When your Graylog instance or cluster is up and running, the next thing you usually want to do is check out our web interface, which offers you great capabilities for searching and analyzing your indexed data and configuring your Graylog environment. By default you can access it using your browser on https://<graylog-server>:9000/.
Access the Web Interface
  1. Open a browser and navigate to the URL https://xxx.xxx.xxx.xxx:9000. Substitute the IP of your Graylog server.
  2. If using a VM appliance, log in using admin for both the username and password. If using either container or OS versions of Graylog, log in as an admin and use the password secret you created when you installed Graylog.
The Graylog web interface was rewritten in JavaScript for 2.0 to be a client-side single-page browser application. This means its code is running solely in your browser, fetching all data via HTTP(S) from the REST API of your Graylog server.
Hint:The HTTP address must be accessible by everyone using the web interface. This means that Graylog must listen on a public network interface or be exposed to one using a proxy, NAT or a load balancer!
Getting Started with the Web Interface
Now that you are connected to the web interface, you can start to explore Graylog!
After logging in you will be directed to the Getting Started page, which is customized with information specific to your Graylog experience:
  • Last Opened: A list of your most recently view saved searches and dashboards so you can resume your latest journey if desired.
  • Favorite Items: An overview of saved searches and dashboards that you have marked as favorite items.
  • Recent Activity: A list of recent actions by other Graylog users, including newly created content or content shared with you.
Configuration Options
If our default settings do not work for your environment, there are a number of options in the Graylog server configuration file that you can change to influence its behavior:
Setting
Default
Explanation
http_bind_address
127.0.0.1:9000
The network interface used by the Graylog HTTP interface.
http_publish_uri
If not set, https://$http_bind_address will be used.
The HTTP URI of this Graylog node which is used to communicate with the other Graylog nodes in the cluster and by all clients using the Graylog web interface.
http_external_uri
If not set,$http_publish_uri will be used.
The public URI of Graylog which will be used by the Graylog web interface to communicate with the Graylog REST API.Graylog web interface.
http_enable_cors
true
This is necessary for JS-clients accessing the server directly. If disabled, modern browsers will not be able to retrieve resources from the server.
http_enable_gzip
true
Serve web interface assets using compression to reduce overall round-trip times.
http_max_header_size
8192
The maximum size of the HTTP request headers in bytes.
http_thread_pool_size
16
The size of the thread pool used exclusively for serving the HTTP interface.
http_enable_tls
false
This secures the communication with the HTTP interface with TLS to prevent request forgery and eavesdropping.
http_tls_cert_file
(no default)
The X.509 certificate chain file in PEM format to use for securing the HTTP interface.
http_tls_key_file
(no default)
The PKCS#8 private key file in PEM format to use for securing the HTTP interface.
http_tls_key_password
(no default)
The password to unlock the private key used for securing the HTTP interface. (only needed if the key is encrypted)
How Does the Web Interface Connect to the Graylog Server?
The web interface is fetching all information it is showing from the REST API of the Graylog server. Therefore it needs to connect to it using HTTP(S). There are several ways how you can define which way the web interface connects to the Graylog server. The URI used by the web interface is determined in this exact order:
  • If the HTTP(S) client going to the web interface port sends a X-Graylog-Server-URL header, which contains a valid URL, then this is overriding everything else.
  • If http_external_uri is defined in the Graylog configuration file, this is used if the aforementioned header is not set.
  • If http_publish_uri is defined in the Graylog configuration file, this is used if the aforementioned http_external_uri is not set.
  • If none of the above are defined, https://$http_bind_address is used.
The web interface assets (e.g. the index.html, CSS and JavaScript files) are accessible at the URI root (/ by default) and the REST API endpoints are accessible at the /api path.
For example, setting http_bind_address to 10.0.0.1:9000 configures the Graylog server with the following URLs:
  • Web interface: https://10.0.0.1:9000/
  • REST API: https://10.0.0.1:9000/api/
Browser Compatibility
Writing the web interface as a single-page application is a challenging task. We want to provide the best possible experience to everyone, which often means using modern web technology only available in recent browsers, while keeping a reasonable compatibility with old and less-capable browsers. Here are the minimum supported browsers for Graylog:
Browser
OS
Minimum Version
Chrome
Windows, OS X, Linux
68
Firefox
91
Microsoft Edge
Windows
111
Safari
OS X
15.6
Opera
Windows, OS X, Linux, Android
97
Please take into account that you need to enable JavaScript in order to use Graylog web interface.
