Graylog Server Configuration Settings Reference
The file server.conf is the Graylog server configuration file. When you install and configure Graylog for the first time, we recommend that you follow the instructions provided in the installation documentation. Review Graylog Server Configuration for information on accessing and updating this configuration file. For additional configuration options available via this file, consult the tables below.
Configuration Database Connection Properties
These properties define connections to the MongoDB database, which stores cluster configuration metadata.
| Parameter | Default Value | Recommended Value | Description |
Increase this value according to the maximum connections your MongoDB server can handle from a single client if you encounter MongoDB connection problems. |
MongoDB connection string. See the MongoDB documentation for details To secure this connection with a user name and password, see Configure Graylog to Use MongoDB Password Authentication. |
This defines the number of attempts the search version probe should run before giving up. Default 0 means retry indefinitely until a connection can be established. |
Core Graylog Cluster Settings Properties
These properties define important cluster identification and security elements that must be set.
This directory contains binaries that are used by the Graylog server (relative or absolute). |
None |
A comma-separated list of content packs (files in |
The directory that contains content packs that should be loaded on the first start of Graylog |
Determines whether content packs in |
This directory is used to store Graylog server state (relative or absolute). |
Ignores any exceptions encountered when running migrations. Use with caution! Skipping failing migrations can result in an inconsistent database state. |
If you are running more than one instance of Graylog server, you have to select only one graylog-server node as the leader. This node performs periodic maintenance actions that replica nodes do not perform. For replica nodes, set this value to |
The auto-generated node ID is stored in this file and read after restarts. It is recommended to use an absolute file path here if you are starting Graylog from init scripts or similar. |
None |
You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters. Generate one by using, for example: |
Set plugin directory here (relative or absolute). |
None |
empty |
The email address of the root user. |
None |
You MUST specify a hash password for the root user (which you only need to initially set up the system and in case you lose connectivity to your authentication backend). This password cannot be changed using the API or via the web interface. If you need to change it, modify it in this file. Create one by using, for example: |
The time zone setting of the root user. See this list of valid time zones. |
The default root user is named |
Do not perform any preflight checks when starting. |
Data Lake Properties
Use these properties to adjust aspects of the Graylog Data Lake or to provision Data Lake as part of an initial installation of Graylog. For information about implementing Data Lake in Graylog, see Data Lake.
Enables or disables the Data Lake feature. If the internal data lake becomes corrupted, disable this setting before starting Graylog to facilitate recovery. |
Defines the maximum age of snapshots to retain when running an optimization job. Each time data is written to the data lake, a snapshot is created. Snapshots are used to access point-in-time data. During optimization, older snapshots are deleted unless there are fewer snapshots than specified in
Defines how many snapshots should be retained when running an optimization job. Each time data is written to the data lake, a snapshot is created. Snapshots are used to access point-in-time data. This setting takes precedence over
Sets where the data lake journal is stored. |
Sets the interval after which data is flushed from the queue and written to the journal.
Specifies a message count at which Graylog forces data from the queue to be written to the journal.
Sets the maximum age of a message within the internal data lake journal. Before processing, messages wait in the journal. If the data lake backend is unreachable, messages accumulate in the journal until the backend becomes reachable again. We recommend you configure this property for the maximum length that backed up data could still be considered relevant. To minimize dropped data when the journal begins to fill, set this value high (72 hours or greater).
Sets the maximum size on disk used by the internal data lake journal. Before processing, messages wait in the journal. If the data lake backend is unreachable, messages accumulate in the journal until the backend becomes reachable again. If you use an internal data lake, this property should be configured to the same maximum size as the Graylog journal. Ideally, journals of all Graylog nodes combined should be sized to hold 1 day of normal data ingestion.
Sets the maximum age of journal segments.
Sets the maximum size on disk of journal segments.
Sets the percentage of internal data lake journal space that can be used before a warning is issued. For significantly larger journal sizes, we recommend you set this value much lower than the default (perhaps 20%). |
Sets the timeout value for data lake preview, after which the operations fails. If you perform extremely demanding preview tasks (for example, searching large time periods with many filters), you might need to increase this value. |
Sets how frequently Graylog runs the retention job for an internal data lake on a Graylog cluster. |
Email Properties
These properties configure email notification delivery settings.
