NGINX [Engine x] is an HTTP Server that runs on Linux systems. It was originally written by Igor Sysoev and publicly released in 2004.
This pack parses and configures NGINX access logs and error logs. The default log location is: /var/log/nginx/
Requirement(s)
A Graylog Server with a valid Enterprise license that is running Graylog version 5.1.10 or 5.2.3 (or later).
This pack will work with all versions of NGINX, as long as the combined log format is used.
Log folders must be named:
access.log
Either Filebeat (with Sidecar) or rsyslog are required for delivering logs.
Input via Filebeat Together with Graylog Sidecar
Please follow the official documentation . You will need to configure your Graylog Server and your client(s).
To do this:
Create an input and an API key. Then set up Graylog sidecar.
Add your clients, e.g. web server.
Graylog Server Settings
Create a global Beats input in Graylog.
Create a Graylog REST API Access Token and save it.
Create a (Linux) filebeat configuration under Sidecar > Configuration with a
filebeat on Linux
collector. -
After configuring the file:
Add the Graylog server IP under hosts.
Configure the log source to the desired value and configure the field
event_source_product
with the valueNGINX-web
filebeat.inputs:
- input_type: log
paths:
- /var/log/nginx/access.log
- /var/log/nginx/error.log
type: filestream
fields_under_root: true
fields:
event_source_product: nginx-web
and - /var...
Save the configuration
Configure a Client with Filebeat and Graylog Sidecar
Install Sidecar on the remote machine. See here for instructions.
Edit the
/etc/graylog/sidecar/sidecar.yml
file and configure:-
server_url
as:GraylogServerIP
server_api_token
as:your API token
Install the Sidecar service.
Enable and start the Sidecar service.
Check the Sidecar status.
Here are some sample commands for Ubuntu, please use the official documentation.
wget https://packages.graylog2.org/repo/packages/graylog-sidecar-repository_1-5_all.deb
sudo dpkg -i graylog-sidecar-repository_1-5_all.deb
sudo apt-get update && sudo apt-get install graylog-sidecar
sudo gedit /etc/graylog/sidecar/sidecar.yml
server_url: "http://192.168.122.52:9000/api/"
server_api_token: "65ol7edseo24mub8o7pu86h2rsr8j9fjjpimtrm9nrpbjso7cnv"
sudo graylog-sidecar -service install
sudo systemctl enable graylog-sidecar
sudo systemctl start graylog-sidecar
sudo systemctl status graylog-sidecar
6. Install Filebeat.
7. Download the link for the OSS version.
If you choose to install it manually, install it under
/etc/filebeat
If you choose to install it via
apt-get
, no further action is required.
Sample commands for Ubuntu, please use the official documentation.
wget -qO - https://artifacts.elastic.co/GPG-KEY-elasticsearch | sudo apt-key add -
sudo apt-get install apt-transport-https
echo "deb https://artifacts.elastic.co/packages/oss-8.x/apt stable main" | sudo tee -a /etc/apt/sources.list.d/elastic-8.x.list
sudo apt-get update && sudo apt-get install filebeat
sudo systemctl enable filebeat
sudo systemctl start filebeat
sudo systemctl status filebeat
You may edit thefilebeat.yml
file via the Sidecar configuration in Graylog.
8. Start the daemon. Any permission issues may be solved with sudo chown root filebeat.yml
9. Configure filebeat to start automatically after reboot (recommended).
10. Assign a configuration to your machine in Graylog.
Input via rsyslog
You will need a configured UDP or
TCP_syslog
input on the Graylog server side. -
Install rsyslog via the official documentation.
Modify the configured
rsyslog.conf
file.
Example for /etc/nginx.conf
with a UDP input at 1544 on IP 192.168.122.40:
sudo gedit /etc/rsyslog.conf
Under MODULES add or modify:
# provides UDP syslog reception
$ModLoad imudp
$UDPServerRun 1544
*.* @192.168.122.40:1544;RSYSLOG_SyslogProtocol23Format
The next code block can be set in a different configuration file or at the end of thersyslog.conf
file.
module(load="imfile" PollingInterval="10" statefile.directory="/var/spool/rsyslog")
input(type="imfile"
File="/var/log/nginx/access.log"
Tag="nginx_web_http_access"
Severity="info"
Facility="local6")
input(type="imfile"
File="/var/log/nginx/error.log"
Tag="nginx_web_http_error"
Severity="info"
Facility="local6")
local6.access @192.168.122.40:1544
The command to restart the service on Ubuntu:
sudo systemctl restart rsyslog
You can check the status with:
sudo systemctl status rsyslog
Red lines may indicate problems. Sometimes a full reboot of the system is needed.
Tested rsyslog version
8.2212.0
Stream Configuration:
"Illuminate:Nginx_web Messages"
If this stream name is already defined, then nothing will be changed. If this stream name does not exist, then it will be created.
Index Set Configuration:
NGINX_web Logs
If this index set is already defined, nothing will be changed. If this index set does not exist, it will be created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Format Examples:
Access Logs version 1.18
127.0.0.1 - - [04/Mar/2023:19:25:07 -0600] "GET / HTTP/1.1" 200 3543 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/109.0"
Access Logs version 1.24
127.0.0.1 - - [13/Sep/2023:08:34:54 -0500] "GET / HTTP/1.1" 200 615 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:103.0) Gecko/20100101 Firefox/103.0" "-"
Error Logs:
2023/03/05 09:34:46 [emerg] 2032#2032: no "ssl_certificate" is defined for the "listen ... ssl" directive in /etc/nginx/sites-enabled/default:21
2023/01/05 11:50:44 [error] 22053#0: *3 open() "/usr/local/stefan/nginx/1.10.2_1/html/stest" failed
What is Provided
This pack includes parsing rules that convert Nginx logs into Graylog schema-compatible fields. Nginx access logs get the GIM code “180200”.
NGINX Spotlight Content Pack
The NGINX content pack provides an Overview Dashboard.
