WatchGuard Firebox Content Pack
WatchGuard's Firebox is a unified security platform that covers traditional traffic protection, protecting an environment from intrusions, phishing attempts, malware, ransomware, and more. Both hardware and virtual appliances are available. This technology pack processes Firebox event log messages, providing normalization and enrichment of common events of interest.
Supported Versions
Fireware 12.x and later
WatchGuard Firebox running Fireware 12.x
Graylog Server with valid Enterprise license, version 4.2.5, 4.3.0, or later
WatchGuard Firebox configured to send logs via syslog to Graylog
Stream Configuration
- "Illuminate:WatchGuard Device Messages"
Index Set Configuration
- "WatchGuard Device Logs"
Log Collection and Delivery
WatchGuard Firebox logs are delivered to Graylog via syslog. The Firebox must be configured to send logs to a Graylog syslog input. A local Syslog input must be created on the Graylog server with a port that matches the Firebox configuration.
Fireware Web UI Configuration
Configure the Firebox to send logs to Graylog:
Select System > Logging.
Click the Syslog Server tab.
Select Send log messages to these syslog servers.
Click Add, then enter the Graylog server IP address.
Configure the port to match the Graylog Syslog input.
Select Syslog format.
Select the timestamp and serial number boxes.
Select a syslog facility (Local0-7), and set Alarm to Local0 for high priority.
Click Save.
Log Format Example
DEV01 0011223344556 (2022-09-01T13:58:33) firewall: msg_id="3000-0148" Allow External Inside 44 tcp 20 238 10.11.12.13 192.168.1.10 58325 60951 offset 6 S 3172487743 win 4 geo_src="USA" geo_dst="USA" (Inbound Policy-00)
What is Provided
Parsing rules to extract WatchGuard Firebox logs into Graylog schema compatible fields
GIM event type categorization and enforcement fields for supported WatchGuard Firebox events
Spotlight dashboard and saved searches
GIM Categorization
GIM categorization is provided for the following event types:
| Event Category | Event IDs | gim_event_type_code | gim_event_category | gim_event_subcategory | gim_event_type |
| User authentication succeeded/failed | 1100-0004, 1100-0005 | 100000 | authentication | authentication.logon | logon |
| User login succeeded | 3E00-0002 | 100000 | authentication | authentication.logon | logon |
| User logout | 3E00-0004 | 102500 | authentication | authentication.logoff | logoff |
| Firewall traffic (allow/deny) | 3000-0148, 3000-0149, 3000-0150, 3000-0173 | 120000 | network | network.network connection | network connection |
| Policy alarm, blocked site/port, spoofing | 3000-0167, 3000-0168, 3000-0169, 3000-0172 | 120000 | network | network.network connection | network connection |
| VPN tunnel established | 0207-0001 | 120000 | network | network.network connection | network connection |
| HTTP/HTTPS/TCP-UDP proxy events | 1AFF-, 2CFF-, 2DFF-* | 120000 | network | network.network connection | network connection |
| Operational events (address, server status, connections, interface, host blocking) | 3000-0029/002A/003C/0040/00CB/012D/0170/0171, 3001-1001/1002, 3100-0030 | 219999 | service | service.default | service event |
| Device configuration change | 0101-0001 | 220500 | audit | audit.policy | audit policy changed |
| Signature update | 2E02-0065, 2E02-0066, 2E02-0067 | 280100 | agent | agent.update | agent update |
| Signature version check | 2E02-0069 | 280200 | agent | agent.status | agent status |
| DHCP Request | 1600-0003, DHCPREQUEST | 290000 | dhcp | dhcp.request | dhcp request |
| DHCP Offer | 1600-0002, DHCPOFFER | 290100 | dhcp | dhcp.offer | dhcp offer |
| DHCP Discovery | 1600-0001, DHCPDISCOVER | 290200 | dhcp | dhcp.discovery | dhcp discovery |
| DHCP Acknowledgement | DHCPACK | 290300 | dhcp | dhcp.acknowledgement | dhcp acknowledgement |
| IPS/GAV/APT detection in proxy | 1AFF-0025/0026/0028/0029/0034, 2CFF-0005, 2DFF-0001 | 300000 | detection | detection.network_detection | ids_detection |
| Attack events (flood, scan, DDoS, spoofing) | 3000-0152 through 3000-0166 | 300000 | detection | detection.network_detection | ids_detection |
WatchGuard Firebox Spotlight
This spotlight offers a dashboard with 5 tabs:
Overview (1)
Overview (2)
Status
Saved Search: Log Viewer
Saved Search: Traffic Log
