Debian Installation with Self-Managed OpenSearch
The following article contains information on deploying Graylog with self-managed OpenSearch. Please note that Graylog Data Node is the preferred method of data management. See Get Started with Data Node for more information.
This guide describes the recommended way to install Graylog on Debian Linux 12 (Bookworm). All links and packages are present at the time of writing.
These installation steps also include installation of OpenSearch so that you can manage your search backend manually.
Warning: This installation guide does not configure security settings. Before deploying Graylog to users or ingesting production data, secure all components in the Graylog stack. This includes restricting network access, preventing public internet exposure of internal services, enabling encryption, and configuring authentication and authorization. For detailed guidance, see Secure Your Graylog Environment and Network Connectivity and Firewall Requirements.
Prerequisites
Hint: This guide assumes that any firewall is disabled and traffic can flow across all necessary ports.
Graylog 7.2 requires the following to maintain compatibility with its software dependencies:
Graylog Version Minimum MongoDB Version Maximum MongoDB Version Minimum OpenSearch Version Maximum OpenSearch Version
7.2.x
7.x
8.2.x
1.1.x (or 2.0.x for Graylog Security) 3.7.x*
*OpenSearch 3.x is supported for new installations and for upgrades of existing self-managed deployments if there are no incompatible indices. Indices created under an OpenSearch version older than 2.0 are incompatible with OpenSearch 3.x.
Additionally, we recommend you review the version notes specific to your preferred version of Graylog for guidance on installing and configuring your Graylog instance.
Server Timezone
To set a specific time zone on the Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
Copy
sudo timedatectl set-timezone UTC
MongoDB
To install MongoDB on Debian, the official MongoDB documentation provides the most updated version and is the recommended way of installing MongoDB.
Follow the steps below to install MongoDB on Debian:
  1. Update repository package
    Copy
    sudo apt-get update
  2. Install the cryptographic libraries required for the repository keys.
    Copy
    sudo apt-get install gnupg curl
  3. Import the key:
    Copy
    curl -fsSL https://www.mongodb.org/static/pgp/server-8.0.asc | \
       sudo gpg -o /usr/share/keyrings/mongodb-server-8.0.gpg \
       --dearmor
  4. Add the Debian repo to the APT list:
    Copy
    echo "deb [signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg] https://repo.mongodb.org/apt/debian bookworm/mongodb-org/8.0 main" | sudo tee /etc/apt/sources.list.d/mongodb-org-8.0.list
  5. Update repository package.
    Copy
    sudo apt-get update
  6. Install the latest stable version of MongoDB.
    Copy
    sudo apt-get install -y mongodb-org
  7. Enable MongoDB during the operating system’s start up.
    Copy
    sudo systemctl daemon-reload
    sudo systemctl enable mongod.service
    sudo systemctl restart mongod.service
    sudo systemctl --type=service --state=active | grep mongod
  8. Hold the currently installed version of the MongoDB package to prevent it from being automatically upgraded to a newer version when updates are installed.
    Copy
    sudo apt-mark hold mongodb-org
  9. When you want to upgrade the package, be sure to remove the hold:
    Copy
    sudo apt-mark unhold <package-name>
In the above code line, replace <package-name> with the correct package name.
OpenSearch
Hint: The remainder of this guide assumes that you wish to use Graylog with a self-managed OpenSearch deployment. Should you prefer to enable the Graylog Data Node, which is designed to configure and optimize OpenSearch for use with Graylog, please proceed now to Install Graylog Data Node.
The recommended method of installation is to follow the user documentation provided by the OpenSearch service.
1. Install the necessary packages.
Copy
sudo apt-get update && sudo apt-get -y install lsb-release ca-certificates curl gnupg2
2. Import the public GPG key. This key is used to verify that the APT repository is signed.
Copy
curl -o- https://artifacts.opensearch.org/publickeys/opensearch.pgp | sudo gpg --dearmor --batch --yes -o /usr/share/keyrings/opensearch-keyring
3. Create an APT repository for OpenSearch.
Copy
echo "deb [signed-by=/usr/share/keyrings/opensearch-keyring] https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable main" | sudo tee /etc/apt/sources.list.d/opensearch-2.x.list
4. Verify that the repository was created successfully.
Copy
sudo apt-get update
5. With the repository information added, list all available versions of OpenSearch:
Copy
sudo apt list -a opensearch
6. Choose the version of OpenSearch you want to install. Unless otherwise indicated, the latest available version of OpenSearch is installed.
