Red Hat Installation: Multiple Graylog Nodes
This installation guide covers installing Graylog on Red Hat 8 or 9 on a multi-node cluster consisting of more than one Graylog and MongoDB node and more than one Data Node. A generally recommended cluster design that supports most medium-to-large scale deployments is our Conventional model, which is composed of three Graylog and MongoDB nodes and three Data Nodes; however, this installation guide can generally be followed at any scale cluster.
This article will guide you through installing three services that comprise the Graylog stack: MongoDB, Graylog Data Node, and Graylog.
Prerequisites
Verify that all required ports are open. We assume in the following steps that firewalls are disabled and traffic can flow across all necessary ports.
A load balancer with a DNS record assigned for Graylog is encouraged for this deployment type.
We strongly recommend the use of an XFS file system for storage.
Review the Conventional architecture diagram and our recommendations for resource allocation before you begin installation.
Server Timezone
To set a specific time zone on a Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
sudo timedatectl set-timezone UTC
Configuration and Service Files
Before you begin the process of installing Graylog and its required components, it is important to note that there are multiple configuration files and service files included in the Graylog and MongoDB operating system packages that should be adjusted during the initial deployment process to optimize your system performance. For your reference, the files mentioned in this installation guide for each service are as follows:
MongoDB: The MongoDB configuration file. For extensive information on the configuration properties included in this file, we recommend you review the MongoDB documentation. We offer some additional guidance on the use and maintenance of this file in Additional Configuration.
Data Node: The Graylog Data Node has a configuration file that should be adjusted during deployment. A full reference for the Data Node configuration file can be found in Data Node Configuration Settings Reference.
Graylog: Graylog also has both a configuration file and a service file that should be adjusted during deployment. We recommend you review Initial Configuration Settings first. A full reference for the Graylog server configuration file can also be found in Graylog Server Configuration Settings Reference. Also, the Graylog service file must be adjusted for heap settings; additional information on this file may be found in Additional Configuration.
Install MongoDB
MongoDB is a NoSQL database designed to store and manage data in a flexible, scalable, and high-performance manner. As a part of the Graylog stack, MongoDB serves as the metadata database for the system.
The official MongoDB documentation provides a helpful tutorial on installation with Red Hat. Additionally, we recommend you review their guide for setting up a MongoDB cluster. For information on installing MongoDB for use with Graylog, we recommend you generally follow the process below.
Create the repository file:
Copysudo nano /etc/yum.repos.d/mongodb-org-8.0.repoHint: You may need to install Nano for use with Red Hat. -
Add the following MongoDB repository configuration:
For Red Hat 8▼Copy[mongodb-org-8.0]
name=MongoDB Repository
baseurl=https://repo.mongodb.org/yum/redhat/8/mongodb-org/8.0/x86_64/
gpgcheck=1
enabled=1
gpgkey=https://pgp.mongodb.com/server-8.0.ascFor Red Hat 9▼Copy[mongodb-org-8.0]
baseurl=https://repo.mongodb.org/yum/redhat/9/mongodb-org/8.0/x86_64/
gpgcheck=1
enabled=1
gpgkey=https://pgp.mongodb.com/server-8.0.asc -
Install the latest stable version of MongoDB:
Copysudo yum update
sudo yum install mongodb-org -
Hold the currently installed version of the MongoDB package to prevent it from being automatically upgraded to a newer version when updates are installed:
Copysudo yum versionlock add mongodb-orgHint: See the RedHat documentation for installingyum-versionlock. -
Open the MongoDB configuration file:
Copysudo nano /etc/mongod.conf -
By default, MongoDB only listens locally.You must modify either the
bindIporbindIpAllsetting in the MongoDB configuration file so that the port binds to an interface address or a host name or listens on all interfaces. See the example configurations below.To listen on all interfaces:
Copynet:
port: 27017
bindIpAll: trueTo bind to a specific interface, like
192.168.50.71:Copynet:
port: 27017
bindIp: 192.168.50.71To bind to a host name, like
graylog01:Copynet:
port: 27017
bindIp: graylog01 -
Create the MongoDB replica set in the MongoDB configuration file:
CopyreplSetName: "rs0" -
Enable MongoDB and start the service:
Copysudo systemctl daemon-reload
sudo systemctl enable mongod.service
sudo systemctl start mongod.service -
On the leader node only, initiate the replica set. In the following example command,
graylog01,graylog02, andgraylog03represent the host names of the Graylog/MongoDB nodes. You must update them to reflect the host names or IP addresses of your Graylog/MongoDB nodes:Copysudo mongosh
rs.initiate( { _id : "rs0", members: [ { _id: 0, host: "graylog01:27017" }, { _id: 1, host:"graylog02:27017" }, { _id: 2, host: "graylog03:27017" } ] }) -
Repeat all of the above steps for your additional MongoDB nodes.
Install Data Node
Data Node is a component in Graylog's architecture designed to handle log ingestion, processing, and indexing, and manage communication with OpenSearch for storing and querying logs efficiently. As noted in the Conventional architecture, the Data Node service should be maintained on its own cluster, separate from Graylog and MongoDB.
