Manage Certificates with Data Node
When you install Graylog with Data Node, or when you migrate existing indices to Data Node architecture, you are prompted during the preflight login to create a certificate authority (CA) so that Graylog can secure your data in OpenSearch. The Data Node section of the web interface lets you manage existing certificates and issue new ones.
Hint: You can also choose to upload your own CA and certificates as well. If you choose this option, you can still use the Data Node web interface to manage certificate policy and certificate renewals. If you are unable to upload a CA, you must configure certificates for Data Node in the Data Node configuration file and manage them externally.
To manage certificates through Graylog, navigate to the Certificate Management page via System > Cluster Configuration and select the Configuration tab.
Manage Certificates
The Configuration tab shows the current policy established for certificates, which is typically set when you create the CA. The Renewal Mode shows whether expired certificates renew automatically or must be manually renewed. The Certificate Lifetime shows the default length of validity of newly created certificates.
Edit Certificate Policy
To update the certificate policy:
  1. Click Edit configuration.
  2. Select the Certificate Renewal Mode:
    • Automatic: (Default) Renews all expiring certificates without user interaction.
    • Manual: Creates a system notification when one or more certificates are about to expire. You must manually renew certificates.
  3. Set the Certificate Lifetime. This value determines the length of the validity of newly created certificates. The default value is 30 days.
  4. Click Update configuration.
Renew Certificates
If you select Automatic as your renewal policy, certificates renew automatically before expiration. You do not need to take any additional action to ensure certificates are renewed as required.
For Manual renewal, navigate to the Data Nodes tab, then select Renew certificate from the More menu for the chosen node. The certificate is renewed for the length of time established in the Renewal Policy.
Create Certificates for Third-Party Tools
If you have third-party tools that require access to OpenSearch within the Data Node (for instance, via HTTPS), you need to generate a client certificate.
Hint: Certificates generated using this menu expire based on the renewal policy configured for Data Node. This value defaults to 30 days. However, you can override the policy for a given certificate by setting a different value for Certificate Lifetime. Any certificate generated needs to be replaced when it expires.
  1. Navigate to System > Cluster Configuration, then select the Configuration tab.
  2. Select Generate Client Certificate.
  3. Complete the following fields:
    Principal
    Enter the fully qualified domain name (FQDN) of the server to connect to. This value is the hostname of the Data Node server you want to query. For example, if the hostname of the client is server123, and its domain is network.local, its FQDN is server123.network.local.
    Role
    Enter the required OpenSearch roles. Defaults to all_access, which is what is required in most cases. See users and roles for a list of predefined roles.
    Unencrypted
    Select this option if you need to generate an unencrypted client key. Using this option disables the Password field.
    Password
    Enter the password to use to encrypt the client key.
    Enter a value to determines the length of the validity of newly created certificates. The default value is 30 days.
  4. Click Create Certificate.
  5. Save the certificates into separate files with the following naming conventions:
    • Private Key: client-cert.key
    • Certificate: client-cert.crt
Use Third-Party Tools
After your client certificate is issued, you can use third-party tools such as curl or Grafana to query OpenSearch's API.
Query via Curl
If you choose to use a command-line tool such as curl, save the private key and certificate text files and name them as above. You can run this command from your terminal:
Copy
curl "https://hostname.domain.tld:9200/_cluster/health?pretty" -k --cert client-cert.crt --key client-cert.key
Query via Grafana
If you choose to use Grafana, you can copy and paste the certificates into the relevant boxes.
Warning: Grafana version 9.0.0 or higher is required along with the grafana-opensearch-datasource plugin.
We encourage you to read the Grafana documentation for full instructions on using Grafana with OpenSearch. Note the following significant steps in the configuration process as follows:
  • Add OpenSearch as a new data source.
  • Specify the URL using HTTPS, such as https://hostname.domain.tld:9200.
  • After pasting the certificate files into their relevant Grafana boxes, you might need to correct the certificate formats so that -END CERTIFICATE and -END RSA PRIVATE KEY are on new lines. This change must be applied to the CA, client certificate, and client key.