Empty |
Empty |
Empty |
Journal Properties
These properties control the location, size, and performance of the on-disk journal, which contains all messages until they are written in the search backend.
The directory that is used to store the message journal. The directory must be exclusively used by Graylog and must not contain any files other than the ones created by Graylog itself. |
Enables the disk-based message journal. |
Sets a time interval at which Graylog forces an |
Specifies a message count at which Graylog forces an |
The maximum time the journal holds a message before it is dropped without being processed. Works with |
The maximum size the journal grows to before messages are dropped without processing. This property works with When messages are dropped, they are dropped on a first in, first out (FIFO) basis. |
Controls the period of time after which Graylog forces the log to roll even if the segment file isn’t full to ensure that retention can delete or compact old data. |
Sets the size of the journal segment. |
Networking Properties
These properties relate to communication between Graylog nodes as well as between Graylog and external environments.
Configures system-wide enabled TLS protocols. Only configure this if you need to support legacy systems. We maintain a secure default (currently TLS 1.2 and TLS 1.3). |
Specifies whether to use TLS for the Forwarder service. |
Determines whether the Forwarder service starts automatically. |
The Forwarder input TLS configuration value (Boolean). |
Overrides the TLS configuration value displayed in the Forwarder wizard. This property does not change the actual TLS configuration but only what is displayed in the Forwarder UI. |
Graylog instance hostname. |
Overrides the hostname displayed in the Forwarder wizard. This property does not change the actual hostname of the Forwarder but only what is displayed in the Forwarder UI. |
Determines whether inputs can be specified for individual nodes or must be run globally on all nodes. If you set this property to |
Sets the network interface used by the Graylog HTTP interface. This address and port is used by default in the |
The default connect timeout for outgoing HTTP connections. Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). |
Enables CORS headers for the HTTP interface. This setting is necessary for JavaScrip clients accessing the server directly. If this is disabled, modern browsers will not be able to retrieve resources from the server. |
Compresses API responses and therefore helps to reduce overall round trip times. |
Secures the communication with the HTTP interface with TLS to prevent request forgery and eavesdropping. Note that additional configuration is required. |
Sets the public URI of Graylog, which is used by the Graylog web interface to communicate with the Graylog REST API. The external Graylog URI usually has to be specified if Graylog is running behind a reverse proxy or load-balancer and it will be used to generate URLs addressing entities in the Graylog REST API (see |
The maximum size of the HTTP request headers in bytes. |
None |
A list of hosts that should be reached directly, bypassing the configured proxy server. This value is a list of patterns separated by commas (,). The patterns can start or end with an asterisk (*) for wildcards. Any host matching one of these patterns will be reached through a direct connection instead of through a proxy. |
None |
Sets an HTTP proxy for outgoing HTTP connections. |
Sets the HTTP URI of this Graylog node, which is used to communicate with the other Graylog nodes in the cluster and by all clients using the Graylog web interface. The URI is published in the cluster discovery APIs so that other Graylog nodes are able to find and connect to this Graylog node. This setting has to be used if this Graylog node is available on a network interface other than This setting must not be configured to a wildcard address! If |
The default read timeout for outgoing HTTP connections. Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). |
The size of the thread pool used exclusively for serving the HTTP interface. |
The X.509 certificate chain file in PEM format to use for securing the HTTP interface. |
The PKCS#8 private key file in PEM format to use for securing the HTTP interface. |
The password to unlock the private key used for securing the HTTP interface (if key is encrypted). |
The default write timeout for outgoing HTTP connections. Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). |
How many seconds to wait between marking node as DEAD for possible load balancers and starting the actual shutdown process. Set this value to 0 if you have no status checking load balancers in front. |
lb_throttle_threshold_percentage
Journal usage percentage that triggers requesting throttling for this server node from load balancers. The feature is disabled if not set. |
Connection timeout for a configured LDAP server (e. g., Active Directory) in milliseconds. |
Comma-separated list of trusted proxies that are allowed to set the client address with X-Forwarded-For header. Can be subnets or hosts. |
Performance Tuning Properties
These properties allow you to affect the performance of your Graylog installation.
