Red Hat Installation with Self-Managed OpenSearch
The following article contains information on deploying Graylog with self-managed OpenSearch. Please note that Graylog Data Node is the preferred method of data management. See Get Started with Data Node for more information.
This guide describes the fastest way to install Graylog on Red Hat Enterprise Linux 8 or 9. All links and packages are present at the time of writing.
These installation steps also include installation of OpenSearch so that you can manage your search backend manually.
Warning: This installation guide does not configure security settings. Before deploying Graylog to users or ingesting production data, secure all components in the Graylog stack. This includes restricting network access, preventing public internet exposure of internal services, enabling encryption, and configuring authentication and authorization. For detailed guidance, see Secure Your Graylog Environment and Network Connectivity and Firewall Requirements.
Prerequisites
Hint: This guide assumes that any firewall is disabled and traffic can flow across all necessary ports.
Graylog 7.2 requires the following to maintain compatibility with its software dependencies:
Graylog Version Minimum MongoDB Version Maximum MongoDB Version Minimum OpenSearch Version Maximum OpenSearch Version
7.2.x
7.x
8.2.x
1.1.x (or 2.0.x for Graylog Security) 3.7.x*
*OpenSearch 3.x is supported for new installations and for upgrades of existing self-managed deployments if there are no incompatible indices. Indices created under an OpenSearch version older than 2.0 are incompatible with OpenSearch 3.x.
Additionally, we recommend you review the version notes specific to your preferred version of Graylog for guidance on installing and configuring your Graylog instance.
Server Timezone
To set a specific time zone on the Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
Copy
sudo timedatectl set-timezone UTC
MongoDB
To install MongoDB on Red Hat, follow the tutorial for Red Hat from the MongoDB documentation.
  1. First, add the repository file /etc/yum.repos.d/mongodb-org.repo with the following contents.
    Copy
    [mongodb-org-8.0]
    name=MongoDB Repository
    baseurl=https://repo.mongodb.org/yum/redhat/9/mongodb-org/8.0/x86_64/
    gpgcheck=1
    enabled=1
    gpgkey=https://pgp.mongodb.com/server-8.0.asc
  2. After that, install the latest release of MongoDB.
    Copy
    sudo yum install -y mongodb-org
  3. Enable MongoDB during the operating system’s startup and verify it is running.
    Copy
    sudo systemctl daemon-reload
    sudo systemctl enable mongod
    sudo systemctl start mongod
    sudo systemctl status mongod
  4. Hold the currently installed version of the MongoDB package to prevent it from being automatically upgraded to a newer version when updates are installed.
    Copy
    sudo yum versionlock add mongodb-org
    When you want to upgrade the package, be sure to remove the hold:
    Copy
    sudo yum versionlock delete <package-name>
    In the above code line, replace <package-name> with the correct package name.
OpenSearch
Hint: The remainder of this guide assumes that you wish to use Graylog with a self-managed OpenSearch deployment. Should you prefer to enable the Graylog Data Node, which is designed to configure and optimize OpenSearch for use with Graylog, please proceed now to Install Graylog Data Node.
Refer to the OpenSearch install page for detailed instructions.
The installation example below utilizes the YUM repository for installation.
1. Create a local repository file for OpenSearch.
Copy
sudo curl -SL https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/opensearch-2.x.repo -o /etc/yum.repos.d/opensearch-2.x.repo
2. Disable the YUM GPG check for the OpenSearch software package repository.
Copy
sudo sed -i "s/^gpgcheck=.*/gpgcheck=0/g" /etc/yum.repos.d/opensearch-2.x.repo
3. Choose the version of OpenSearch you want to install. Unless otherwise indicated, the latest available version of OpenSearch is installed.
Hint: OpenSearch 2.12 and greater now requires setting the OPENSEARCH_INITIAL_ADMIN_PASSWORD environment variable when installing. The password must be a minimum of eight characters with at least one uppercase letter, one lowercase letter, one number, and one special character.
For example:
Copy
sudo OPENSEARCH_INITIAL_ADMIN_PASSWORD=<custom-admin-password> yum -y install opensearch
To install a specific version of OpenSearch, specify the version manually using opensearch=<version>.
Copy
sudo OPENSEARCH_INITIAL_ADMIN_PASSWORD=<custom-admin-password> yum -y install 'opensearch-2.15.0'
Warning: RHEL 9 may fail with a SHA-1 warning; please see the Red Hat documentation for guidance.
