Ubiquiti UniFi Content Pack
Ubiquiti UniFi is a family of monitoring products that range from wireless access points, routers, switches, security cameras, and controllers (cloud or on-prem), all working together to provide a cohesive overview of your environment. This technology pack processes UniFi syslog messages and CEF-formatted SIEM integration logs for UniFi OS, UniFi Network, and UniFi Protect by providing normalization and enrichment for common events of interest.
Supported Versions
UniFi OS 3.0+
UniFi Network 7.3+
UniFi Protect 2.7+
Graylog 4.3.0+ with a valid Enterprise license
A dedicated syslog input configured for UniFi log delivery
Illuminate lookup override configured to map the input ID to ubiquiti_unifi
Stream Configuration
- "Illuminate:Ubiquiti Unifi Messages"
Index Set Configuration
- "Ubiquiti Unifi Logs"
Log Collection and Delivery
Due to the way UniFi controllers generate some logs (syslog notation of path, process name, and process ID), a UniFi-specific input and Illuminate lookup override must be configured. This maps the input ID to the UniFi identification rule so Illuminate treats every log on this input as a UniFi message.
Graylog Server Configuration: Create the Syslog Input
Create a new syslog input and choose an unused port. If an input already exists that only handles UniFi logs, use that input.
Select Received messages for the input on the inputs list.
Copy the
gl2_source_inputvalue.
Graylog Server Configuration: Configure the Illuminate Override
Navigate to Enterprise > Illuminate and select the Customization tab.
Locate
lookup_adapter_input_routing, then select Edit. -
Enter your custom values:
content_name: Enter
ubiquiti_unifi. -
input_id: Enter the
gl2_source_inputID copied earlier.
Select Configure value.
UniFi Syslog Configuration
Enable remote logging in the UniFi Network System settings page under Support.
Set Logging Levels to Auto.
Under Remote Logging Location, enable Remote Server, check Syslog, and enter the Graylog server IP address and port matching the input configured above.
UniFi CEF / SIEM Integration (UniFi Network 8.5+)
UniFi Network 8.5+ supports CEF-formatted log export for IDS/IPS alerts, admin access, WiFi client events, and system events.
In the UniFi Network Application, navigate to Settings > Control Plane > Integrations > Activity Logging.
Select SIEM Server as the destination.
Enter the Graylog server IP and the syslog input port.
CEF-formatted logs are sent over syslog (UDP) to the configured input.
Log Format Examples
UniFi devices send logs in syslog format with the AP/device name, MAC, model version, and daemon name.
DNS Query
APSomewhere f091234518f6,UAP-AC-Pro-Gen2-6.2.49+14111: dnsmasq[4797]: forwarded www.graylog.org to 10.10.10.10
Firewall
Houston-Office-DM-Pro [LAN_LOCAL-RET-2147483647] DESCR="no rule description" IN=br148 OUT= MAC=60:22:32:28:41:e5:d0:21:f9:96:fa:d8:08:00 SRC=10.148.153.76 DST=10.148.0.1 LEN=1500 TOS=00 PREC=0x00 TTL=64 ID=10151 DF PROTO=TCP SPT=33725 DPT=7550 SEQ=270903990 ACK=2412021963 WINDOW=913 ACK URGP=0
CEF IDS/IPS Alert
pandora CEF:0|Ubiquiti|UniFi Network|9.4.19|201|Threat Detected and Blocked|7|proto=TCP src=81.181.129.172 spt=54321 dst=192.168.0.233 dpt=443 UNIFIcategory=Security UNIFIsubCategory=Intrusion Prevention UNIFIhost=Office-UDM-Pro UNIFIdeviceMac=84:78:48:80:0d:86 UNIFIdeviceName=Office-UDM-Pro UNIFIdeviceModel=UDM-Pro UNIFIdeviceIp=192.168.0.1 UNIFIrisk=medium UNIFIipsSignature=ET DROP Dshield Block Listed Source group 1 UNIFIipsSignatureId=2402000 msg=A network intrusion attempt has been detected and blocked.
What is Provided
Field extraction, normalization, and message enrichment for UniFi syslog and CEF-formatted log messages.
CEF (Common Event Format) parsing for UniFi Network SIEM integration logs: IDS/IPS alerts, admin access, WiFi client events, system events.
GIM event type categorization and enforcement fields for supported Ubiquiti UniFi events (firewall, DNS, DHCP, IDS/IPS).
Spotlight: Ubiquiti UniFi Overview dashboard.
GIM Categorization
GIM event type categorization is provided for the following message types:
| UniFi Log Type | Condition | gim_event_type_code | GIM Category | GIM Subcategory | GIM Event Type |
| firewall | All firewall events (allowed) | 120000 | network | network.network_connection | network connection |
| firewall | Drop rules (-D- chain pattern) | 120000 | network | network.network_connection | network connection (blocked) |
| dnsmasq | Query only (no response) | 140000 | name_resolution | name_resolution.dns_request | dns query |
| dnsmasq | Query with response | 140000|140200 | name_resolution | name_resolution.dns_request + dns_answer | dns query + dns response |
| dnsmasq-dhcp | DHCPDISCOVER | 290200 | dhcp | dhcp.discovery | dhcp discovery |
| dnsmasq-dhcp | DHCPOFFER | 290100 | dhcp | dhcp.offer | dhcp offer |
| dnsmasq-dhcp | DHCPREQUEST | 290000 | dhcp | dhcp.request | dhcp request |
| dnsmasq-dhcp | DHCPACK | 290300 | dhcp | dhcp.acknowledgement | dhcp acknowledgement |
| dnsmasq-dhcp | DHCPNAK | 299999 | dhcp | dhcp.default | dhcp default |
| CEF (event ID 201) | IPS Threat Detected and Blocked | 300000 | detection | detection.network_detection | ids_detection |
Ubiquiti UniFi Spotlight
Overview
