Create a Data Lake Backend on Amazon S3
Before you can start routing Graylog data to an internal Data Lake, you must first set up your backend storage.
Warning: Amazon S3, OVH Object Storage, and SysEleven Object Storage are the only supported S3-compatible backend types for a Data Lake. Other S3-compatible storage services are not supported.
You can also use OVH Object Storage, SysEleven Object Storage, Google Cloud Services (GCS), Azure Blob Storage, or a local network storage to set up your backend.
Prerequisites
You must be a Graylog administrator to set up and manage a Data Lake.
To use Amazon S3, you must have an existing Amazon S3 bucket and appropriate access credentials.
Important: Review your Data Lake journal settings before you create this backend, especially data_lake_journal_max_size and data_lake_journal_max_age. Adding or updating these values after your Data Lake is in use can require provisioning additional storage or partitions. See Data Lake Properties for the full list of configurable properties.
Create an Amazon S3 Storage Backend
To create an S3 storage backend for your Data Lake:
Navigate to Data Lake > Internal Data Lake. If you have existing backends, select the Backend tab. Any existing storage backends are displayed here.
Select Create Data Lake Backend.
Select S3 from the dropdown as the Backend Type.
Complete configuration details for your S3 backend:
Title
Enter a unique and descriptive name for the backend.
Description
Enter a description of the backend.
S3 Endpoint URL
(optional)
Enter the URL of the S3 endpoint for the region that hosts your bucket (e.g.
s3.us-east-1.amazonaws.com). This value is required only if you want to override the default endpoint. Leave this field blank to use the appropriate S3 endpoint based on the selected region.Warning: Graylog does not support retrieval of data from the Glacier tier of AWS S3. For S3 backends, make sure the S3 bucket does not have lifecycle rules that move files into the Glacier tier.AWS Authentication Type
Select the authentication method for accessing Amazon S3. AWS recommends using role-based authentication with temporary credentials instead of long-term static access keys.
AWS Assume Role (ARN)
Enter the Amazon Resource Name (ARN) of the Identity and Access Management (IAM) role that Graylog will assume to access the S3 bucket. This method uses temporary credentials and is the preferred authentication approach. It also supports cross-account access.
AWS External ID
(optional)
Enter the external ID for the assume role, if your role's trust policy requires one. This value confirms that only your intended service can assume the role, which prevents the role from being assumed by an unauthorized party. This field only applies when you provide an Assume Role ARN.
S3 Bucket Name
Enter the name of the S3 bucket in which logs will be stored.
AWS Region
Select an AWS region, or type a custom region.
S3 Output Base Path
Enter the base path where the archives should be stored within the S3 bucket.
You can use a single bucket for multiple purposes. For instance, you could use the same bucket for a Data Lake backend and a warm tier snapshot backend. However, if you do, it is important to use different sub folders for each specific use. The base path you set here determines the sub folder structure for this backend.
Important: This value can only be set on backend creation and cannot be changed at a later date!
Click Create to complete configuration of the storage backend.
Click Activate to make this the active storage backend. You must activate the backend before it can be used for storage. You can have multiple backends defined, but only one can be active. See the warning below about data loss if you are switching from an existing storage backend.
If you need to update settings for the Data Lake, such as changing access credentials, click Edit. You are presented with the same options as on initial creation. As noted, you cannot change the Output Base Path after your initial save, but you can update the other settings.
Change Your Storage Backend
To change your active storage backend:
Create a new storage backend or select one you have previously created.
Click Activate.
Graylog prompts you to confirm you want to change your storage backend. Graylog recommends you do not change your storage backend! All the data written to the previous storage backend must be deleted before you can switch.
Warning: Deleting Data Lake data requires you to first stop routing data to the Data Lake. Note that if the affected streams are routing only to the Data Lake, you risk losing new data until you complete the process and start routing again with the new storage backend. -
Click Confirm to proceed.
The storage backend has now been switched. As new logs arrive, they are routed to the newly activated Data Lake storage backend.
Delete Backend Data
Before you can switch a storage backend, you must delete any data in the old storage backend. It is recommended that you delete this data with the following steps:
Navigate to the Overview tab of Data Lake > Internal Lake Setup.
Disable the Data Lake for each stream that is routing data to this backend. Click Data Routing, then toggle the Data Lake to Disabled.
Delete the data from each stream.
Select More > Delete.
Select the Full Delete check box.
Click Delete.
Verify that the message count for all streams hits 0.
Further Reading
