This guide describes the recommended way to install Graylog on SUSE Linux Enterprise Server 13 and 15. All links and packages are present at the time of writing.
Warning: This guide does not cover security settings! The server administrator must make sure the Graylog server is not publicly exposed and is following security best practices.
Prerequisites
Hint: This guide assumes that any firewall is disabled and traffic can flow across all necessary ports.
Graylog 5.2 requires the following to maintain compatibility with its software dependencies:
  • OpenJDK 17 (This is embedded in Graylog and does not need to be separately installed.)
  • OpenSearch 1.x, 2.x (or Elasticsearch 7.10.2)
  • MongoDB 5.x or 6.x
  • Review the version notes specific to your preferred version of Graylog for additional guidance on installing and configuring your Graylog instance.
Additionally, the following patterns are required for a minimal setup (see SUSE 15 SP3 Deployment Guide):
Copy
- Base System
- Minimal System (Appliances)
- YaST configuration packages
MongoDB
Installing MongoDB on SUSE should follow the tutorial for SUSE from the MongoDB documentation. Graylog 5.2 is compatible with MongoDB 5.x-6.x.
1. Import the MongoDB public key.
Copy
sudo rpm --import https://www.mongodb.org/static/pgp/server-6.0.asc
2. Add the MongoDB repository.
Copy
sudo zypper addrepo --gpgcheck "https://repo.mongodb.org/zypper/suse/15/mongodb-org/6.0/x86_64/" mongodb
3. Install the MongoDB packages.
Copy
sudo zypper -n install mongodb-org
4. Then, start the MongoDB instance.
Copy
sudo systemctl daemon-reload
sudo systemctl start mongod.service
5. In order to automatically start MongoDB on system boot, you have to activate the MongoDB service by running the following command:
Copy
sudo systemctl enable mongod.service
Hint: For the following sections on OpenSearch and Elasticsearch, select which data node you will be using for your Graylog instance and complete only the requisite section.
OpenSearch
If you are using OpenSearch as your data node, then follow the steps below to install OpenSearch.
Hint: These installation steps assume you are using Zypper as your package manager with SUSE.
1. You may prefer to disable transparent hugepages to improve performance before installing.
Copy
sudo su
cat > /etc/systemd/system/disable-transparent-huge-pages.service <<EOF
Description=Disable Transparent Huge Pages (THP)
DefaultDependencies=no
After=sysinit.target local-fs.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'echo never | tee /sys/kernel/mm/transparent_hugepage/enabled > /dev/null'
[Install]
WantedBy=basic.target
EOF
sudo systemctl enable disable-transparent-huge-pages.service
sudo systemctl start disable-transparent-huge-pages.service
2. Install the OpenSearch GPG key.
Copy
sudo rpm --import https://artifacts.opensearch.org/publickeys/opensearch.pgp
3. Download the OpenSearch 2.5 package.
Copy
wget https://artifacts.opensearch.org/releases/bundle/opensearch/2.5.0/opensearch-2.5.0-linux-x64.rpm
4. From the CLI, you can install the package.
sudo curl -SL https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/opensearch-2.x.repo -o /etc/zypp/repos.d/opensearch-2.x.repo
sudo zypper update
sudo zypper install opensearch
5. For rpm x64.
Copy
sudo rpm -ivh opensearch-2.5.0-linux-x64.rpm
6. Edit the opensearch.yml file.
Copy
sudo nano /etc/opensearch/opensearch.yml
7. At a minimum the following changes are required (for a single instance install).
Copy
cluster.name:
path.data: /var/lib/opensearch
network.host: 0.0.0.0
discovery.type: single-node
8. After the installation succeeds, enable the OpenSearch service.
Copy
sudo systemctl enable opensearch.service
sudo systemctl start opensearch.service
9. Then, enable and start OpenSearch.
10. Finally, verify that OpenSearch launched correctly.
Copy
sudo systemctl status opensearch
Elasticsearch
Elasticsearch 7.10.2 is the only version that is compatible with Graylog 5.2; however, we recommend OpenSearch for new Graylog cluster installations.
The following commands will begin the installation of the open-source version of Elasticsearch. See the Elasticsearch install page for more detailed instructions.
1. First install the Elasticsearch GPG key with.
Copy
rpm --import https://artifacts.elastic.co/GPG-KEY-elasticsearch
2. Then add the repository file /etc/zypp/repos.d/elasticsearch.repo with the following contents.
Copy
echo "[elasticsearch-7.10.2]
name=Elasticsearch repository for 7.10.2 packages
baseurl=https://artifacts.elastic.co/packages/oss-7.x/yum
gpgcheck=1
gpgkey=https://artifacts.elastic.co/GPG-KEY-elasticsearch
enabled=1
autorefresh=1
type=rpm-md" | sudo tee /etc/zypp/repos.d/elasticsearch.repo
3. Install the 7.10.2 release with.
Copy
sudo zypper install elasticsearch-oss
Graylog Configuration for Elasticsearch
1. Make sure to modify the Elasticsearch configuration file (/etc/elasticsearch/elasticsearch.yml), set the cluster name to graylog, and uncomment action.auto_create_index: false to enable the action.
Copy
sudo tee -a /etc/elasticsearch/elasticsearch.yml > /dev/null <<EOT
cluster.name: graylog
EOT
2. In order to automatically start Elasticsearch on system boot, you must activate the Elasticsearch service by running the following commands.
Copy
sudo systemctl enable elasticsearch.service
sudo systemctl start elasticsearch.service
Graylog
1. First install the Graylog GPG key with.
Copy
sudo wget https://downloads.graylog.org/repo/el/stable/GPG-KEY-graylog -O /etc/pki/GPG-KEY-graylog
2. Then add the repository file /etc/zypp/repos.d/graylog.repo with the following content.
Copy
[graylog]
name=graylog
baseurl=https://packages.graylog2.org/repo/el/stable/5.2/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/GPG-KEY-graylog
repo_gpgcheck=0
3. Refresh zypper repositories:
Copy
sudo zypper --gpg-auto-import-keys ref
4. After that, install the latest Graylog Open release with:
Copy
sudo zypper install graylog-server
If you are installing Graylog Operations, then you will use the following command.
Copy
sudo zypper install graylog-enterprise
Edit the Configuration File
Read the instructions within the configurations file and edit as needed, located at /etc/graylog/server/server.conf. Additionally add password_secret and root_password_sha2 as these are mandatory and Graylog will not start without them.
1. You can use the following command to create your password_secret:
Copy
cat /dev/urandom | base64 | cut -c1-96 | head -1
2. You will then need to use the following command to create your root_password_sha2:
Copy
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
3. To be able to connect to Graylog, you should set http_bind_address to the public host name or a public IP address for the machine with which you can connect. More information about these settings can be found in Configuring the Web Interface.
Hint: If you’re operating a single-node setup and would like to use HTTPS for the Graylog web interface and the Graylog REST API, it’s possible to use NGINX or Apache as a reverse proxy.
4. It is necessary in Graylog 5.2 to manually adjust the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid Elasticsearch/OpenSearch nodes. A sample specification may look as follows:
Copy
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:19200
Warning: If this setting is not adjusted before start up, then you will NOT be able to log into Graylog using your previously configured root password! For more information on this configuration setting, see Elasticsearch Configuration.
5. The last step is to enable Graylog during the operating system’s startup:
Copy
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
Now you can ingest messages into Graylog.
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
Cluster Setup
If you plan to have multiple servers assuming different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our multi-node setup guide. The default file location guide lists the locations of the files you need to modify.
