Cluster Configuration
The Cluster Configuration page provides a centralized, real-time view of all nodes in your deployment, offering critical insight into roles, processing states, and load balancer status. This visibility helps administrators monitor system health, troubleshoot performance issues, and make informed decisions during scaling or maintenance.
This topic describes the metrics available for different node types as well as the node management activities administrators can perform here.
Prerequisites
  • You must be a Graylog administrator or a user with the Cluster Configuration Reader role to access the Cluster Configuration page.
Node Management
Navigate to the Cluster Configuration page at System > Cluster Configuration. This page shows all the nodes in your deployment, with each node type shown in a separate table that displays key metrics specific to the node:
Use the Columns dropdown at the upper-left of each table to customize which metrics appear. You can drag columns to reorder as you like. Note that some columns have a small arrow beside the title to indicate you can sort by these metrics (ascending/descending).
Some metrics in the tables have pre-set warning and caution thresholds. When a warning is exceeded, the metric displays with a red banner to indicate a potential constraint. When a caution level is exceeded, the metric displays with a yellow banner. The metrics that include this feature are statuses, CPU usage, and memory and storage usage.
Just above the tables, you can use the search field to locate specific nodes, or select the toggles to view only a single type of node. These features are particularly useful to focus your view if you have many nodes in your environment.
See the sections below for specific metrics and actions available for each node type.
Graylog Nodes
Specific node metrics are also available from the Actions menu, including viewing all inputs running on the node, a thread dump of all active threads or process buffers, and recent system logs.
The Graylog Nodes table on the Cluster Configuration page displays information about each Graylog node, including node roles, processing state, load balancer status, Graylog version, memory usage, and processing metrics. Use the Columns dropdown to add or remove columns from the table. Note that not all information is displayed by default.
From the More menu for each node, administrators can pause message processing or change the node’s load balancer status to DEAD. When a node is marked DEAD, the load balancer does not send log messages to that Graylog node.
Hint: When you pause message processing, the process buffers stop accepting new messages. If the message journal is enabled on the node (which is the default setting), Graylog continues to persist incoming messages to disk. Therefore, no data is lost and processing can safely resume when the node is re-enabled.
Select a node from the Node column to open the node detail page. This page displays detailed status and performance information, including JVM resource usage, message throughput, real-time disk journal utilization, and installed components and inputs lists.
Additional diagnostic options are available from the Actions menu, including loading a thread dump or process-buffer dump and viewing extensive internal metrics for monitoring and debugging.
Data Nodes
The Data Nodes table on the Cluster Configuration page displays node roles and node status for each Data Node. This section also shows the version of Graylog each node is running along with CPU, memory, and storage statistics. As with other tables, you can customize the displayed metrics from the Columns dropdown.
From the More menu, administrators can renew Data Node certificates, stop or remove nodes, and display recent system logs.
Data Node Management
At the top of the Cluster Configuration page, you can navigate to additional tabs for Data Node management, including:
  • Certificate Management: From here, you can issue or renew certificates for all Data Nodes in your cluster. See Manage Certificates with Data Node for more information.
  • Data Node Dashboard: This page displays additional performance metrics for each Data Node.
  • Data Node Upgrade: Navigate to this page for guidance on upgrading your Data Nodes. See Upgrade Graylog for more information on this process. To upgrade the embedded OpenSearch version, see Upgrade to OpenSearch 3.x with Data Node.
Hint: If you have not yet migrated to Data Node as your search backend, note that the only tab visible will be Data Node Migration. See Data Node Migration for more information on this process.
MongoDB Nodes
The MongoDB Nodes table on the Cluster Configuration page displays node roles and the current MongoDB version of the node along with performance metrics. By default, Profiling Level is set to Off. Select Enable Profiling above the table to receive additional data to identify slow queries and troubleshoot performance issues across cluster nodes.
Hint: Using profiling can cause reduced performance of your clusters. We recommend you leave profiling disabled when not in use.
Roles and Permissions for MongoDB Access
You must have appropriate permissions to view information about the MongoDB nodes. Permissions must be set both within Graylog and within MongoDB.
In Graylog, you must be assigned the following permissions:
  • mongodb_nodes:read: Allows user to view MongoDB node information. This permission is included in the Reader role, so most users should receive this permission by default. Remember, as stated in Prerequisites, users must also have the Cluster Configuration Reader role to access the Cluster Configuration page, which is not included in the Reader role.
  • mongodb_nodes:changeprofiling: Required to enable or disable MongoDB profiling. This permission is included in the Admin role by default.
To update roles in Graylog, navigate to System > Roles.
In addition, if you have configured MongoDB password authentication, the MongoDB user that Graylog connects with must have the correct permissions.
On each MongoDB instance, the graylog user must be assigned the following roles:
  • clusterMonitor: Allows the user to read the node stats.
  • dbAdmin: Allows the user to change profiling on all MongoDB nodes.
These roles are in addition to the readWrite role that Graylog requires to start and operate. To create the graylog user or grant it these roles, see Configure Graylog to Use MongoDB Password Authentication.
Further Reading
