GeoIP Data Adapter
The GeoIP data adapter supports reading MaxMind and IPinfo Geodatabases. Graylog lets you extract and visualize geolocation information from IP addresses in your logs.
Prerequisites
Create a GeoLite2 account and sign up to get access to GeoLite2 geolocation database.
Install GeoIP Update.
Configure GeoIP.conf.
Configure the Data Adapter
You can create a data adapter during the lookup table creation workflow, or they can be created separately on the Data Adapters tab. The following configuration options are available for this data adapter:
Title |
A short and unique title for this data adapter. |
Description |
Data adapter description. |
Name |
The name used to refer to this data adapter. This should be something unique and recognizable within your Graylog environment. |
Custom Error TTL |
Specifies the time to live (TTL) for custom error messages if any occur during the API interaction. Enter a value in seconds, such as |
File path |
The path to the MaxMind database file. This file must exist on all Graylog server nodes. This file should also be updated on a regular basis using the GeoIpUpdate tool. |
Database Type |
Supports multiple options:
Refresh file |
If enabled, the database file is checked for modifications and refreshed when changed on disk. |
Example GeoIP Pipeline Rule
This rule enriches messages by performing a GeoIP lookup on the query_response_ip field. It adds location-based details, such as coordinates, country code, country name, and city name using data from a geoip-city lookup table.
rule "PARSE query_response_ip GEO"
has_field("query_response_ip")
let geo = lookup("geoip-city", to_string($message.query_response_ip));
set_field("query_response_geolocation", geo["coordinates"]);
set_field("query_response_geo_country_code", geo["country"].iso_code);
set_field("query_response_geo_country_name", geo["country"].names.en);
set_field("query_response_geo_city_name", geo["city"].names.en);
Further Reading
