Redis Content Pack
Redis is an in-memory data structure store used as a database, cache, message broker, and streaming engine. This technology pack processes Redis server log messages from Redis open source, including server lifecycle events, replication, persistence operations, Sentinel monitoring, slow query logging, and ACL authentication. This pack also processes logs from Valkey, the open-source fork of Redis, in all three of its log output modes: legacy (byte-for-byte identical to Redis OSS), logfmt, and JSON.
All the ingest variants share a single event_source_product value. Therefore, downstream streams, searches, and spotlights cover the entire Redis family seamlessly. This content pack supports log delivery via Filebeat with Graylog Sidecar integration.
A supported version of Redis or Valkey (see Supported Versions below)
Graylog version 7.1.0 or later
Redis or Valkey configured to send logs via Filebeat to Graylog
Supported Versions
Redis 6.x and later (open-source)
Redis 7.x and later (open-source)
Valkey 7.2.4 and later (legacy, logfmt, and JSON log formats)
Log Collection and Delivery
Redis server logs are delivered to Graylog using Filebeat managed by the Graylog Sidecar. Redis must be configured to write to a log file that Filebeat can ship.
Filebeat Configuration
Configure Filebeat to ship Redis log files:
Install Filebeat on the Redis server (typically through Graylog Sidecar).
Create a configuration under Sidecar > Configuration with a filebeat on linux collector.
Set the Graylog server IP address under
hostsand add theevent_source_productfield with the valueredis.Copyfilebeat.inputs:
- input_type: log
paths:
- /var/log/redis/redis-server.log
- /var/log/redis/redis.log
type: filestream
fields_under_root: true
fields:
event_source_product: redis -
Default log paths vary by OS: Ubuntu/Debian uses /var/log/redis/redis-server.log, RHEL/CentOS uses /var/log/redis/redis.log. Check the redis.conf 'logfile' setting for the actual path on your host.
Create a matching Beats input in Graylog and save the configuration.
fields_under_root: true is required so that event_source_product lands at the message root where the pack's identification rule looks for it.
Valkey Log Collection
Valkey is the open-source fork of Redis 7.2.4. It ships three log output modes selected via the 'log-format' directive in valkey.conf. The pack identifies and parses all three. Downstream processing is unified with Redis OSS so no separate pipeline is required.
Legacy mode (default, byte-for-byte identical to Redis OSS): Forward via Filebeat. Identification matches on
application_namestarting with 'valkey', the 'valkey[PID]:' message prefix, or the PID:ROLE body pattern. -
logfmt mode (log-format logfmt in valkey.conf): messages arrive as 'pid=<n> role=<word> timestamp="<ts>" level=<word> message="<text>"'. Roles: primary, replica, sentinel, RDB/AOF. Levels: debug, verbose, notice, warning.
JSON mode (log-format json in valkey.conf): messages arrive as '{"pid":<n>,"role":"<word>","timestamp":"<ts>","level":"<word>","message":"<text>"}'. Same role/level vocabulary as logfmt.
All three Valkey modes produce
event_source_product=redis(unified with Redis OSS).
Stream Configuration
- Illuminate:Redis Messages
Index Set Configuration
- Redis Logs
What is Provided
Parsing rules to extract Redis server logs into Graylog schema compatible fields.
Graylog Information Model (GIM) message categorization for service lifecycle and authentication events.
Support for Redis Sentinel monitoring events.
Support for Redis slow query log parsing.
Support for Redis signal handler events (SIGTERM, SIGINT).
Redis role description mapping (M=master, S=replica, C=child, X=sentinel).
Valkey support across all three log output modes: legacy (same format as Redis OSS, handled by existing rules), logfmt (pid=N role=primary|replica|sentinel|RDB/AOF timestamp=... level=... message=...), and JSON ({"pid":N,"role":"...","timestamp":"...","level":"...","message":"..."}). Role words map to the existing role description, and level words (debug, verbose, notice, warning) map through the severity lookup.
Log Format Examples
Representative log lines for Redis open-source and Valkey.
Redis OSS (text log)
87041:M 10 Apr 2026 14:22:01.234 * Server started, Redis version 7.2.4
87041:M 10 Apr 2026 14:22:01.235 * Ready to accept connections tcp
87041:M 10 Apr 2026 14:35:12.456 # WARNING: The TCP backlog setting of 511 cannot be enforced
87041:M 10 Apr 2026 15:00:00.789 * Background saving started by pid 87150
87041:M 10 Apr 2026 15:00:01.012 * Background saving terminated with success
45123:X 10 Apr 2026 16:45:30.100 # +sdown master mymaster 10.0.1.50 6379
45123:X 10 Apr 2026 16:45:31.200 # +odown master mymaster 10.0.1.50 6379 #quorum 2/2
87041:S 10 Apr 2026 17:00:05.300 * MASTER <-> REPLICA sync: Finished with success
87041:M 10 Apr 2026 18:30:00.400 * User requested shutdown
87041:signal-handler (1744358400) Received SIGTERM scheduling shutdown...
