Users and Teams
Graylog allows you to manage users either individually or in teams. With either method, you have the option to integrate with your organization's authoritative identity source to provide single sign-on (SSO) and manage assigned permissions.
This article provides an overview of users and teams in Graylog.
Prerequisites
You must be a Graylog administrator to create and manage users and teams.
A Graylog Enterprise license is required to create and manage teams.
Users
Graylog provides multiple methods for adding and managing your users. In the Graylog web interface, visit the Users Overview page at System > Users and Teams. The Users tab lists all existing users with details such as their email address and any roles assigned to them. You can also create new users here.
User Inspector role. Typically, this role is assigned only to administrators.
For detailed information about creating users or updating existing users, see Manage Users.
Graylog can also sync with your organization’s authoritative identity source, such as Active Directory/LDAP or any OIDC-compliant provider. When you establish this connection, users are automatically imported to Graylog and you can determine what roles imported users should be assigned. In this way, Graylog can set access using the current roles and groups from the identity source, reflecting the organizational permissions structure.
For detailed information about creating teams, see Manage Teams.
Teams
The Teams feature groups users so that you can more easily assign roles. You can create teams based on work groups, shared responsibilities, physical location, or any classification useful to your organization. When you create a team, you can determine the roles that team’s members are assigned.
Users can be assigned to as many teams as necessary, or to no team. Each team can be assigned as many permissions as necessary, or no permissions. All permissions from the team are assigned to each member of the team, so a user in a team receives all the permissions for the team.
For large organizations, the Teams feature can reduce the time spent managing user access. Administrators can apply unique sets of roles to each team without worrying that any user has too much or too little access to complete their required tasks.
Team Assignment Example
Marcus, an IT admin, has an organization with 10 teams and 5 users on each team. Because each team is focused on different areas, Marcus sets the Graylog roles on each team so the team members have the permissions they need for their jobs.
For example, the analyst team is assigned the Reports Manager role so that they can produce and distribute reports from the data. Of course, they also need the appropriate permissions to access the data. The security team is assigned all security-focused roles, and so forth. In this way, all teams get only the roles they require, and Marcus saves time by assigning roles through teams instead of to all the individual users.
Further Reading
