Zeek Content Pack
Zeek is an open-source network security monitoring tool capable of passively analyzing network traffic and generating a number of logs describing the activity it sees.
Zeek can be used to detect attacks and probes with a variety of different analyzers and scripts. This technology pack processes Zeek log messages by providing normalization, enrichment, and GIM categorization of common events of interest.
Supported Versions
  • Zeek 5.0.9+
  • Filebeat 7.13+ (ndjson parser)
  • Graylog Server 5.0.3+ with a valid Enterprise license
  • Configured Beats input
Hint: This pack requires Graylog Server 5.0.3 or later due to changes in extraction functions. Fields will be improperly processed on earlier versions.
Stream Configuration
  • "Illuminate:Zeek Messages"
Index Set Configuration
  • "Zeek Logs"
Log Format Example
An example of a Zeek conn.log message delivered via Filebeat in GELF format:
Zeek conn.log (Filebeat GELF)
{"filebeat_id_orig_p":58405,"filebeat_log_offset":908201,"filebeat_agent_name":"snort1","filebeat_history":"ShADadFf","filebeat_resp_pkts":7,"filebeat_id_orig_h":"74.96.110.140","filebeat_event_source_product":"zeek","beats_type":"filebeat","filebeat_@metadata_beat":"filebeat","filebeat_ts":"2023-06-05T14:15:05.682220Z","filebeat_@timestamp":"2023-06-05T14:15:23.109Z","filebeat_agent_type":"filebeat","filebeat_@metadata_version":"8.6.2","filebeat_host_name":"snort1","filebeat_proto":"tcp","filebeat_agent_version":"8.6.2","filebeat_orig_ip_bytes":1234,"filebeat_agent_ephemeral_id":"6a114e83-ca97-4925-b4c6-8971c97d191b","filebeat_local_orig":true,"filebeat_orig_bytes":942,"filebeat_input_type":"filestream","filebeat_id_resp_h":"172.65.251.78","filebeat_orig_pkts":7,"filebeat_resp_bytes":1960,"filebeat_duration":10.197248935699463,"message":"-","filebeat_ecs_version":"8.0.0","filebeat_id_resp_p":443,"filebeat_uid":"CyRQBS1i6zJKpZXgHl","filebeat_service":"ssl","filebeat_missed_bytes":0,"filebeat_@metadata_type":"_doc","filebeat_conn_state":"SF","filebeat_resp_ip_bytes":2252,"filebeat_local_resp":false,"filebeat_agent_id":"c2c08007-50ba-4d8e-948b-ca484ef0ece2","filebeat_log_file_path":"/opt/zeek5/logs/current/conn.log","host":"bg-devel","level":6,"replayed_log":"true"}
Log Collection
This pack processes Zeek JSON logs delivered via Filebeat. Zeek must be configured to log in JSON format, and Filebeat must be configured to parse and deliver the logs to a Graylog Beats input.
Zeek Configuration
  1. Zeek must be configured to log in JSON format. Any existing logging configuration can still be used separately, but this technology pack requires the JSON configuration below.
  2. The ISO8601 setting is crucial for proper timestamp processing.
  3. Edit json-logs.zeek at /zeek_install_path/share/zeek/policy/tuning/:
    Copy
    ##! Loading this script will cause all logs to be written
                        ##! out as JSON by default.
                        redef LogAscii::use_json=T;
                        redef LogAscii::json_timestamps = JSON::TS_ISO8601;
                        redef LogAscii::json_include_unset_fields=T;
  4. Edit local.zeek at /zeek_install_path/share/zeek/site/ and add the following lines:
    1. @load packages
    2. @load policy/tuning/json-logs.zeek
  5. Additional information: Zeek download | Zeek documentation
Filebeat Configuration
  1. Create a matching Beats input in Graylog.
  2. Ensure that the option Do not add Beats type as prefix is disabled.
  3. Configure Filebeat to ship Zeek logs to Graylog. The event_source_product: zeek field and ndjson parser with target: zeek are critical for proper identification and parsing.
  4. If Zeek logs are stored in a location other than the default, update the paths accordingly.
  5. Example filebeat.yml configuration:
    Copy
    - type: filestream
                        enabled: true
                        paths:
                        - /zeek_install_path/logs/current/*.log
                        parsers:
                        - ndjson:
                        target: "zeek"
                        add_error_key: true
                        overwrite_keys: true
                        fields:
                        fields_under_root: true
  6. Additional information: Filebeat download | Filebeat configuration
What is Provided
  • Rules to normalize and enrich Zeek log messages.
This pack supports 63 Zeek log types. The following log types receive specific field extraction and GIM categorization. Generic processing is provided for all other log types.
  • conn.log - TCP/UDP/ICMP connections
  • dns.log - DNS activity
  • http.log - HTTP requests and replies
  • ntlm.log - NTLM authentication
  • ssl.log - SSL/TLS handshake info
  • dce_rpc.log - Distributed Computing Environment/RPC
  • ntp.log - Network Time Protocol
  • weird.log - Unexpected network-level activity
  • files.log - File analysis results
  • x509.log - X.509 certificate info
  • pe.log - Portable Executable analysis
  • ocsp.log - Online Certificate Status Protocol
  • loaded_scripts.log - Scripts loaded by Zeek
GIM Categorization
GIM categorization is provided for the following Zeek log types:
Zeek Log Type gim_event_type_code GIM Category GIM Subcategory gim_event_type
conn 120500 network network.flow flow record
dns (request) 140000 name resolution name resolution.dns request dns query
dns (response) 140200 name resolution name resolution.dns answer dns response
http 180200 http http.communication http communication
ntlm 100500 authentication authentication.credential validation credential validation
ssl 129999 network network.default network message
dce_rpc 129999 network network.default network message
ntp 129999 network network.default network message
weird 129999 network network.default network message
Zeek Spotlight Content Pack
Overview
