Additional Configuration
In addition to adjusting configuration properties in Graylog’s primary configuration files, you might need to complete some configuration for additional components of the Graylog stack. Specifically, you need to ensure proper configuration of MongoDB for metadata and configuration data on your clusters and of JVM heap settings for memory management.
This article provides additional detail about each of these components and offers guidance about where and how to set these related configuration properties.
Prerequisites
It is generally required that you are an administrator of the application that requires configuration.
You must have access credentials to third-party components in your environment as necessary.
MongoDB Configuration
MongoDB is responsible for storing metadata and configuration data of the Graylog clusters. You often need to adjust MongoDB properties to allow other Graylog nodes access to the shared database.
For official guidance on adjusting configuration properties for self-managed MongoDB instances, we highly recommend you review the MongoDB documentation.
For use with Graylog, the following situations can require additional configuration for MongoDB:
Ensure that you configure MongoDB for multi-node environments. Both Graylog and Data Node must be configured to connect to MongoDB, and MongoDB must be configured to correctly connect to multiple nodes of Graylog. Specific settings to update are included in our multi-node installation documentation.
Modifications to your MongoDB service can be required for ongoing management of a MongoDB cluster. For instance, adding database machines to an existing cluster requires configuration changes. Consult the MongoDB documentation for details.
If you run MongoDB with authentication, you must configure access control. See the MongoDB documentation for details.
JVM Heap Settings
The Java Virtual Machine (JVM) heap is a memory space that stores objects created by Java applications. The JVM heap is created when the JVM starts and is used by the JVM to allocate objects. Graylog, Data Node, and OpenSearch are Java-based applications. You need to control the amount of memory allocated to each for optimal performance.
It is generally recommended to set JVM heap size to half of your available RAM, but it should not exceed 31 GB. Note that the 31 GB limit is per service, not per computer.
You need to set JVM heap size in the following locations:
Data Node: The Data Node has two JVM heap settings, one for the search backend and one for the service:
Search Backend: Update the
opensearch_heapproperty indatanode.conf.Hint: You are directed to update this property during installation. However, if your environment changes, you might need to revisit this setting to maintain peak performance. -
Data Node service: Add or update values in
jvm.options, found at/etc/graylog/datanode/. This files is a text file that you can generally open and update directly by adding the minimum and maximum heap size. It is recommended to set both values the same:Copy-Xms1g
-Xmx1gThis service needs very little memory and can be set at 1 or 2 GB.
Graylog server: Set the heap value in
graylog-server, found at:-
/etc/default/graylog-serverfor DEB-based packages
/etc/sysconfig/graylog-serverfor RPM-based packages
This file is a text file that you can generally open and update directly by adding the minimum and maximum heap size. It is recommended that you set the both values to be the same, so a typical setting might look like:
GRAYLOG_SERVER_JAVA_OPTS="-Xms2g -Xmx2g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow"
Hint: This setting has a default value set initially. Therefore, you should only need to update the-Xms2gand-Xmx2goptions to the desired amount of RAM. -
OpenSearch: Set the value for OpenSearch in
jvm.options, found at/etc/opensearch/.Warning: You can only set this value directly if you have a self-managed OpenSearch installation. If you are running Data Node, Graylog manages this setting for you, so this file and file path are not available.
OpenSearch Configuration
The following scenarios with OpenSearch might require additional configuration:
Ensure minimum requirements for using OpenSearch are met as per OpenSearch guidance.
When creating or updating a cluster of OpenSearch nodes, some additional configuration properties likely need adjustment.
Adjust JVM heap settings for OpenSearch as noted in the previous section.
For a Graylog installation using self-managed OpenSearch, if you want to set authentication to OpenSearch, consult the OpenSearch documentation.
Hint: If OpenSearch authentication is required, we strongly recommend installing or upgrading to Graylog with Data Node.
Further Reading
