Upgrade Graylog on SUSE
This guide describes the recommended way to upgrade Graylog on SUSE Linux Enterprise Server 15.
Prerequisites
You must be a Graylog administrator to perform a system upgrade.
Review the release notes for your target Graylog version to identify breaking changes and required configuration updates.
Back up data for all services before upgrading to enable rollback if needed. See Backup and Restore Best Practices for details.
Ensure all system components are compatible with your target Graylog version.
If you are upgrading MongoDB (or self-managed OpenSearch, if used as your search backend) do so before upgrading Graylog.
Software Verification
To verify your current version of Graylog or any of its dependencies before upgrading, use the following commands:
Graylog
sudo zypper search -i | grep graylog
Data Node
sudo zypper search -i | grep graylog-datanode
MongoDB
sudo zypper search -i | grep mongod
Upgrade with Self-Managed OpenSearch
This guide describes the upgrade process for Graylog environments using Graylog Data Node as a search backend. If you have deployed Graylog with self-managed OpenSearch, then you will only need to follow the process described in subsequent sections to upgrade the Graylog service.
If you wish to upgrade OpenSearch to a Graylog-supported version, you must do so before you upgrade Graylog. See the OpenSearch documentation for more information on upgrading OpenSearch.
Warning: Before you upgrade self-managed OpenSearch to 3.x, note the following: Upgrading is not supported if any of your indices were created under an OpenSearch version older than 2.0. The maximum supported version is OpenSearch 3.7.x. After the upgrade, you cannot return to your previous OpenSearch version. If your warm tier uses a Google Cloud Storage (GCS) backend, avoid OpenSearch 3.3 through 3.7. See Create a Warm Tier on Self-Managed OpenSearch. Check the compatibility matrix before you upgrade OpenSearch.
To verify your current version of OpenSearch before upgrading, run the following command:
sudo zypper search -i | grep opensearch
Upgrade Graylog
To ensure data consistency, all Graylog Server instances must be stopped before upgrading. Graylog releases may include database migrations, and running different Graylog versions within the same environment can lead to errors or inconsistent MongoDB data. For this reason, rolling upgrades of the Graylog service are not recommended.
To upgrade the Graylog service, follow the steps below.
Stop the Graylog service:
Copysudo systemctl stop graylog-server.serviceHint: In a multi-node cluster, stop Graylog on all nodes before upgrading packages. This ensures that database migrations run only after all nodes are offline. -
Monitor the status of the Graylog service to verify it has stopped:
Copyps -aefww | grep graylog -
Once the service has stopped, update the local package cache:
Copysudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-7.2-repository_latest.rpm
sudo zypper updateTo display all available versions of Graylog:
Graylog Open ▼
Copysudo zypper search -s graylog-server
Graylog Enterprise ▼
Copysudo zypper search -s graylog-enterprise
Graylog Security ▼
Copysudo zypper search -s graylog-enterprise -
If you have a lock on the Graylog package, you may then be prompted to remove it before allowing the upgrade to execute:
Copysudo zypper removelock graylog-server -
Upgrade the Graylog package:
Graylog Open ▼
Copysudo zypper install graylog-server-7.2
Copysudo zypper install graylog-enterprise-7.2
Graylog Security ▼
Copysudo zypper install graylog-enterprise-7.2 -
Verify that the updated Graylog packages have been installed:
Copyzypper se --installed-only graylog -
If the release notes for your target version indicate configuration changes are necessary, then make these changes in the
server.conffile. To open the file:Copysudo nano /etc/graylog/server/server.conf -
Start the Graylog service:
Copysudo systemctl start graylog-server.service
Upgrade Data Node
Graylog Data Node must be on the same version as your Graylog service. For example, if you have upgraded Graylog to 7.2, then you must also upgrade Data Node to the 7.2 release.
Rolling upgrades apply only to Data Node clusters of three or more nodes. If you have fewer than three Data Nodes, you must perform a restart upgrade, where you shut down all Data Nodes and stop the service during the upgrade process. To complete a rolling upgrade of three or more Data Node servers, follow the steps below.
Important: After you upgrade Data Node, Graylog notifies you that the embedded OpenSearch can be upgraded to 3.x. You start that upgrade from System > Cluster Configuration > Data Node Upgrade. However, indices created under an OpenSearch version older than 2.0 are not compatible with OpenSearch 3.x in Graylog. If you have incompatible indices, you must resolve them before you can upgrade OpenSearch. See Upgrade to OpenSearch 3.x with Data Node.
To begin the Data Node upgrade process, you must first log in to the Graylog interface and navigate to System > Cluster Configuration > Data Node Upgrade. Note that after upgrading Graylog, you will receive a warning on this page that there is a version mismatch between Graylog and your Data Nodes.
Select Rolling Upgrade.
Graylog will indicate the Data Node (by its hostname) that should be upgraded first, so for the first node listed, click Start Upgrade Process. This disables shard replication temporarily for the upgrade to proceed safely.
Hint: Unlike upgrading the Graylog service, upgrading the Data Node service requires that you start on a follower node first and finish with the leader node. The Graylog interface will indicate the correct upgrade order. -
Now, navigate to the physical Data Node host on which you are performing the upgrade and stop the Data Node service:
Copysudo systemctl stop graylog-datanode -
Monitor the status of the Data Node service to verify it has stopped:
Copyps -aefww | grep graylog-datanode -
sudo zypper updateTo display all available versions of Data Node:Copysudo zypper search -s graylog-datanode -
If you have a lock on the Graylog Data Node package, you may then be prompted to remove it before allowing the upgrade to execute:
Copysudo zypper removelock graylog-datanode -
Copysudo zypper install graylog-datanode-7.2 -
To verify that the updated Data Node packages have been installed:
If the release notes for your target version indicate configuration changes are necessary for Data Node, then make these changes in the
datanode.conffile. To open the file:Copysudo nano /etc/graylog/datanode/datanode.conf -
Start the Data Node service:
Copysudo systemctl start graylog-datanode -
Return to the Graylog interface and select Confirm Upgrade for the node indicated. This re-enables shard replication and signals Graylog that the node upgrade is complete.
Repeat all the previous steps for the remaining nodes, upgrading them one at a time in the order indicated by Graylog.
Incremental Upgrade
When upgrading across multiple Graylog versions (for example, from 5.x to 7.x), it is essential to perform the upgrade incrementally through every minor version and not just between major releases. Each Graylog version may include important database migrations, configuration updates, or compatibility changes that must be applied in order.
The recommended process is to upgrade one version at a time, following the full sequence of available releases until you reach the target version. Skipping versions may result in failed migrations or inconsistent system behavior.
Incremental Upgrade Path Example
For example, if you are upgrading from Graylog 5.2 to Graylog 7.2, you should follow this path:
Graylog 5.2 → 6.0 → 6.1 → 6.2 → 6.3 → 7.0 → 7.1
This ensures that all intermediate schema changes, configuration updates, and feature migrations are properly applied at each step.
