SUSE Installation with Self-Managed OpenSearch
The following article contains information on deploying Graylog with self-managed OpenSearch. Please note that Graylog Data Node is the preferred method of data management. See Get Started with Data Node for more information.
This guide describes the recommended way to install Graylog on SUSE Linux Enterprise Server 15. All links and packages are present at the time of writing.
These installation steps also include installation of OpenSearch so that you can manage your search backend manually.
Warning: This installation guide does not configure security settings. Before deploying Graylog to users or ingesting production data, secure all components in the Graylog stack. This includes restricting network access, preventing public internet exposure of internal services, enabling encryption, and configuring authentication and authorization. For detailed guidance, see Secure Your Graylog Environment and Network Connectivity and Firewall Requirements.
Prerequisites
Hint: This guide assumes that any firewall is disabled and traffic can flow across all necessary ports.
Graylog 7.2 requires the following to maintain compatibility with its software dependencies:
Graylog Version Minimum MongoDB Version Maximum MongoDB Version Minimum OpenSearch Version Maximum OpenSearch Version
7.2.x
7.x
8.2.x
1.1.x (or 2.0.x for Graylog Security) 3.7.x*
*OpenSearch 3.x is supported for new installations and for upgrades of existing self-managed deployments if there are no incompatible indices. Indices created under an OpenSearch version older than 2.0 are incompatible with OpenSearch 3.x.
Additionally, we recommend you review the version notes specific to your preferred version of Graylog for guidance on installing and configuring your Graylog instance.
Server Timezone
To set a specific time zone on the Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
Copy
sudo timedatectl set-timezone UTC
Note the following patterns are required for a minimal setup (see SUSE 15 SP3 Deployment Guide):
Copy
- Base System
- Minimal System (Appliances)
- YaST configuration packages
MongoDB
Installing MongoDB on SUSE should follow the tutorial for SUSE from the MongoDB documentation.
  1. Import the MongoDB public key.
    Copy
    sudo rpm --import https://pgp.mongodb.com/server-8.0.asc
  2. Add the MongoDB repository.
    Copy
    sudo zypper addrepo --gpgcheck "https://repo.mongodb.org/zypper/suse/15/mongodb-org/8.0/x86_64/" mongodb
  3. Install the MongoDB packages.
    Copy
    sudo zypper -n install mongodb-org
  4. Then, start the MongoDB instance.
    Copy
    sudo systemctl daemon-reload
    sudo systemctl start mongod.service
  5. In order to automatically start MongoDB on system boot, you have to activate the MongoDB service by running the following command:
    Copy
    sudo systemctl enable mongod.service
  6. Hold the currently installed version of the MongoDB package to prevent it from being automatically upgraded to a newer version when updates are installed.
    Copy
    sudo zypper addlock mongodb-org
    When you want to upgrade the package, be sure to remove the hold:
    Copy
    sudo zypper removelock <package-name>
    In the above code line, replace <package-name> with the correct package name.
OpenSearch
Hint: The remainder of this guide assumes that you wish to use Graylog with a self-managed OpenSearch deployment. Should you prefer to enable the Graylog Data Node, which is designed to configure and optimize OpenSearch for use with Graylog, please proceed now to Install Graylog Data Node.
The following installation steps assume you are using Zypper as your package manager with SUSE.
1. You may prefer to disable transparent huge pages to improve performance before installing.
Copy
sudo su
cat > /etc/systemd/system/disable-transparent-huge-pages.service <<EOF
Description=Disable Transparent Huge Pages (THP)
DefaultDependencies=no
After=sysinit.target local-fs.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'echo never | tee /sys/kernel/mm/transparent_hugepage/enabled > /dev/null'
[Install]
