Create a Data Lake Backend on Local Network Storage
Before you can start routing Graylog data to an internal Data Lake, you must first set up your backend storage. This article shows you how to set up a Data Lake storage backend in Graylog using local network storage.
You can also use Amazon Web Services (AWS), OVH Object Storage, SysEleven Object Storage, Google Cloud Storage (GCS), or Azure Blob Storage to set up your backend.
Prerequisites
You must be a Graylog administrator to set up and manage a Data Lake.
Important: Review your Data Lake journal settings before you create this backend, especially data_lake_journal_max_size and data_lake_journal_max_age. Adding or updating these values after your Data Lake is in use can require provisioning additional storage or partitions. See Data Lake Properties for the full list of configurable properties.
Create a Local Network Storage Backend
To create a local network storage backend for your Data Lake:
Navigate to Data Lake > Internal Lake Setup. If you have existing backends, select the Backend tab. Any existing storage backends are displayed here.
Select Create Data Lake Backend.
Select File system from the dropdown as the Backend Type.
Enter configuration details for your network storage backend:
Title
Enter a unique and descriptive name for the backend.
Description
Enter a description of the backend.
Disk Usage Threshold
Enter the percentage of disk utilization that should trigger a notification.
Output Base Path
Enter the base path where the archives should be stored.
Warning: This value can only be set on backend creation and cannot be changed at a later date! -
Click Create to complete configuration of the storage backend.
Click Activate to make this the active storage backend. You must activate the backend before it can be used for storage. You can have multiple backends defined, but only one can be active. See the warning below about data loss if you are switching from an existing storage backend.
If you need to update settings for the Data Lake, such as changing access credentials, click Edit. You are presented with the same options as on initial creation. As noted, you cannot change the output base path after your initial save, but you can update the other settings.
Change Your Storage Backend
To change your active storage backend:
Create a new storage backend or select one you have previously created.
Click Activate.
Graylog prompts you to confirm you want to change your storage backend. Graylog recommends you do not change your storage backend! All the data written to the previous storage backend must be deleted before you can switch.
Warning: Deleting Data Lake data requires you to first stop routing data to the Data Lake. Note that if the affected streams are routing only to the Data Lake, you risk losing new data until you complete the process and start routing again with the new storage backend. -
Click Confirm to proceed.
The storage backend has now been switched. As new logs arrive, they are routed to the newly activated Data Lake storage backend.
Delete Backend Data
Before you can switch a storage backend, you must delete any data in the old storage backend. It is recommended that you delete this data with the following steps:
Navigate to the Overview tab of Data Lake > Internal Lake Setup.
Disable the Data Lake for each stream that is routing data to this backend. Click Data Routing, then toggle the Data Lake to Disabled.
Delete the data from each stream.
Select More > Delete.
Select the Full Delete check box.
Click Delete.
Verify that the message count for all streams hits 0.
Further Reading