Sets the length of time items stay in the asset cache after the last time they are accessed. Set a higher value (for example, |
Sets the maximum number of entries in the asset cache. Set a higher value (for example, |
Number of threads used exclusively for dispatching internal events. |
Enable to auto-restart manually stopped inputs. |
The number of parallel running processors. Raise the number if your input buffer is filling up. |
no limits |
Optional limits on scheduling concurrency by job type. No more than the specified number of worker threads can execute jobs of the specified type across the entire cluster. |
Batch size for the search backend output. This value is the maximum number of messages the search backend output module gets at once and writes to the search backend in a batch call. Alternatively, you can set the value to maximum size by including a size designation with the number, such as 10mb. If the configured batch size has not been reached within the number of seconds set in |
Defines how many faults an output can have before not being tried again for a number of seconds set in |
Sets the delay in seconds to wait before retrying a failing output that has hit the |
Flushes interval (in seconds) for the search backend output. This value is the maximum amount of time between two batches of messages written to the search backend. It is effective only if your minimum number of messages for this time period is less than |
Sets the size of the thread pool in the output buffer processor. |
Dynamically calculated |
The number of parallel running processors. By default, this value is determined automatically based on the number of CPU cores available. Set this value explicitly to override the dynamically calculated value. Raise the number if your buffers are filling up. |
Wait strategy describing how buffer processors wait on a cursor sequence. Possible types:
Size of internal ring buffers. Raise this value if raising |
UDP receive buffer size for all message inputs (for example, |
Performance Monitoring and Logging Properties
These properties control configuration of metrics and logging that Graylog performs.
IP address and port for the Prometheus exporter HTTP server. |
Enables the Prometheus exporter HTTP server. |
None |
Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is replaced with the mappings in this file. This file is monitored for changes, and updates are applied at runtime. |
None |
Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are configured in addition to the built-in core mappings. Mappings in this file cannot overwrite any core mappings. This file is monitored for changes, and updates are applied at runtime. |
Configures the refresh interval for the monitored Prometheus exporter mapping files. |
Report Generation Properties
These properties determine aspects of how Graylog generates reports. The bin_dir property and data_dir property, covered in the Core Graylog Cluster Settings Properties section, are also relevant for reports. See Reports for more details about reporting and these properties.
Specifies whether report generation can run in environments with self-signed TLS certificates. |
Set to
Time in seconds to wait for report generation. When a report takes longer than configured to load, the report generation fails, and Graylog logs the error. |
None |
Port to communicate with background process. The reporting engine can bind to any available port. If no port is assigned, a random, available port is used. |
Used to customize the URI the reporting background process uses to connect to the Graylog web interface. |
Internal user to generate reports. |
Search Backend Configuration Properties
These properties affect how the backend search service is configured, such as where data is stored and node roles.
elasticsearch as a naming convention, the properties apply to any search backend.
Maximum number of attempts to connect to Data Node on boot. With the default, |
Sets the wait time between connection attempts for |
The default index prefix for Graylog events. |
The default index prefix for Graylog system events. |
Disables the optimization of search backend indices after index cycling. This process can take some load from the search backend on heavily used systems with large indices, but it will decrease search performance. The default is to optimize cycled indices. |
This configuration list limits the retention strategies available for user configuration via the UI. The following strategies can be disabled:
Note that at least one strategy must be enabled. Be careful when extending this list on existing installations! |
Analyzer (tokenizer) to use for Note that this setting takes effect only on newly created indices. |
Enables payload compression for search backend requests. |
Maximum amount of time to wait for successful connection to the search backend HTTP port. |
Disables checking the version of the search backend for compatibility with this Graylog release. |
Sets the default scheme when connecting to the search backend discovered nodes. Available options: |
Enables automatic search backend node discovery through Nodes Info. |
Empty |
Filter for including or excluding search backend nodes in discovery according to their custom attributes. |
Frequency of the search backend node discovery. |
List of search backend hosts Graylog should connect to, specified as a comma-separated list of valid URIs for the HTTP ports of your search backend nodes. If one or more of your search backend hosts require authentication, include the credentials in each node URI that requires authentication. |
Maximum idle time for a search backend connection. If this value is exceeded, the connection is torn down. |
Maximum number of concurrently running index optimization (force merge) jobs. If you use many different index sets, you might need to increase this number. |
Global timeout for index optimization (force merge) requests. |
The prefix for the default Graylog index set. |
20000000 |
Approximate maximum number of documents in a search backend index before a new index is created. Configure this value if you set |