Hint: OpenSearch 2.12 and greater now requires setting the OPENSEARCH_INITIAL_ADMIN_PASSWORD environment variable when installing. The password must be a minimum of eight characters with at least one uppercase letter, one lowercase letter, one number, and one special character.
For example:
Copy
sudo OPENSEARCH_INITIAL_ADMIN_PASSWORD=<custom-admin-password> apt-get -y install opensearch
To install a specific version of OpenSearch, specify the version manually using opensearch=<version>.
Copy
sudo OPENSEARCH_INITIAL_ADMIN_PASSWORD=<custom-admin-password> apt-get -y install opensearch=2.15.0
7. Hold the currently installed version of the OpenSearch package to prevent it from being automatically upgraded to a newer version when updates are installed.
Copy
sudo apt-mark hold opensearch
Copy
Graylog Configuration for OpenSearch
1. Begin by opening the yml file.
Copy
sudo nano /etc/opensearch/opensearch.yml
2. Update the following fields for a minimum unsecured running state (single node).
Copy
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /var/lib/opensearch
discovery.type: single-node
network.host: 0.0.0.0
3. Enable JVM options.
Copy
sudo nano /etc/opensearch/jvm.options
4. Now, update the Xms and Xmx settings with half of the installed system memory, like shown in the example below.
Copy
## JVM configuration
## IMPORTANT: JVM heap size
## You should always set the min and max JVM heap
## size to the same value. For example, to set
## the heap to 4 GB, set:
## -Xms4g
## -Xmx4g
## See https://opensearch.org/docs/opensearch/install/important-settings/
## for more information
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms1g
-Xmx1g
5. Configure the kernel parameters at runtime.
Copy
sudo sysctl -w vm.max_map_count=262144
sudo echo 'vm.max_map_count=262144' >> /etc/sysctl.conf
6. Finally, enable the system service.
Copy
sudo systemctl enable opensearch.service
sudo systemctl start opensearch.service
Graylog
1. Install the Graylog repository configuration and Graylog Open itself with the following commands.
Copy
wget https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.deb
sudo dpkg -i graylog-7.2-repository_latest.deb
sudo apt-get update
sudo apt-get install graylog-server
If you are installing Graylog Enterprise, then you will use the following commands.
Copy
sudo apt-get update
sudo apt-get install graylog-enterprise
2. Mark the package on-hold so that package updates do not accidentally upgrade the Graylog server.
For Graylog Open:
Copy
sudo apt-mark hold graylog-server
For Graylog Enterprise:
Copy
sudo apt-mark hold graylog-enterprise
Copy
Edit the Graylog Configuration File
1. Begin by opening the Graylog configuration file. Review the configuration file and edit as needed according to your preferences and environment.
Copy
sudo nano /etc/graylog/server/server.conf
Warning: Add password_secret and root_password_sha2 values to the configuration file as these are mandatory and Graylog will not start without them.
2. To create your password_secret, run the following command:
Copy
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
3. Use the following command to create your root_password_sha2:
Copy
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
4. To be able to connect to Graylog, set the http_bind_address value in the configuration file to the public host name or a public IP address for the machine to which you can connect. More information about these settings can be found in Configuring the Web Interface. Alternatively, you can also set this configuration using this command:
Copy
sudo sed -i 's/#http_bind_address = 127.0.0.1.*/http_bind_address = 0.0.0.0:9000/g' /etc/graylog/server/server.conf
Hint: If you’re operating a single-node setup and would like to use HTTPS for the Graylog web interface and the Graylog REST API, it’s possible to use NGINX or Apache as a reverse proxy.
5. Edit the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid OpenSearch nodes. A sample specification may look as follows:
Copy
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:9200
Warning: If this setting is not adjusted before start up, then you will NOT be able to log into Graylog using your previously configured root password!
6. The last step is to enable Graylog during the operating system’s startup:
Copy
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
sudo systemctl --type=service --state=active | grep graylog
Now you can ingest messages into Graylog!
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
Cluster Setup
If you plan to have multiple servers assuming different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our multi-node setup guide. The default file location guide lists the locations of the files you need to modify.