Making the Web Interface Work with Load Balancers/Proxies
If you want to run a load balancer/reverse proxy in front of Graylog, you need to make sure that:
  • The HTTP port of the load balancer/reverse proxy is accessible for clients
  • The HTTP address for the Graylog server is properly set (as explained in How does the web interface connect to the Graylog server?), so it is resolvable and accessible for the load balancer/reverse proxy.
  • If you use SSL, your certificates must be valid and trusted by your clients.
Hint:To help you with your specific environment, we show some example configuration use cases.
For the configuration use cases below we assume the following:
  • Your Graylog server configuration contains http_bind_address = 127.0.0.1:9000
  • The hostname for the setup is graylog.example.org
  • The IP address for that hostname is 192.168.0.10
Using a Layer 3 Load Balancer (Forwarding TCP Ports)
  1. Configure your load balancer to forward connections going to 192.168.0.10:80 to 127.0.0.1:9000.
  2. Start the Graylog server as usual.
  3. Access the web interface on https://graylog.example.org.
  4. Read up on Using HTTPS .
NGINX
Proxy web interface and API traffic using HTTP
Copy
server
    listen 80 default_server;
    listen [::]:80 default_server ipv6only=on;
    server_name graylog.example.org;
    location / {
      proxy_set_header X-Graylog-Server-URL http://$server_name/;
      proxy_pass       http://127.0.0.1:9000;
NGINX can be used for SSL Termination, you would only need to modify the server listen directive and add all Information about your certificate.
If you are running multiple Graylog Server you might want to use HTTPS/SSL to connect to the Graylog Servers (on how to Setup read Using HTTPS) and use HTTPS/SSL on NGINX. The configuration for TLS certificates, keys and ciphers is omitted from the sample config for brevity’s sake.
Proxy web interface and API traffic using HTTPS (TLS)
Copy
server
    listen      443 ssl http2;
    # <- your SSL Settings here!
    location /
      proxy_set_header X-Graylog-Server-URL https://$server_name/;
If you want to serve several different applications under one domain name, you can also serve the Graylog web interface using a path prefix.
Proxy web interface and API traffic under a path prefix using HTTP
Copy
server
    location /
This makes your Graylog setup available under the following URLs:
  • Web interface: https://applications.example.org/graylog/
  • REST API: https://applications.example.org/graylog/api/
Apache httpd 2.x
Copy
<VirtualHost *:80>
    ServerName graylog.example.org
    ProxyRequests Off
    <Proxy *>
        Order deny,allow
        Allow from all
    </Proxy>
    <Location />
        RequestHeader set X-Graylog-Server-URL "http://graylog.example.org/"
        ProxyPass http://127.0.0.1:9000/
        ProxyPassReverse http://127.0.0.1:9000/
    </Location>
</VirtualHost>
Copy
<VirtualHost *:443>
    ProxyRequests Off
    SSLEngine on
    <Proxy *>
        Order deny,allow
        Allow from all
    </Proxy>
    <Location />
        RequestHeader set X-Graylog-Server-URL "https://graylog.example.org/"
    </Location>
</VirtualHost>
HAProxy 1.6
Copy
frontend http
    bind 0.0.0.0:80
    option forwardfor
    http-request add-header X-Forwarded-Host %[req.hdr(host)]
    http-request add-header X-Forwarded-Server %[req.hdr(host)]
    http-request add-header X-Forwarded-Port %[dst_port]
    acl is_graylog hdr_dom(host) -i -m str graylog.example.org
    use_backend     graylog if is_graylog
backend graylog
    description     The Graylog Web backend.
    http-request set-header X-Graylog-Server-URL http://graylog.example.org/
    use-server graylog_1
    server graylog_1 127.0.0.1:9000 maxconn 20 check
Multiple Backends (roundrobin) with Health-Check (using HTTP)
Copy
frontend graylog_http
    bind *:80
    option forwardfor
    use_backend     graylog
backend graylog
    balance roundrobin
    option httpchk HEAD /api/system/lbstatus
    server graylog1 192.168.0.10:9000 maxconn 20 check
    server graylog2 192.168.0.11:9000 maxconn 20 check
    server graylog3 192.168.0.12:9000 maxconn 20 check