Sets the number of indices to keep. |
Maximum number of times Graylog retries failed requests to the search backend. |
Approximate maximum size in bytes per search backend index on disk before a new index is created. Configure this value if you set |
Approximate maximum time before a new search backend index is created. Configure this value if you set Specify the time using a duration and a suffix indicating which unit you want:
Permitted suffixes are: See also |
Maximum number of total connections to the search backend. |
Maximum number of total connections per search backend route (typically this means per search backend server). |
Optional upper bound on |
Mutes the logging-output of search backend deprecation warnings during REST calls in the search backend REST client. |
The number of replicas for your indices. A good setting here highly depends on the number of nodes in your search backend cluster. |
Controls whether empty indices are rotated. Applies only if |
The number of shards for your indices. A good setting here highly depends on the number of nodes in your search backend cluster. |
Maximum amount of time to wait for reading back a response from a search backend server. |
Name of the search backend index template used by Graylog to apply the mandatory index mapping. |
Enables use of |
Maximum number of attempts to connect to the search backend on boot for the version probe. |
Sets which rotation options are available through the UI. The options available to set are:
A strategy can be disabled by specifying the optional |
Time interval to trigger a full refresh of the index field types for all indexes. This option queries the search backend for all indexes and populate any missing field type information to the database. |
Optimize the index down to <= |
Time interval for index range information cleanups. This setting defines how often stale index range information is purged from the database. |
None |
Provides a hard upper limit for the retention period of any index set at configuration time. This setting is used to validate the value a user chooses for the maximum number of retained indexes when configuring an index set. However, it is only in effect when a time-based rotation strategy is chosen. If a rotation strategy other than time-based is selected or if no value is provided for this setting, no upper limit for index retention is enforced. |
Disables message retention on this node—that is, disables the search backend index rotation. |
Determines what happens with the oldest indices when the maximum number of indices is reached. The following strategies are available:
The default index rotation strategy to use. For details, see Index Time Size Optimizing. |
User Experience Properties
These properties affect the user experience in the Graylog web interface.
Allows searches to be highlighted. Depending on message sizes, this setting can use a lot of memory and should be enabled only after making sure your search backend cluster has enough memory. |
Allows searches to begin with wildcard characters. Such searches can use a lot of resources and should only be enabled with care. |
Sets how often the Welcome screen content feed checks for new posts. See |
URL for the content feed that appears on the Welcome screen. |
The default cache time for dashboard widgets. The minimum setting is 1 second. |
Maximum value that can be set for an event limit. |
Sets field value suggestion mode. The possible values are:
Enables Graylog to periodically investigate indices to determine which fields are used in which streams. Therefore, field lists in the Graylog interface show only fields used in selected streams. This option can decrease system performance, especially on systems with a large number of streams and fields. |
SIDECAR_STATUS_UNKNOWN
Comma-separated list of notification types that should not lead to a system event. |
Miscellaneous Properties
These properties affect Graylog elements not directly relevant to other categories.
None |
Optional allowed paths for Graylog data files. If provided, certain operations in Graylog are permitted only if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter). All sub-directories of indicated paths are allowed by default. This option provides an additional layer of security and allows administrators to control where in the file system Graylog users can select files from. |
Using the default value minimizes the possibility of repeated snapshots being retaken with multiple server reboots during the day. |
Sets the interval at which the asset history snapshots are taken. The minimum supported value is one hour ( |
Disable the use of OSHI for collecting system stats. |
Time in milliseconds to wait for all message outputs to finish writing a single message. |
Controls how often processing status information is written to the database. Values must be a positive duration and cannot be less than 1 second. |
Configures the threshold for detecting outdated processing status records. Any records that have not been updated in the configured threshold time are ignored. Values must be a positive duration and cannot be less than 1 second. |
The default HTTP call timeout for cluster-related REST requests. This timeout might be overriden for some resources in code or other configuration values. (Some cluster metrics resources use a lower timeout value.) |
For some cluster-related REST requests, the node must query all other nodes in the cluster. This value is the maximum number of threads available for this process. Increase the value if The value should be |
shutdown_timeout
30000
How many milliseconds should the Data Node wait for termination of all tasks during the shutdown. |
Time in milliseconds after which a detected stale leader node is rechecked on startup. |
Sets the maximum number of times a stream can timeout before it is disable and a notification shown in the web interface. See also |
Sets the maximum execution time for stream rules, in milliseconds, before throwing a fault. See also |
