0 are incompatible with OpenSearch 3.x.
Compatibility for Graylog Security with OpenSearch
If you are using Graylog with self-managed OpenSearch, Graylog Security requires the following version compatibility for software dependencies:
Graylog Version
6.0.x
5.0.7
7.x
2.0.x
2.15.x
6.1.x
5.0.7
7.x
2.0.x
2.15.x
6.2.x
5.0.7
8.2.x
2.0.x
2.19.6
6.3.x
5.0.7
8.2.x
2.0.x
2.19.6
7.0.x
7.x
8.2.x
2.0.x
2.19.6
7.1.x
7.x
8.2.x
2.0.x
2.19.6
7.2.x
7.x
8.3.x
2.0.x
3.7.x*