4. Hold the currently installed version of the OpenSearch package to prevent it from being automatically upgraded to a newer version when updates are installed.
Copy
sudo yum versionlock add opensearch.x86_64-2.13
Copy
Graylog Configuration for OpenSearch
1. Begin by opening the yml file.
Copy
sudo nano /etc/opensearch/opensearch.yml
2. Update the following fields for a minimum unsecured running state (single node).
Copy
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /var/lib/opensearch
discovery.type: single-node
network.host: 0.0.0.0
indices.query.bool.max_clause_count: 32768
3. Enable JVM options.
Copy
sudo nano /etc/opensearch/jvm.options
4. Now, update the Xms and Xmx settings with half of the installed system memory, like shown in the example below.
Copy
## JVM configuration
## IMPORTANT: JVM heap size
## You should always set the min and max JVM heap
## size to the same value. For example, to set
## the heap to 4 GB, set:
## -Xms4g
## -Xmx4g
## See https://opensearch.org/docs/opensearch/install/important-settings/
## for more information
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms1g
-Xmx1g
5. Configure the kernel parameters at runtime.
Copy
sudo sysctl -w vm.max_map_count=262144
echo 'vm.max_map_count=262144' | sudo tee -a /etc/sysctl.conf
6. Enable OpenSearch to start during operating system’s startup and verify it is running.
Copy
sudo systemctl enable opensearch
sudo systemctl start opensearch
sudo systemctl status opensearch
Graylog
1. Install the Graylog repository configuration and Graylog Open itself with the following commands:
Copy
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo yum install graylog-server
If you are installing Graylog Enterprise, then you will use the following commands:
Copy
sudo yum install graylog-enterprise
2. Mark the package on-hold so that package updates do not accidentally upgrade the Graylog server.
For Graylog Open:
Copy
sudo yum versionlock add graylog-server-7.2
For Graylog Enterprise:
Copy
sudo yum versionlock add graylog-enterprise-7.2
Copy
Edit the Graylog Configuration File
1. Begin by opening the Graylog configuration file. Review the configuration file and edit as needed according to your preferences and environment.
Copy
sudo nano /etc/graylog/server/server.conf
Warning: Add password_secret and root_password_sha2 values to the configuration file as these are mandatory and Graylog will not start without them.
2. To create your password_secret, run the following command:
Copy
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
3. Use the following command to create your root_password_sha2:
Copy
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
4. To be able to connect to Graylog, set the http_bind_address value in the configuration file to the public host name or a public IP address for the machine to which you can connect. More information about these settings can be found in Configuring the Web Interface. Alternatively, you can also set this configuration using this command:
Copy
sudo sed -i 's/#http_bind_address = 127.0.0.1.*/http_bind_address = 0.0.0.0:9000/g' /etc/graylog/server/server.conf
Hint: If you’re operating a single-node setup and would like to use HTTPS for the Graylog web interface and the Graylog REST API, it’s possible to use NGINX or Apache as a reverse proxy.
5. Edit the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid OpenSearch nodes. A sample specification may look as follows:
Copy
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:9200
Warning: If this setting is not adjusted before start up, then you will NOT be able to log into Graylog using your previously configured root password!
6. The last step is to enable Graylog during the operating system’s startup:
Copy
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
sudo systemctl --type=service --state=active | grep graylog
Now you can ingest messages into Graylog!
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
Cluster Setup
If you plan to have multiple servers assuming different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our multi-node setup guide. The default file location guide lists the locations of the files you need to modify.
SELinux Information
Hint: We assume that you have policycoreutils-python installed to manage SELinux.
If you’re using SELinux on your system, you must address the following settings:
  • Allow the web server to access the network: sudo setsebool -P httpd_can_network_connect 1.
  • If the policy above does not comply with your security policy, you can also allow access to each port individually:
    • Graylog REST API and web interface: sudo semanage port -a -t http_port_t -p tcp 9000.
    • Elasticsearch (only if the HTTP API is being used): sudo semanage port -a -t http_port_t -p tcp 9200.
  • Allow using MongoDB’s default port (27017/tcp): sudo semanage port -a -t mongod_port_t -p tcp 27017.
If you run a single-server environment with NGINX or Apache proxy, enabling the Graylog REST API is enough. All other rules are only required in a multi-node setup. Having SELinux disabled during installation and enabling it later requires you to manually check the policies for MongoDB, OpenSearch, Elasticsearch, and Graylog.
Depending on your actual setup and configuration, you might need to add more SELinux rules to get to a running setup.