WantedBy=basic.target
EOF
sudo systemctl enable disable-transparent-huge-pages.service
sudo systemctl start disable-transparent-huge-pages.service
2. Install the OpenSearch GPG key.
Copy
sudo rpm --import https://artifacts.opensearch.org/publickeys/opensearch.pgp
3. From the CLI, you can install the package.
sudo curl -SL https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/opensearch-2.x.repo -o /etc/zypp/repos.d/opensearch-2.x.repo
sudo zypper update
sudo OPENSEARCH_INITIAL_ADMIN_PASSWORD=<custom-admin-password> zypper install -y opensearch=2.15.0
Hint: OpenSearch 2.12 and greater now requires setting the OPENSEARCH_INITIAL_ADMIN_PASSWORD environment variable when installing. The password must be a minimum of eight characters with at least one uppercase letter, one lowercase letter, one number, and one special character.
For example:
Copy
4. Edit the opensearch.yml file.
Copy
sudo nano /etc/opensearch/opensearch.yml
5. At a minimum the following changes are required (for a single instance install).
Copy
cluster.name:
path.data: /var/lib/opensearch
network.host: 0.0.0.0
discovery.type: single-node
6. After the installation succeeds, enable the OpenSearch service.
Copy
sudo systemctl enable opensearch.service
sudo systemctl start opensearch.service
7. Then, enable and start OpenSearch.
8. Hold the currently installed version of the OpenSearch package to prevent it from being automatically upgraded to a newer version when updates are installed.
Copy
sudo zypper addlock opensearch
Copy
9. Finally, verify that OpenSearch launched correctly.
Copy
sudo systemctl status opensearch
Graylog
1. First install the Graylog GPG key.
Copy
sudo wget https://downloads.graylog.org/repo/el/stable/GPG-KEY-graylog -O /etc/pki/GPG-KEY-graylog
2. Then add the repository file /etc/zypp/repos.d/graylog.repo with the following content.
Copy
[graylog]
name=graylog
baseurl=https://packages.graylog2.org/repo/el/stable/7.2/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/GPG-KEY-graylog
repo_gpgcheck=0
3. Refresh zypper repositories:
Copy
sudo zypper --gpg-auto-import-keys ref
4. After that, install the latest Graylog Open release with:
Copy
sudo zypper install graylog-server
If you are installing Graylog Enterprise, then you will use the following command.
Copy
sudo zypper install graylog-enterprise
5. Mark the package on-hold so that package updates do not accidentally upgrade the Graylog server.
For Graylog Open:
Copy
sudo zypper addlock graylog-server
For Graylog Enterprise:
Copy
sudo zypper addlock graylog-enterprise
Copy
Edit the Graylog Configuration File
1. Begin by opening the Graylog configuration file. Review the configuration file and edit as needed according to your preferences and environment.
Copy
sudo nano /etc/graylog/server/server.conf
Warning: Add password_secret and root_password_sha2 values to the configuration file as these are mandatory and Graylog will not start without them.
2. To create your password_secret, run the following command:
Copy
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
3. Use the following command to create your root_password_sha2:
Copy
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
4. To be able to connect to Graylog, set the http_bind_address value in the configuration file to the public host name or a public IP address for the machine to which you can connect. More information about these settings can be found in Configuring the Web Interface. Alternatively, you can also set this configuration using this command:
Copy
sudo sed -i 's/#http_bind_address = 127.0.0.1.*/http_bind_address = 0.0.0.0:9000/g' /etc/graylog/server/server.conf
Hint: If you’re operating a single-node setup and would like to use HTTPS for the Graylog web interface and the Graylog REST API, it’s possible to use NGINX or Apache as a reverse proxy.
5. Edit the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid OpenSearch nodes. A sample specification may look as follows:
Copy
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:9200
Warning: If this setting is not adjusted before start up, then you will NOT be able to log into Graylog using your previously configured root password!
6. The last step is to enable Graylog during the operating system’s startup:
Copy
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
sudo systemctl --type=service --state=active | grep graylog
Now you can ingest messages into Graylog!
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
Cluster Setup
If you plan to have multiple servers assuming different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our multi-node setup guide. The default file location guide lists the locations of the files you need to modify.
