This guide describes the fastest way to install Graylog on Red Hat Enterprise Linux 7-9. All links and packages are present at the time of writing.
Prerequisites
Graylog 5.2 requires the following to maintain compatibility with its software dependencies:
- OpenJDK 17 (This is embedded in Graylog and does not need to be separately installed.)
- OpenSearch 1.x, 2.x (or Elasticsearch 7.10.2)
- MongoDB 5.x or 6.x
- Review the version notes specific to your preferred version of Graylog for additional guidance on installing and configuring your Graylog instance.
MongoDB
To install MongoDB on Red Hat follow the tutorial for Red Hat from the MongoDB documentation. Graylog 5.2 is compatible with MongoDB 5.x-6.x.
1. First, add the repository file /etc/yum.repos.d/mongodb-org.repo
with the following contents:
[mongodb-org-6.0]
name=MongoDB Repository
baseurl=https://repo.mongodb.org/yum/redhat/$releasever/mongodb-org/6.0/x86_64/
gpgcheck=1
enabled=1
gpgkey=https://www.mongodb.org/static/pgp/server-6.0.asc
2. After that, install the latest release of MongoDB.
sudo yum install -y mongodb-org
3. Enable MongoDB during the operating system’s startup and verify it is running.
sudo systemctl daemon-reload
sudo systemctl enable mongod
sudo systemctl start mongod
sudo systemctl status mongod
OpenSearch
If you are using OpenSearch as your data node, then follow the steps below to install OpenSearch.
The following example installation installs via YUM repository.
1. Create a local repository file for OpenSearch.
sudo curl -SL https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/opensearch-2.x.repo -o /etc/yum.repos.d/opensearch-2.x.repo
2. Install OpenSearch.
sudo yum install -y opensearch
3. Update the following fields for a minimum unsecured running state in the configuration file located at /etc/opensearch/opensearch.yml
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /var/lib/opensearch
discovery.type: single-node
network.host: 0.0.0.0
4. Edit /etc/opensearch/jvm.options
both Xms
and Xmx
to half system memory.
5. For RHEL 9, update /usr/lib/tmpfiles.d/opensearch.conf
and change /var/run/opensearch
to /run/opensearch
6. Configure the kernel parameters at runtime.
sudo sysctl -w vm.max_map_count=262144
sudo echo 'vm.max_map_count=262144' >> /etc/sysctl.conf
7. Enable OpenSearch during operating system’s startup and verify it is running.
sudo systemctl enable opensearch
sudo systemctl start opensearch
sudo systemctl status opensearch
Elasticsearch
Elasticsearch 7.10.2 is the only version that is compatible with Graylog 5.2; however, we recommend OpenSearch for new Graylog cluster installations.
The following commands will begin the installation of the open-source version of Elasticsearch. See the Elasticsearch install page for more detailed instructions.
1. First, install the Elasticsearch GPG key.
rpm --import https://artifacts.elastic.co/GPG-KEY-elasticsearch
2. Then add the repository file /etc/yum.repos.d/elasticsearch.repo
with the following contents.
sudo rpm --import https://artifacts.elastic.co/GPG-KEY-elasticsearch
echo "[elasticsearch-7.10.2]
name=Elasticsearch repository for 7.10.2 packages
baseurl=https://artifacts.elastic.co/packages/oss-7.x/yum
gpgcheck=1
gpgkey=https://artifacts.elastic.co/GPG-KEY-elasticsearch
enabled=1
autorefresh=1
type=rpm-md" | sudo tee /etc/yum.repos.d/elasticsearch.repo
sudo yum install elasticsearch-oss
3. Install the 7.10.2 release with.
sudo rpm install elasticsearch-oss
4. Modify the Elasticsearch configuration file (/etc/elasticsearch/elasticsearch.yml
), set the cluster name to graylog
, and uncomment action.auto_create_index: false
to enable the action.
echo "cluster.name: graylog
action.auto_create_index: false" | sudo tee /etc/elasticsearch/elasticsearch.yml
5. After you have modified the configuration, you can start Elasticsearch.
sudo systemctl enable elasticsearch.service
sudo systemctl restart elasticsearch.service
sudo systemctl --type=service --state=active | grep el
Graylog
Now install the Graylog repository configuration and Graylog Open itself with the following commands:
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-5.2-repository_latest.rpm
sudo yum install graylog-server
If you are installing Graylog Operations, then you will use the following commands:
sudo yum install graylog-enterprise
Edit the Configuration File
Read the instructions within the configurations file and edit as needed, located at /etc/graylog/server/server.conf
. Additionally add password_secret
and root_password_sha2
as these are mandatory and Graylog will not start without them.
1. To create your password_secret
, run the following command.
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
2. To generate a root_password_sha2
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
3. To be able to connect to Graylog, you should set http_bind_address
to the public host name or a public IP address for the machine with which you can connect. More information about these settings can be found in Configuring the Web Interface.
4. It is necessary in Graylog 5.2 to manually adjust the elasticsearch_hosts
setting to include a list of comma-separated URIs to one or more valid Elasticsearch/OpenSearch nodes. A sample specification may look as follows:
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:19200
5. The last step is to enable Graylog during the operating system’s start up and verify it is running.
sudo systemctl enable graylog-server
sudo systemctl start graylog-server
sudo systemctl --type=service --state=active | grep graylog
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
SELinux Information
If you’re using SELinux on your system, you must address the following settings:
- Allow the web server to access the network:
sudo setsebool -P httpd_can_network_connect 1
. - If the policy above does not comply with your security policy, you can also allow access to each port individually:
- Graylog REST API and web interface:
sudo semanage port -a -t http_port_t -p tcp 9000
. - Elasticsearch (only if the HTTP API is being used):
sudo semanage port -a -t http_port_t -p tcp 9200
- Allow using MongoDB’s default port (27017/tcp):
sudo semanage port -a -t mongod_port_t -p tcp 27017
If you run a single-server environment with NGINX or Apache proxy, enabling the Graylog REST API is enough. All other rules are only required in a multi-node setup. Having SELinux disabled during installation and enabling it later requires you to manually check the policies for MongoDB, OpenSearch, Elasticsearch, and Graylog.
Depending on your actual setup and configuration, you might need to add more SELinux rules to get to a running setup.
Further Reading
- https://www.nginx.com/blog/nginx-se-linux-changes-upgrading-rhel-6-6/
- https://wiki.centos.org/HowTos/SELinux
- https://wiki.centos.org/TipsAndTricks/SelinuxBooleans
- https://www.serverlab.ca/tutorials/linux/administration-linux/troubleshooting-selinux-centos-red-hat/
- https://access.Red Hat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html/SELinux_Users_and_Administrators_Guide/
- https://www.digitalocean.com/community/tutorials/an-introduction-to-selinux-on-centos-7-part-1-basic-concepts
Multiple Server Setup
If you plan to have multiple server taking care of different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our Multi-Node Setup guide. The Default File Location guide will give you the file you need to modify in your setup.