To install Data Node, we recommend you follow the process below:
Install the Data Node package on a select node in your Data Node cluster:
Copysudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo yum install graylog-datanode -
Create your
password_secret. This is a secure, randomly generated string used to encrypt sensitive data within the system:Copyopenssl rand -hex 32Hint: This command uses OpenSSL, a toolkit for TLS/SSL protocols and cryptography, to generate a secure random password. See the OpenSSL documentation for more information. -
Open the Data Node configuration file:
Copysudo nano /etc/graylog/datanode/datanode.conf -
Add the
password_secretvalue to the Data Node configuration file. Note that you must add this same value to the Graylog server configuration file in a later step since it is crucial that this value be the same for the Graylog node. -
Ensure the heap settings are set to half your system memory, up to a max of 31 GB. To do so, you will need to add the following configuration property to your Data Node configuration file. For example, if you have 16 GB of RAM, you would set it to 8 GB, like in the example below:
Copyopensearch_heap = 8gWarning: This configuration property is not included in thedatanode.confby default! It must be added to the file manually. -
Configure the MongoDB connection string in the Data Node configuration file. In the following example command,
graylog01,graylog02, andgraylog03represent the host names of the MongoDB nodes. You must update them to reflect the host names or IP addresses of your MongoDB nodes:Copymongodb_uri = mongodb://graylog01:27017,graylog02:27017,graylog03:27017/graylog?replicaSet=rs0Hint: This example connects to MongoDB without authentication. To connect with a user name and password instead, see Configure Graylog to Use MongoDB Password Authentication.
Enable Data Node and start the service:
sudo systemctl enable graylog-datanode.service
sudo systemctl start graylog-datanode -
Follow all of the above steps for each additional Data Node with the exception of generating the password secret. The value you first generated and configured must be the same for each additional node.
Install Graylog
After Data Node installation is complete, you must install the core Graylog service. Our recommended cluster architecture denotes that the Graylog and MongoDB services are installed on the same nodes.
To install Graylog, we recommend you follow the process below:
On a select node in your Graylog/MongoDB cluster, install the Graylog package.
For Graylog Open ▼Copysudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo yum install graylog-serverFor Graylog Enterprise ▼Copysudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo yum install graylog-enterpriseFor Graylog Security ▼Copysudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo yum install graylog-enterprise -
Use the following command to create your
root_password_sha2. This is the password for the root administrator account for the Graylog interface. Make sure you record this password as you will need it to log into the Graylog interface after preflight configuration:Copyecho -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1Warning: Do NOT attempt to log into Graylog for the first time using the password you generated in the steps above! You must complete the preflight login with the credentials found in the log file after first starting the Graylog service. You will be able to login to Graylog with your generated password after the preflight is complete. See The Web Interface for more information. -
Open the Graylog server configuration file:
Copysudo nano /etc/graylog/server/server.conf -
Enter the value you created for the
root_password_sha2in the previous step into the Graylog configuration file. -
Retrieve the password secret from the Data Node configuration file as indicated in steps 3-5 of Install Data Node and add it to the
password_secretproperty in the Graylog configuration file. -
Make the following additional adjustments to your Graylog configuration file to optimize the performance and integration of your Graylog cluster.
Set the
http_bind_addressvalue in the Graylog configuration file to the public host name or a public IP address on which the Graylog web and API server will listen for incoming HTTP requests. (This property is commented out by default and listed beneath the# HTTP settingssection of the configuration file):Copyhttp_bind_address = 0.0.0.0:9000Hint: More information about these settings can be found in The Web Interface. -
Configure the MongoDB connection string. In the following example command,
Configure the external URI. The
http://graylog.user.com/value equals the DNS record set on your load balancer:Copyhttp_external_uri = http://graylog.user.com/ -
Adjust your journal settings. We recommend you configure your journal settings' max age to 72 hours and the size to your expected total log volume over a 72-hour period divided by the number of nodes in your cluster. So, if your expected daily log volume is 30 GB, your max size over 72 hours would be 90 GB. And if there are three Graylog nodes in your cluster, then you would divide 90 GB by 3, resulting in 30 GB, as in the example below:
Copymessage_journal_max_age = 72h
message_journal_max_size = 30gb -
On the follower nodes only, ensure that the setting
is_leaderis set tofalse.Copyis_leader = falseHint: The settingis_leaderis set totrueby default!
Open the
graylog-serverfile found by default at/etc/graylog/:Copysudo nano /etc/sysconfig/graylog-server -
In the
graylog-serverfile, adjust your heap settings to half the system memory up to a max of 16 GB for the Graylog service, as recommended in Additional Configuration. It is recommended that you set the minimum and maximum values to be the same, so if you are setting your minimum to 2 GB, like shown in-Xms2g, and your maximum to 2 GB, like shown in-Xmx2g, the setting may look like:CopyGRAYLOG_SERVER_JAVA_OPTS="-Xms2g -Xmx2g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow" -
Enable Graylog and start the service:
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service -
Follow all of the above steps for each additional Graylog node with the exception of generating the root administrator password. The value you first generated and configured must be the same for each additional node.
Once installation is complete, proceed to the following section on the preflight login to access the Graylog web interface!
Preflight Login
After installation is complete, immediately proceed to The Web Interface for information on completing the preflight process and logging into Graylog for the first time. This preflight login will require the initial login credentials found in the log file after first starting the Graylog service!
Troubleshooting and Common Issues
The following section outlines troubleshooting steps for common issues to assist you in resolving potential challenges you may encounter.
Issue: Network Connectivity Issue During MongoDB Installation
It is possible you may receive a network connectivity issue while you are initiating the replica set for MongoDB. This may be related to your DNS and/or your TCP port or network configuration.
Solution: Modify Firewall and/or DNS Settings
If you encounter this issue, we recommend you test whether the required port TCP/27017 is open. You can use telnet or nc (Netcat) to test:
nc -vz <node_ip> 27017
