Manage Warm Tier Repositories
Before you can move data to the warm tier, you must first set up a storage repository. This article explains how to create, view, and manage credentials for warm tier repositories.
Hint: Snapshot Archiving also reads from these same repositories. See Archiving for more information.
Prerequisites
View Warm Tier Repositories
The Warm Tier Repositories tab at System > Indices is where you create and manage backend storage for warm tier. The tiles at the top provide useful information about system readiness as well as defined backends. If you have already configured backend storage, a table lists every repository, its type, location, and credential status.
If your cluster isn't ready for the warm tier yet or no backends have been defined, this page lists the remaining setup steps instead of showing the repository table.
Create a Repository
To create a repository:
  1. Select Create repository.
  2. Select a Warm Storage Repository Location. Ensure that the type you choose is configured in datanode.conf or your OpenSearch configuration on every search node, and that you restarted those nodes afterward.
Edit Repository Credentials
Credential management through this page is available only for Amazon S3, OVH Object Storage, and SysEleven Object Storage repositories. To edit credentials:
  1. Select More > Edit Credentials for the repository.
  2. Enter the access key and secret, or select automatic authentication.
  3. Select Save.
Important: Each repository needs its own credentials. Entering credentials for one S3-type repository does not apply them to any other.
For every other backend type, and for S3-type repositories used only by the warm tier, credentials still come from your OpenSearch or Data Node configuration.
Delete a Repository
To remove a repository you no longer need, select More > Delete for that repository. You must confirm this action in the dialog, and you cannot undo this action.
Further Reading
