CrowdStrike Falcon is a cutting-edge endpoint security solution with advanced capabilities. Leveraging artificial intelligence and threat intelligence, Falcon empowers organizations to proactively defend against cyber threats, detect malicious activities in real-time, and respond swiftly to secure their endpoints with unmatched precision and agility.
This technology pack will:
Process Crowdstrike Falcon logs, providing normalization and enrichment of those events.
Supported Version(s)
Crowdstrike Falcon 6.54.16812.0
Crowdstrike Falcon version 6.54.16812.0
Stream Configuration
“Illuminate:Crowdstrike Falcon Messages”
Index Set Configuration
“Crowdstrike Falcon Event Log Messages”
Log Collection
Sending logs via Graylog’s Crowdstrike Input
Log Format Example
- {"timestamp":1693337449.649,"version":"1.1","host":"customer-id","short_message":"{\"UserId\":\"api-client-id\",\"UserIp\":\"10.1.1.1\",\"OperationName\":\"reveal_token\",\"ServiceName\":\"sensor_update_policy\",\"UTCTimestamp\":1688847014,\"Attributes\":{\"device_id\":\"6614e76223cc47699c09b18e84da6425\",\"message\":\"\",\"seedID\":\"101\"}}","full_message":"{\"metadata\":{\"customerIDString\":\"customer-id\",\"offset\":2802412,\"eventType\":\"UserActivityAuditEvent\",\"eventCreationTime\":1688847014000,\"version\":\"1.0\"},\"event\":{\"UserId\":\"api-client-id\",\"UserIp\":\"10.1.1.1\",\"OperationName\":\"reveal_token\",\"ServiceName\":\"sensor_update_policy\",\"UTCTimestamp\":1688847014,\"Attributes\":{\"device_id\":\"6614e76223cc47699c09b18e84da6425\",\"message\":\"\",\"seedID\":\"101\"}}}","_event_source_product":"crowdstrike_falcon","_vendor_subtype":"UserActivityAuditEvent","_vendor_version":"1.0","_event_created":"2023-07-08T20:10:14.000Z"}
What is Provided
We provide parsing rules to normalize and enrich Crowdstrike Falcon log messages .
All messages sent via the Crowdstrike API to the Graylog Crowdstrike Input will be parsed, but not all will receive categorization or normalization.
We provide Categorization for the following log types:
DetectionSummaryEvent
Input Configuration
In order to successfully connect your Crowdstrike Falcon device to the Graylog Crowdstrike input, you will need your CrowdStrike client ID and your Client Secret.
Then, once connected, your Crowdstrike logs should successfully be coming into your Graylog instance.
The Crowdstrike Falcon content pack supports parsing for all fields and GIM categorization for the CustomerIOCEvent
, DetectionSummaryEvent
, and UserActivityAuditEvent
events.
Crowdstrike Spotlight Content Pack
Crowdstrike Falcon: Overview Tab
Crowdstrike Falcon: Authentication Tab
Crowdstrike Falcon: Alert Tab