Valkey (legacy, logfmt, and JSON modes)
# Valkey (open-source Redis fork) -- three log output modes
# Select with 'log-format <legacy|logfmt|json>' in valkey.conf.
# Role words: primary, replica, sentinel, RDB/AOF
# Level words: debug, verbose, notice, warning
# Legacy mode (default, byte-for-byte identical to Redis OSS):
87041:M 15 Apr 2026 14:22:01.234 * Server started, Valkey version 8.0.1
87041:M 15 Apr 2026 14:22:01.235 * Ready to accept connections tcp
87041:S 15 Apr 2026 14:35:12.456 # WARNING: Lost connection to primary, will retry
87041:X 15 Apr 2026 16:45:30.100 # +sdown master mymaster 10.0.1.50 6379
# logfmt mode (log-format logfmt):
pid=87041 role=primary timestamp="2026-04-15T14:22:01.234Z" level=notice message="Server started, Valkey version 8.0.1"
pid=87041 role=primary timestamp="2026-04-15T14:22:01.235Z" level=notice message="Ready to accept connections tcp"
pid=87041 role=replica timestamp="2026-04-15T14:35:12.456Z" level=warning message="Lost connection to primary, will retry"
# JSON mode (log-format json):
{"pid":87041,"role":"primary","timestamp":"2026-04-15T14:22:01.234Z","level":"notice","message":"Server started, Valkey version 8.0.1"}
{"pid":87041,"role":"replica","timestamp":"2026-04-15T14:35:12.456Z","level":"warning","message":"Lost connection to primary, will retry"}
GIM Categorization
GIM categorization is provided for the following event types:
| Event Type | gim_event_type_code | gim_event_type |
| Authentication (ACL login, auth failure, security attack) | 100000 | logon |
| Server startup | 210000 | service started |
| Server shutdown | 210100 | service stopped |
| Configuration change | 211000 | service configuration change |
| Sentinel state transition / failover | 211504 | service error |
| Crash report / replica connection loss | 211504 | service error |
| Out-of-memory panic | 211504 | service error |
| RDB / AOF persistence failure | 211504 | service error |
| Max clients reached (connection-limit DoS / leak) | 211504 | service error |
| Module load / unload (supply-chain audit) | 211000 | service configuration change |
| General events (replication, persistence, notices, warnings, slowlog) | 219999 | service event |
| Valkey (any mode) server startup | 210000 | service started |
| Valkey (any mode) server shutdown | 210100 | service stopped |
| Valkey (any mode) general events (replication, persistence, notices, warnings) | 219999 | service event |
Parsed Fields
| Field | Description | Example | Type |
| process_id | Redis server process ID | 87041 | string |
| vendor_redis_role | Redis instance role (M=Master, S=Slave, C=Child, X=Sentinel) | M | string |
| vendor_redis_role_description | Human-readable Redis role name derived from role character | master | string |
| vendor_event_severity | Redis log severity character (.=debug, -=verbose, *=notice, #=warning) | * | string |
| vendor_event_description | The core log message content | Server started, Redis version 7.2.4 | string |
| vendor_event_time | Timestamp from the standard Redis log line | 14:22:01.234 | string |
| vendor_event_epoch | Unix epoch timestamp from signal handler log events | 1744358400 | string |
| vendor_sentinel_event | Sentinel event type (e.g., +sdown, +odown, +failover) | +sdown | string |
| vendor_sentinel_target_type | Type of the Sentinel target (master, slave, sentinel) | master | string |
| vendor_sentinel_target_name | Name of the monitored instance | mymaster | string |
| vendor_sentinel_target_ip | IP address of the Sentinel target | 10.0.1.50 | ip |
| vendor_sentinel_target_port | Port of the Sentinel target | 6379 | int |
| vendor_slowlog_key | Key referenced in a slow query log entry | user:session:12345 | string |
| vendor_replication_backlog_bytes | Bytes of backlog sent during partial resync | 1234 | int |
| vendor_replication_offset | Replication offset value | 56789 | string |
| vendor_replication_id | Replication ID from full resync | 3e1b5c4a9f2d8e7b6c5a4f3e2d1c0b9a | string |
| vendor_replication_sync_type | Sync type when replica times out | streaming sync | string |
| source_ip | Client IP address (from Accepted or Client info logs) | 10.0.2.200 | ip |
| source_port | Client source port | 55123 | int |
| destination_ip | Redis server IP (from Client info laddr field) | 10.0.1.50 | ip |
| destination_port | Redis server port (from Client info laddr field) | 6379 | int |
| vendor_client_id | Redis client connection ID | 42 | string |
| vendor_client_cmd | Last command issued by the client | client|info | string |
| db_database_name | Redis OSS DB index (0-15) from CLIENT INFO | 0 | string |
| memory_total_bytes | Total memory consumed by the client connection in bytes | 22426 | int |
| user_name | Username from ACL authentication or client info | admin | string |
| event_action | Normalized event action verb derived by the pack (started, stopped, module_loaded, module_unloaded, max_clients_reached) | started | string |
| event_error_description | Matched failure phrase from the Redis log for persistence, sentinel, crash, or replica-loss events | Background saving error | string |
| event_severity | Normalized severity level name | informational | string |
| service_version | Redis or Valkey version captured from the startup banner | 7.2.4 | string |
| service_name | Service name, always set to redis | redis | string |
| application_name | Application name | redis-server | string |
Redis Spotlight Content Pack
Overview
