Microsoft Defender for Endpoint Content Pack
Microsoft Defender for Endpoint is an industry-leading, cloud-powered endpoint security solution that helps to secure against ransomware, file-less malware, and other sophisticated attacks on Windows, macOS, Linux, Android, and iOS.
Supported Versions
  • Graylog Server 5.2 or later
Requirement(s)
  • Microsoft Defender for Endpoint Plan 1 or Plan 2.
  • Graylog Server with a valid Enterprise license.
Stream Configuration
  • "Illuminate:Microsoft Defender for Endpoint Messages"
Hint: If this stream does not exist prior to the activation of this pack then it is created and configured to route messages to this stream and the associated index set. There should not be any stream rules configured for this stream.
Index Set Configuration
  • "Microsoft Defender for Endpoint Logs"
Hint: If this index set is already defined, then nothing is changed. If this index set does not exist, then it is created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Collection and Delivery
Microsoft Defender for Endpoint utilizes the Graylog Microsoft Defender for Endpoint input that ingests alert logs in JSON format. Documentation detailing the configuration of this input can be found in the Graylog documentation.
Due to how Illuminate processes nested arrays, for each evidence entityType (Process, User, IP, File, URL), only one result per entityType is processed by Illuminate. Additional results can still be seen in the evidence_array field and GIM-specific fields such as user_name, file_name, and file_path.
Log Format Example
{"id":"da20708b1e-8554-4ec8-b59c-925c4663aa3a_1","incidentId":2,"investigationId":null,"assignedTo":null,"severity":"Medium","status":"New","classification":null,"determination":null,"investigationState":"UnsupportedAlertType","detectionSource":"WindowsDefenderAtp","detectorId":"7f1c3609-a3ff-40e2-995b-c01770161d68","category":"Execution","threatFamilyName":null,"title":"Suspicious PowerShell command line","description":"A suspicious PowerShell activity was observed on the machine.","alertCreationTime":"2023-04-06T10:41:43.691043Z","firstEventTime":"2023-04-06T10:39:00.7407597Z","lastEventTime":"2023-04-06T10:42:49.3567967Z","lastUpdateTime":"2023-04-06T10:45:41.5166667Z","resolvedTime":null,"machineId":"31328158e55872c03a1b5ec4c96744cbb82c8f4b","computerDnsName":"win-tfb8l7bi77h","rbacGroupName":"UnassignedGroup","aadTenantId":"df620235-50d7-4400-bb7e-3b112e9b1ff4","threatName":null,"mitreTechniques":["T1059.001","T1105","T1140"],"relatedUser":{"userName":"Administrator","domainName":"WIN-TFB8L7BI77H"},"loggedOnUsers":[{"accountName":"testuser","domainName":"DESKTOP-IIQVPJ7"}],"comments":[{"comment":"test comment","createdBy":"secop123@contoso.com","createdTime":"2020-07-21T01:00:37.8404534Z"}],"evidence":[{"entityType":"Process","evidenceCreationTime":"2023-04-06T10:45:41.51Z","sha1":"6cbce4a295c163791b60fc23d285e6d84f28ee4c","sha256":"de96a6e69944335375dc1ac238336066889d9ffc7d73628ef4fe1b1b160ab32c","fileName":"powershell.exe","filePath":"C:\\Windows\\System32\\WindowsPowerShell\\v1.0","processId":10520,"processCommandLine":"powershell.exe -NoExit -ExecutionPolicy Bypass","processCreationTime":"2023-04-06T10:42:49.2635644Z","parentProcessId":5212,"parentProcessCreationTime":"2023-04-06T10:40:44.9749107Z","parentProcessFileName":"cmd.exe","parentProcessFilePath":"C:\\Windows\\System32","ipAddress":null,"url":null,"accountName":"Administrator","domainName":"WIN-TFB8L7BI77H","userSid":"S-1-5-21-3669279935-616031708-4259075843-500","aadUserId":null,"userPrincipalName":null,"detectionStatus":"Detected"},{"entityType":"Ip","evidenceCreationTime":"2023-04-06T10:41:43.81Z","ipAddress":"10.10.10.173","url":null,"detectionStatus":null}],"domains":[]}
What is Provided
  • Field extraction, normalization, and message enrichment for Microsoft Defender for Endpoint alert log messages.
  • Graylog Information Model categorization and enforcement fields for alert events.
  • Illuminate Spotlight: Microsoft Defender for Endpoint Overview dashboard and saved search.
GIM Categorization
GIM event type categorization is provided for the following message types:
Log Type gim_event_type_code gim_event_category gim_event_subcategory gim_event_type
Defender for Endpoint Alerts (all) 300000 detection detection.network_detection ids_detection
Fields Extracted by This Pack
Alert Fields
Fields extracted from the root-level alert JSON object.
Evidence Entity Fields
Fields extracted from alert evidence entities. Only one entry per entity type (Process, File, IP, User, URL) is processed.
This spotlight offers a dashboard with 2 tabs:
Overview
Saved Search
