Compliance Unified Visibility Content Pack (Preview)
This preview compliance pack provides targeted visibility into Identification and Authentication (IAC), Network (NET), and Endpoint (END) events that support control requirements shared across NIST SP 800-53 Rev 5, PCI DSS v4.0, and US CMMC 2.0 Level 1. The Spotlight includes dashboards and a daily report template with tailored widgets for compliance reporting.
Supported Frameworks
This pack currently supports a subset of controls from the following compliance frameworks:
PCI DSS v4.0
US CMMC 2.0 Level 1
Graylog 6.1.6+ with a valid Security license
Graylog Illuminate 6.3.0 or later
What is Provided
Compliance: Unified Visibility (Preview) dashboard
Compliance: Unified Visibility Report (Preview) report template
Using This Content Pack
GIM Categorization
This compliance pack uses events that have been categorized using Graylog Information Model (GIM) categorization codes and in some cases additional schema-defined fields. It is not restricted to a specific product. Illuminate content that leverages Core enrichment will assign GIM categories automatically where applicable. Custom packs and pipeline rules can manually assign GIM categories as well for inclusion in this pack's dashboard widget searches.
Refer to the Graylog Information Model (GIM) Categories Reference for a complete list of GIM categorizations, and the enrichments documentation for more information on Illuminate enrichments.
Identification and Authentication (IAC) Events
For widgets pertaining to Identification and Authentication (IAC) events, the following GIM event types are utilized:
account created
account deleted
account modified
account renamed
account disabled
account enabled
account locked
account unlocked
group member added
group member removed
password change
administrative password reset
access policy violation
account policy violation
credential validation
logon
Network (NET) Event Categories
For widgets pertaining to Network (NET) events, the following GIM event categories are utilized:
network
authentication
Network (NET) GIM Tags
For widgets pertaining to Network (NET) events, the following GIM tags are utilized:
remote_access (used in conjunction with
gim_event_category: authentication) -
source_is_internal
destination_is_internal
Endpoint (END) Events
For widgets pertaining to Endpoint (END) events, the following GIM event categories are utilized:
alert
detection
Report Generation
This compliance pack includes a prebuilt report template for exporting dashboard data. The report can be scheduled for regular delivery via email in accordance with compliance requirements of continuous logging and monitoring and data storage over long periods of time.
Please view the reporting documentation for full details on report generation.
Scheduled compliance reports can be configured with the following example workflow in Graylog:
Navigate to the Enterprise > Reports.
Locate the report Compliance: Unified Visibility Report (Preview).
In the More dropdown, select Edit.
(Optional) Modify the report Content and Style to your specifications.
Select the Delivery tab.
Adjust any current settings as desired, such as the report delivery schedule.
Add one or more recipients to the Email recipients field.
Select Update to save the changes.
Compliance Unified Visibility Spotlight Preview
The Spotlight pack offers a dashboard with 3 tabs:
Network Security (NET)
Endpoint Security (END)
