Upgrade to Graylog 6.1
This article contains important information about your upgrade to Graylog 6.1 For more information on the upgrade process, see our complete guides to upgrading for the following supported systems and services:
Breaking Changes
API errors that are related to invalid requests (e.g. JSON parsing failures, invalid types, etc.) are now responded to with a type of
RequestErrorinstead ofAPIError. -
Removed GreyNoise Community Data Adapter deprecated in 5.2.
Default Configuration Changes
The
default_message_output_classsetting changed fromorg.graylog2.outputs.BlockingBatchedESOutputtoorg.graylog2.outputs.BatchedMessageFilterOutputas part of an internal refactoring. Regular users should not change the setting. -
The
output_batch_sizesetting can now be configured by providing a byte-based value, e.g.10 mb. For backward compatibility, the default value is still count-based (500). Previously configured count-based values are still supported. -
The legacy mode configuration setting of newly created Kafka based inputs has been changed to false. The default mode will now use the high level consumer API that has been available since Kafka 1.x.
Java API Changes
The following Java Code API changes have been made:
| File/Method | Description |
The class got removed. |
GreyNoiseCommunityIpLookupAdapter
REST API Endpoint Changes
The following REST API changes have been made:
| Enpoint | Description |
PUT /system/indices/index_set_defaults
This endpoint now expects an index set template id as payload. The values of the index set template are used as default values. |
GET licenses/{licenseId}
deprecated |
GET licenses |
deprecated |
GET licenses/status |
deprecated |
GET licenses/status/active |
(New) Show status for currently active license. |
GET licenses/validity/for-subject |
Check for valid license for given subject |
GET licenses/status/for-subject |
deprecated |
DELETE licenses/{licenseId} |
When called with a contract ID it will delete the contract and all associated licenses. |
Get the time series data for remaining provisioned traffic. |
Get the stats for consumed and remaining provisioned traffic. |
Get info about license traffic threshold warning. |
Acknowledge current traffic threshold warning. |
Delete any FAILED or PARTIAL snapshots for this index set. |
Deprecated Inputs
The following Enterprise Google inputs have been deprecated. Also, a new Enterprise Google Workspace input has been introduced, which supports retrieving many types of Workspace logs, including the logs from the deprecated inputs. Log parsing for the new Workspace input is expected to be delivered in a future Graylog Illuminate version.
Gmail Log Events
Google Workspace Log Events
