Modern server architectures and configurations are managed in many different ways. Some people still put new software somewhere in opt manually for each server while others have already jumped on the configuration management train and fully automated reproducible setups.
Graylog can be installed in many different ways, allowing you to pick whatever works best for you.
This section describes a few ways to install Graylog and aims to help you choose the one that best fits your needs.
Choose an Installation Method
System Requirements
Warning: We caution you not to install or upgrade Elasticsearch to 7.11 or later! It is not supported. Doing so will break your instance!
The Graylog server application is compatible with the following operating systems:
  • Debian 10 and 11
  • Ubuntu 20.04 and 22.04
  • Red Hat Enterprise Linux 7-9 and compatible (AlmaLinux, Rocky Linux, etc.)
  • SUSE Linux Enterprise Server 13, 15
Also required is one of the following databases:
WarningGraylog 5.2 is the last version to include support for Elasticsearch (7.10.2 only)! We recommend you use OpenSearch 2.x as your data node to support Graylog 5.2.
Compatibility Matrix
Please verify the version compatibility of your Graylog version with its dependent software requirements:
