Manage Users
Each person that accesses your Graylog environment needs to have a user account created with authentication credentials and assigned roles. Graylog provides two methods for user management:
Integration with your organization’s authoritative identity source
Manual user management
For information about integrating identity sources with Graylog, see Single Sign-On.
This article explains how to manually create and manage users in the Graylog web interface as well as how to set password requirements to match your company security policy.
Prerequisites
You must be a Graylog administrator to create and manage users.
Admin users can view and update their own profile but cannot create or update other users or view the Users and Teams page.
Create Users
In the Graylog web interface, you perform user management on the Users Overview tab of the System > Users and Teams page. This page lists existing users and allows you to view details about each user.
To create a new user:
Click Create user.
Enter the user profile:
First name
Enter the user's first name
Last name
Enter the user's last name
Username Select a unique username for the user to log in with. As a best practice, establish a consistent naming practice for usernames.
E-Mail address
Enter the user’s email address.
Enter or adjust the user settings:
Session timeout
Set the length of time before a user is logged out due to inactivity, or select the check box to prevent the user’s session from timing out.
Timezone
Choose the local time zone for the user.
Service account
Select this check box only if you want a service account. These accounts cannot access the web interface and are limited to API access. Service accounts are typically used to run automations or back end processes.
Assign roles the user needs. Note that the
Readerrole is selected by default. TheReaderrole contains the basic permissions a user needs to access entities within the Graylog web interface. See Permission Management for complete information about roles and permissions in Graylog. -
Set the user’s initial password. Follow your organization’s security guidelines for establishing and changing passwords. Graylog recommends using only strong passwords. See Configure Password Complexity for information on how to set password requirements.
Click Create user.
The new user is added to the list on the Users Overview page.
Edit User Details
To edit an existing user:
Find the user in the list, then click Edit in the Actions column. Note that you can use the search bar to filter the list, which is useful when you have many pages of users.
Hint: The Edit User detail page has six sections, and you can update and save each separately. While some settings are the same as for new user creation, you can also set some options here that are not available for new users. -
Update the profile.
The information in this section is the same as for new user creation. Note that you cannot change the username. Click Update Profile if you make any changes in this section.
Update the settings.
The information in this section is generally the same as for new user creation, but you can also set a Start page by selecting available entities from the drop-down menus. Note that a user must have permission for the entity type and the entity must be shared with them for it to appear in the menus. Click Update Settings if you make any changes in this section.
Update the password.
An
Adminuser can change a user’s password without knowing the user’s current password. For instance, you could use this process if a user forgets their password. A non-Adminuser can change their own password by first entering their current password, then entering a new password. Click Change Password to complete the change. See Configure Password Complexity for information on how to set password requirements. -
Update preferences.
This section allows you to control certain behaviors of the Graylog web interface:
Search auto-completion: Provides auto-complete suggestions as you type in the search bar.
Search sidebar: Pins the search sidebar open on the Search page.
Dashboard sidebar: Pins the dashboard sidebar open on dashboards.
Theme mode: This section is informational, showing whether you have light mode or dark mode set for the web interface. To set the mode, use the toggle in the user drop-down menu at the upper-right side of the screen.
Update the user's roles.
Use this section to add or remove roles. Remember that at minimum every user must have the
Readerrole. See Permission Management for more information about roles. -
Update the team assignment.
Assign the user to teams or remove current team assignments. Use Quick Create Team to create a new team and assign the user to it. Note that this option allows you only to enter a name and description for the team. To assign roles through the team, you must edit the team on the Teams Overview page. For more information, see Manage Teams.
Hint: The Teams feature requires a Graylog Enterprise license. Contact the Graylog Sales team to learn more.
Graylog provides administrators the ability to set minimum requirements for password complexity that users must adhere to when setting or changing passwords. To set a password requirement for your Graylog environement:
Navigate to System > Configurations.
Select Password Policy, then select Edit.
Select configuration options that meet your company policy:
Minimum length
Set the minimum number of characters for a valid password.
Require uppercase letters
Select to require at least one uppercase character (A-Z).
Require lowercase letters
Select to require at least one lowercase character (a-z).
Require numbers
Select to require at least one numeric character (0-9).
Require special characters
Select to require at least one of the following characters:
! @ # $ % ^ & * ( ) - _ = + [ ] { } | ; : , . < > ? /
Select Update configuration.
Further Reading
