Asset Events
Asset events are triggered when asset risk levels exceed defined thresholds. They monitor the normalized risk scores of assets and triggers an event if a score rises above the configured risk score threshold. Asset events are created using the standard event definition workflow and support scheduling, filtering, and alerting like other event types in Graylog.
Prerequisites
You must have a valid Graylog Security license.
Assets are imported and defined in Graylog. See Asset Enrichment for more information.
Configuration Options
The Asset Events condition type includes the following configuration options:
Risk Score Threshold |
Specifies the value that triggers an event when an asset’s normalized risk score exceeds it. |
Asset Categories |
Defines the functional classification of an asset. For example, server, workstation, network device. Categories are used to group assets and enable targeted detections, filtering, and analysis based on asset type. |
Asset Priorities |
Indicates the relative importance or criticality of an asset within your environment. This value is used in risk scoring and helps prioritize alerts, anomalies, and vulnerabilities associated with assets. |
Skip Events on First Run (Checkbox) |
When enabled, this option stops events from being created the first time the system runs, even if some assets are already above the risk threshold. This setting only applies during the initial run to avoid generating alerts for existing conditions. |
Automatically Create Investigation (Checkbox) |
Creates a dedicated investigation for each asset that exceeds the defined risk threshold and automatically adds related events to that investigation as they occur. |
Use Cron Scheduling |
Enables custom scheduling using a cron expression. |
Execute search every |
Sets how frequently the condition runs to evaluate asset risk scores. |
Enable (Checkbox) |
Select this option to execute this event definition automatically. |
Asset Preview |
Displays a real-time preview of assets that match the selected criteria, including categories, priorities, and risk threshold, allowing you to validate which assets will be evaluated by the event definition. |
During each event execution, Graylog evaluates all assets to identify those with a normalized risk score above the configured threshold. An event is created only if:
The asset exceeds the threshold.
The asset has not already triggered an event from this definition.
All non-empty fields from the asset are included in the generated event.
If an asset’s risk score exceeds the threshold, an event is triggered; no further events occur unless the score first drops below the threshold and then exceeds it again. For example, an asset's risk score rises to 85 (above 80 which is the configured threshold) an event is triggered. If it stays above 80, no new events are generated. If the score later drops to 75 and then rises to 82, a new event is triggered.
Example Use Case: Alerting on High-Risk Assets
In this scenario, you want to proactively alert your security team whenever an asset's normalized risk score exceeds 80, indicating potentially suspicious or risky behavior.
The objective of this event definition is to automatically detect assets with elevated risk scores and generate a single alert for each qualifying asset to prompt investigation and reduce the risk of alert fatigue.
Create Event Definition
Create a new Event Definition under Alerts > Events > Event Definitions.
The configuration wizard begins with the Event Details screen. Set the event title, priority, and description. You can also add an event procedure to provide curated guidance to team members on how to approach alerts on high-risk assets.
On the Event Condition configuration screen, select Asset Events as the Condition Type.
Configure the following fields:
Risk Score Threshold: 80
This option sets the trigger point for creating an event when an asset’s normalized risk score exceeds 80.
Skip Events on First Run: Enabled
This setting prevents alerts from being generated during the initial run for assets that are already over the threshold, avoiding immediate noise from existing high-risk assets.
Use Cron Scheduling: Disabled
In this case, you rely on a simple interval-based execution.
Execute search every: 5 minutes
Graylog evaluates asset risk scores every 5 minutes, ensuring timely detection of changes.
Proceed to the Fields and Notifications steps to add custom fields and configure how alerts are delivered when this event is triggered.
Monitor Event
Once active, the event definition continuously monitors asset risk scores and triggers an event whenever a score exceeds the configured threshold. Each event includes relevant asset fields such as hostname, IP address, user, and associated tags.
The generated event also fires an alert according to your notification settings and can be routed to your team through a configured channel (e.g. Slack or email). Upon receiving the alert, you can begin triaging the event using the included asset context.
Further Reading
