Manage Teams
Teams in Graylog let you easily assign permissions to multiple users who need the same access. You create teams with specific roles, then assign users to teams. Users in a team receive all the roles assigned to that team. You can also set default collections for teams so that all entities created by team members are available in the same collections for sharing.
Graylog provides two methods for team management:
Integration with your organization’s authoritative identity source
Manual team management
For information about the identity sources Graylog can sync with as well as how to integrate these sources, see Single Sign-On.
This article explains how to create and manage teams in the Graylog web interface if you are not synchronizing with an identity source.
Prerequisites
You must be a Graylog administrator to create and manage teams.
Create Teams
To perform team management operations in Graylog, navigate to System > Users and Teams, then select the Teams Overview tab.
This page lists existing teams and allows you to view details about each team.
To create a new team:
- Click Create team.
Enter a Name and Description in the Profile section to identify the team.
Select users to assign to the team from the Assign Users drop-down menu. Assign multiple users by continuing to select users. Note that you can filter the list by typing in the field, which is useful when you have a large user list.
Click Assign User. The users you selected are displayed in the Selected Users section.
Select roles to assign to the team from the Assign Roles drop-down menu. Assign multiple roles by continuing to select roles. Note that you can filter the list by typing in the field. Selected roles are added automatically the to Selected Roles section.
Click Create team.
The new team is added to the list on the Teams Overview page.
Edit Teams
You can assign new users to a team, update the roles, and change other details after it is created.
To edit an existing team:
Find the team in the list on the Teams Overview page, then click Edit in the Actions column. Note that you can use the search bar to filter the list, which is useful if you have many teams.
Update the profile, assigned users, or assigned roles, as necessary. Note that you must save changes to each section independently of the others.
(Optional) Assign a default collection. Note that you can assign multiple collections. All shareable entities created by team members are automatically added to default collections for easy sharing. See Collections for complete details.
Further Reading
