Create a Warm Tier on Self-Managed OpenSearch
When you use Graylog Data Tiering, you set data storage retention policies when you create or update index sets. In fact, you can set different tier policies for each index set, based on the requirements of the data they contain. Establishing a retention policy with a warm tier lets you maintain less-frequently searched data in lower cost and lower performance storage. See Data Tiering for complete information.
If you intend to use data tiering with a warm tier, you first need to configure your backend storage. This article explains how to prepare your environment for a warm tier on a Graylog installation with self-managed OpenSearch, and also includes steps to follow to enable a warm tier for both new and existing index sets.
Hint: If you are using Graylog with Data Node, the requirements and procedures are different. See Create a Warm Tier on Data Node for information.
Prerequisites
You must be a Graylog administrator to set up a warm tier backend and enable a warm tier.
You must use Graylog with OpenSearch minimum version 2.12 and maximum version 3.7.x (check the Compatibility Matrix for additional restrictions). If your search backend cluster is not compatible with Data Tiering, Graylog displays a warning on the Indices and Index Sets page (System > Indices).
You must have appropriate credentials to configure your chosen storage backend.
Prepare Your Environment for a Warm Tier
Before you can enable a warm tier for your installation, you must set up a storage repository. We recommend that you use object storage from a supported third-party provider as your method of backend storage, but you can also choose to store this data in any supported file system repository.
The initial steps for enabling a repository are completed outside of the Graylog web interface and differ depending on the storage backend you choose:
Install the OpenSearch snapshot repository plugin on all OpenSearch nodes:
Copysudo ./bin/opensearch-plugin install repository-s3 -
Add your Amazon Web Services (AWS) access and secret keys to the OpenSearch keystore on all search nodes. See the OpenSearch documentation for instructions.
In the OpenSearch configuration file,
opensearch.yml, for all search nodes, specify the following keys:-
s3.client.default.region(required for OVH and SysEleven; optional for Amazon S3) -
s3.client.default.endpoint(required for OVH and SysEleven; optional for Amazon S3)
Update the OpenSearch configuration file on all search nodes as described in Configure the OpenSearch Configuration File.
Restart all search nodes for the changes to take effect.
Warning: GCS repositories do not work with OpenSearch versions 3.3 through 3.7. To use GCS for your warm tier, run a supported OpenSearch version earlier than 3.3, or migrate to Data Node.
Copysudo ./bin/opensearch-plugin install repository-gcs -
Add the service account key JSON file to the OpenSearch keystore on all search nodes. See Google documentation for information.
Follow the OpenSearch documentation for setting up and registering an Apache HDFS snapshot repository.
Copysudo ./bin/opensearch-plugin install repository-azure -
Set Azure Blob Storage credentials in OpenSearch. See the OpenSearch documentation for information.
As part of setup for a Data Tiering warm tier, you need to update or add configuration settings to the OpenSearch configuration file, opensearch.yml.
Hint: After you make any change to opensearch.yml, you must restart the node for the changes to take effect. If you update multiple nodes, be sure to update all nodes with changes!
Assign the Search Role
OpenSearch nodes used for the warm tier must have the search role to enable searchable snapshots. This role is named warm for OpenSearch 3.0 and later, and search before that. Assign the role that matches your OpenSearch version by adding the following line to opensearch.yml to each node used for warm tier data:
Use this role name if you're running OpenSearch 3.0 and later:
node.roles: [warm]
Use this role name if you're running a version before OpenSearch 3.0:
node.roles: [search]
If you are not sure whether your configuration file includes this role, you can use the _cat/nodes API endpoint:
curl "http://127.0.0.1:9200/_cat/nodes?v&h=ip,name,node.role,node.roles"
For example, a response might look like this:
ip name node.role node.roles
192.168.0.153 glwn s search
Modify the Node Cache Size for Searchable Snapshots
Verify that the node.search.cache.size parameter is included in opensearch.yml for each warm tier node. If not, you must add it to the file.
Set the value to 10gb:
node.search.cache.size: 10gb
The ideal cache size is as large as the node's local storage allows without filling that storage past 80%.
Monitoring the performance of your warm tier is critical to optimizing this value. See the section on monitoring your system performance for detail.
Add a File System Location
For file system repositories, you must at a minimum add a file system path to opensearch.yml using the path.repo property:
path.repo: ["/mnt/snapshots"]
You might need to complete additional configuration, depending on your operating system. Review the OpenSearch documentation for specific requirements.
After your environment is prepared, create a storage repository on the Warm Tier Repositories page (System > Indices > Warm Tier Repositories). See Manage Warm Tier Repositories for the steps for your backend type.
Set Up a Warm Tier
When your environment is ready for Data Tiering, you can enable the warm tier for both new and existing index sets.
Enable the Warm Tier for a New Index Set
You can select warm tier for a new index set when you create it. You can create a new index set based on built-in index set templates provided by Graylog or you can create custom templates for your environment.
For complete information about creating index sets and index set templates, including how to enable the warm tier, see Index Set Templates.
Enable the Warm Tier for an Existing Index Set
To choose warm tier storage for an existing index set, follow these steps:
Navigate to System >Indices.
Click Edit for the desired index set.
In the Rotation and Retention section, select Data Tiering.
Enter the minimum and maximum number of days you want your data to be stored.
Select the Enable warm tier checkbox, then enter the minimum number of days to keep your data in the hot tier. The visual synchronously displays how long your data will be kept in each tier as you make your selections.
Select the repository you want your data stored in from the Repository dropdown. The menu includes any repositories you have created through the Warm Tier Repositories page.
Click Update index set.
View Data Tiering Configuration
After you have created or updated your index set, you can view configuration information as follows:
Navigate to System > Indices
Select the desired index set to view the index set overview page.
Here you can see warm displayed in the index title after the index prefix.
You can perform searches in the warm tier, and you can verify that your search results include the warm tier by checking the Stored in index section. You will see warm in the index set title.
