Create a Warm Tier on Data Node
The following article exclusively pertains to a Graylog Enterprise feature or functionality. To learn more about obtaining an Enterprise license, please contact the Graylog Sales team.
When you use Graylog Data Tiering, you set data storage retention policies when you create or update index sets. In fact, you can set different tier policies for each index set, based on the requirements of the data they contain. Establishing a retention policy with a warm tier lets you maintain less-frequently searched data in lower cost and lower performance storage. See Data Tiering for complete information.
If you intend to use data tiering with a warm tier, you first need to configure your backend storage. This article explains how to prepare your environment for a warm tier on a Data Node installation, and also includes steps to follow to enable a warm tier for both new and existing index sets.
Hint: If you are using a self-managed OpenSearch installation, the requirements and procedures are different. See Create a Warm Tier on Self-Managed OpenSearch for information.
Prerequisites
  • You must be a Graylog administrator to set up a warm tier backend and enable a warm tier.
  • You must have appropriate credentials to configure your chosen storage backend.
Prepare Your Environment for a Warm Tier
Before you can enable a warm tier for your Data Node installation, you must set up a storage repository. We recommend that you locate your warm tier data in an S3 or GCS bucket, but you can also choose to store this data in any supported file system repository.
Data Node assigns the search role automatically to each node with a repository backend configured in datanode.conf. Each of those nodes reserves 10 GB for the warm tier cache by default. To change the cache size, set node_search_cache_size in datanode.conf. The ideal cache size is as large as the node's local storage allows without filling that storage past 80%.
The initial steps for enabling a repository are completed outside of the Graylog web interface and differ depending on the storage backend you choose:
After your environment is prepared, create a storage repository on the Warm Tier Repositories page (System > Indices > Warm Tier Repositories). See Manage Warm Tier Repositories for the steps for your backend type.
Set Up a Warm Tier
When your environment is ready for Data Tiering, you can enable the warm tier for both new and existing index sets.
Enable the Warm Tier for a New Index Set
You can select warm tier for a new index set when you create it. You can create a new index set based on built-in index set templates provided by Graylog or you can create custom templates for your environment.
For complete information about creating index sets and index set templates, including how to enable the warm tier, see Index Set Templates.
Enable the Warm Tier for an Existing Index Set
To choose warm tier storage for an existing index set, follow these steps:
  1. Navigate to System >Indices.
  2. Click Edit for the desired index set.
  3. In the Rotation and Retention section, select Data Tiering.
  4. Enter the minimum and maximum number of days you want your data to be stored.
  5. Select the Enable warm tier checkbox, then enter the minimum number of days to keep your data in the hot tier. The visual synchronously displays how long your data will be kept in each tier as you make your selections.
  6. Select the repository you want your data stored in from the Repository dropdown. The menu includes any repositories you have created through the Warm Tier Repositories page.
  7. Click Update index set.
View Data Tiering Configuration
After you have created or updated your index set, you can view configuration information as follows:
  1. Navigate to System > Indices
  2. Select the desired index set to view the index set overview page.
Here you can see warm displayed in the index title after the index prefix.
You can perform searches in the warm tier, and you can verify that your search results include the warm tier by checking the Stored in index section. You will see warm in the index set title.
Warning: If the warm tier is disabled, you still may be able to perform searches in the warm tier, but data no longer rolls over from the hot tier to the warm tier. This limitation can cause performance issues.
