This guide describes the recommended way to install Graylog on Ubuntu 20.04 LTS and 22.04. All links and packages are present at the time of writing.
Warning: This guide does not cover security settings! The server administrator must make sure the Graylog server is not publicly exposed and is following security best practices.
Prerequisites
Hint: This guide assumes that any firewall is disabled and traffic can flow across all necessary ports.
Graylog 5.2 requires the following to maintain compatibility with its software dependencies:
  • OpenJDK 17 (This is embedded in Graylog and does not need to be separately installed.)
  • OpenSearch 1.x, 2.x or Elasticsearch 7.10.2
  • MongoDB 5.x or 6.x
  • Review the version notes specific to your preferred version of Graylog for additional guidance on installing and configuring your Graylog instance.
Server Timezone
To set a specific time zone on the Graylog server, you can use the following command. (For more information on setting a time zone, we recommend this blog post.)
Copy
sudo timedatectl set-timezone UTC
MongoDB
Graylog 5.2 is compatible with MongoDB 5.x-6.x.
To install MongoDB on Ubuntu, the official MongoDB documentation provides a helpful tutorial. The MongoDB documentation recommends you disable Transparent Huge Pages (THP).
1. First select your version of Ubuntu and begin the installation sequence:
2. You can use a keyserver approach via a widget if you wish to incorporate proxies and other non-free environments. For example:
Copy
wget -qO- 'http://keyserver.ubuntu.com/pks/lookup?op=get&search=0xf5679a222c647c87527c2f8cb00a0bd1e2c63c11' | sudo apt-key add -
3. Enable MongoDB during the operating system’s start up and verify it is running.
Copy
sudo systemctl daemon-reload
sudo systemctl enable mongod.service
sudo systemctl restart mongod.service
sudo systemctl --type=service --state=active | grep mongod
Hint: For the following sections on OpenSearch and Elasticsearch, select which data node you will be using for your Graylog instance and complete only the requisite section.
OpenSearch
If you are using OpenSearch as your data node, then follow the steps below to install OpenSearch.
The recommended method of installation is to follow the user documentation provided by the OpenSearch service. To set up the OpenSearch service with your Graylog instance, follow the steps below.
The following example will demonstrate installing OpenSearch using the DEB package.
1. Import the public GPG key. This key is used to verify that the APT repository is signed.
Copy
curl -o- https://artifacts.opensearch.org/publickeys/opensearch.pgp | sudo gpg --dearmor --batch --yes -o /usr/share/keyrings/opensearch-keyring
2. Create an APT repository for OpenSearch.
Copy
echo "deb [signed-by=/usr/share/keyrings/opensearch-keyring] https://artifacts.opensearch.org/releases/bundle/opensearch/2.x/apt stable main" | sudo tee /etc/apt/sources.list.d/opensearch-2.x.list
3. Verify that the repository was created successfully.
Copy
sudo apt-get update
4. With the repository information added, list all available versions of OpenSearch.
Copy
sudo apt list -a opensearch
5. Choose the version of OpenSearch you want to install. (Unless otherwise indicated, the latest available version of OpenSearch is installed.)
Copy
sudo apt-get install opensearch
To install a specific version of OpenSearch, specify the version manually using opensearch=<version>.
Copy
sudo apt-get install opensearch=2.5.0
Graylog Configuration for OpenSearch
1. Begin by opening the yml file.
Copy
sudo nano /etc/opensearch/opensearch.yml
2. Update the following fields for a minimum unsecured running state (single node).
Copy
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /var/lib/opensearch
discovery.type: single-node
network.host: 0.0.0.0
To create multi-node OpenSearch clusters, see the documentation.
3. Enable JVM options.
Copy
sudo nano /etc/opensearch/jvm.options
4. Now, update the Xms & Xmx settings with half of the installed system memory.
Copy
-Xms1g
-Xmx1g
5. Configure the kernel parameters at runtime.
Copy
sudo sysctl -w vm.max_map_count=262144
echo 'vm.max_map_count=262144' >> sudo /etc/sysctl.conf
6. Finally, enable the system service.
Copy
sudo systemctl enable opensearch.service
sudo systemctl start opensearch.service
sudo systemctl status opensearch.service
Elasticsearch
Elasticsearch 7.10.2 is the only version that is compatible with Graylog 5.2; however, we recommend OpenSearch for new Graylog cluster installations.
1. The following commands will begin the installation of the open-source version of Elasticsearch. See the Elasticsearch install page for more detailed instructions.
Copy
wget -q https://artifacts.elastic.co/GPG-KEY-elasticsearch -O myKey
sudo apt-key add myKey
echo "deb [signed-by=/usr/share/keyrings/elasticsearch-keyring"] https://artifacts.elastic.co/packages/7.x/apt stable main" | sudo tee /etc/apt/sources.list.d/elastic-7.x.list
sudo apt-get update && sudo apt-get install elasticsearch-oss
2. Modify the Elasticsearch configuration file (/etc/elasticsearch/elasticsearch.yml), set the cluster name to graylog, and uncomment action.auto_create_index: false to enable the action.
Copy
sudo tee -a /etc/elasticsearch/elasticsearch.yml > /dev/null <<EOT
EOT
3. After you have modified the configuration, you can start Elasticsearch and verify it is running.
Copy
sudo systemctl enable elasticsearch.service
sudo systemctl restart elasticsearch.service
sudo systemctl --type=service --state=active | grep elasticsearch
Graylog
Install the Graylog Open repository configuration and Graylog itself with the following commands:
Copy
wget https://packages.graylog2.org/repo/packages/graylog-5.2-repository_latest.deb
sudo dpkg -i graylog-5.2-repository_latest.deb
sudo apt-get update && sudo apt-get install graylog-server
If you are installing Graylog Operations, then you will use the following commands:
Copy
sudo apt-get update && sudo apt-get install graylog-enterprise
Edit the Configuration File
Read the instructions within the configurations file and edit as needed, located at /etc/graylog/server/server.conf. Additionally add password_secret and root_password_sha2 as these are mandatory and Graylog will not start without them.
1. To create your password_secret, run the following command:
Copy
< /dev/urandom tr -dc A-Z-a-z-0-9 | head -c${1:-96};echo;
2. You will then need to use the following command to create your root_password_sha2:
Copy
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
3. To be able to connect to Graylog, you should set http_bind_address to the public host name or a public IP address for the machine with which you can connect. More information about these settings can be found in Configuring the Web Interface.
Hint: If you’re operating a single-node setup and would like to use HTTPS for the Graylog web interface and the Graylog REST API, it’s possible to use NGINX or Apache as a reverse proxy.
4. It is necessary in Graylog 5.2 to manually adjust the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid Elasticsearch/OpenSearch nodes. A sample specification may look as follows:
Copy
elasticsearch_hosts = http://es-node-1.example.org:9200/foo,https://someuser:somepassword@es-node-2.example.org:19200
Warning: If this setting is not adjusted before start up, then you will NOT be able to log into Graylog using your previously configured root password! For more information on this configuration setting, see Elasticsearch Configuration.
5. The last step is to enable Graylog during the operating system’s startup:
Copy
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
sudo systemctl --type=service --state=active | grep graylog
Now you can ingest messages into Graylog.
Getting Started
Now that you have installed Graylog, you can review your initial configuration settings and connect to the web interface!
Cluster Setup
If you plan to have multiple servers assuming different roles in your cluster like we have in this big production setup you need to modify only a few settings. This is covered in our multi-node setup guide. The default file location guide lists the locations of the files you need to modify.
