Health Checks Reference
The Health Module continuously runs a set of automated checks and rolls each one up into an overall status. This reference provides the full catalog of checks, grouped by component, along with the condition that triggers each check's Warning and Critical status.
Health Status
Status
Meaning
Healthy
The check passed. Nothing to do.
Warning
Attention recommended.
Critical
Urgent. Action required.
Unknown
The check couldn't run, or the data was unavailable. This isn't a failure. For example, a feature is disabled, or the search cluster is externally managed.
Check Behavior and Scope
Behavior
Details
Usage-based checks
Averaged over a rolling 10-minute window (disk, memory, buffers, CPU), so a brief spike doesn't flip the status.
State-based checks
Change status only after the condition holds for roughly 30 seconds (connectivity, processing state).
Scope
Some checks run per Graylog node (a single node can show Warning while others are healthy); others run once for the whole cluster.
Graylog Server Checks
Check
What It Monitors
Warns When
Critical When
Disk usage (node)
Free space on the node's data/journal directory
≥ 85%
Usage ≥ 95%
JVM heap (node)
Java Virtual Machine (JVM) heap memory used by the Graylog process
≥ 80%
≥ 90%
Message processing state
Whether the node is processing messages
Processing paused, or node shutting down
Processing has failed
Load balancer status
The node's load balancer health signal
Status not ALIVE (for example, throttled or manual override)
Status DEAD
Input buffer
How full the input buffer is
≥ 90%
≥ 95%
Failing inputs
Inputs that fail to start or run
One or more inputs failing
Never Critical
Processing buffer
How full the processing buffer is
≥ 90%
≥ 95%
Disk journal utilization
How full the on-disk message journal is versus its limit
≥ 80%
≥ 95%
Output buffer
How full the output buffer is
≥ 90%
≥ 95%
Report generation
Scheduled report runs
One or more reports failed to generate or deliver
Never Critical
Archiving failures
Archive jobs with active errors
Failures reach the configured archive-failure threshold
Never Critical
Data Lake message drops
How full the local Data Lake write buffer (journal) is. A full buffer means messages are being dropped
Usage ≥ configured threshold
Journal 100% full (messages may be dropping)
Node indexing lag
How far a node's indexing trails the furthest-ahead node
Lags peers by more than 2 minutes
Lags peers by more than 5 minutes
Data Lake connectivity
Reachability of the active Data Lake backend
Never warns
Backend unreachable (after approximately 30 seconds). No backend configured = Healthy
MongoDB Checks
Check
What It Monitors
Warns When
Critical When
Connectivity
Whether Graylog can reach MongoDB
Never warns
MongoDB unreachable
Replica-set primary
Whether a primary is elected in the replica set
Never warns
No primary elected. Standalone MongoDB = Healthy
Storage
Database storage used
≥ 85%
≥ 95%
Slow queries
Slow (greater than 100 ms) queries in the recent window
1 or more slow queries
10 or more slow queries
Slow-query monitoring requires MongoDB profiling to be enabled. Otherwise, this check reports Healthy.
Search Cluster Checks
Check
What It Monitors
Warns When
Critical When
Cluster state
The search cluster's overall status color
Cluster Yellow
Cluster Red
Warm-tier move
Warm-tier snapshot moves per index set
A warm-tier move failed or was partial
Never Critical
Node disk usage
Disk used per search-cluster node
≥ 85%
≥ 95%
Node CPU
CPU used per search-cluster node
≥ 90%
≥ 95%
Node heap
JVM heap used per search-cluster node
≥ 80%
≥ 90%
Node certificates
TLS certificate expiry on data nodes
Expires in fewer than 30 days
Expires in fewer than 7 days, or already expired
Shard count per node
Shards per GB of heap on each hot data node
More than 20 shards/GB
More than 25 shards/GB
Node CPU, heap, certificate, and shard-count checks report Unknown for externally managed OpenSearch, or for Elasticsearch 7, where the required data isn't available.
Thresholds shown above are product defaults. The archiving failure and Data Lake journal thresholds are configurable; the rest are fixed.
Further Reading
Explore the following additional resource and recommended reading to expand your knowledge on related topics:
