PostgreSQL Content Pack
PostgreSQL is an open-source relational database management system designed for reliability, standards compliance, and extensibility. It supports advanced data types, complex queries, transactional integrity, and robust access controls. PostgreSQL generates detailed operational, authentication, and query logs that can be parsed and enriched for monitoring and security analysis. This ability enables efficient search, correlation, and detection of database activity across diverse environments.
Supported Versions
  • PostgreSQL 18
  • Graylog 7.1+ with a valid Enterprise license
  • PostgreSQL with logging_collection on
  • Graylog Sidecar or standalone Filebeat agent installed on PostgreSQL system(s)
Stream Configuration
  • Illuminate:PostgreSQL Messages
Hint: If this stream does not exist prior to the activation of this pack then it is created and configured to route messages to this stream and the associated index set. There should not be any stream rules configured for this stream.
Index Set Configuration
  • PostgreSQL Logs
Hint: If this index set is already defined, then nothing is changed. If this index set does not exist, then it is created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Collection and Delivery
This pack was designed to use the Elastic Filebeat agent for log delivery. You can configure this integration using Graylog Sidecar. Collection of PostgreSQL logs should be performed from the manager and all agents.
This configuration requires that the account used to run the Graylog Sidecar/Filebeat agent has the necessary permissions to access the PostgreSQL log files. When running Sidecar/Filebeat with a non-root service account, you must grant that service account access to the log files.
Configuring PostgreSQL
PostgreSQL should be configured to generate stderr-formatted events. The jsonlog format is in beta and not fully tested. To use it, set the event_source_product in the filebeat configuration file to postgresql_json. The csvlog and syslog format are not supported.
Configuring Sidecar
  1. Refer to the official documentation to set up Graylog Sidecar for Filebeat.
  2. Create a matching Beats input in Graylog.
  3. Ensure that the option Do not add Beats type as prefix is disabled.
  4. Add the following example configuration snippet to your Filebeat configuration:
    Copy
    - type: filestream
    enabled: true
    paths:
    # Default PostgreSQL log paths (Debian/Ubuntu)
    - /var/log/postgresql/*.log
    # Default PostgreSQL log paths (RHEL/CentOS)
    - /var/lib/pgsql/data/log/*.log
    fields_under_root: true
    fields:
    event_source_product: postgresql
Hint: The configuration snippet provided is not a fully functional Filebeat configuration. It is only the section that adds PostgreSQL log ingestion to an existing configuration using the default PostgreSQL paths.
PostgreSQL Logs Format Examples
PostgreSQL has two log types. Some logs are directly related to database activities like updating a table, others are about the status of the database. Logs can be parsed with and without the header.
database.commands
statement: CREATE ROLE myuser GRANT analyst TO postgres; INSERT INTO dml_test VALUES (1); statement: INSERT INTO sales_archive SELECT * FROM sales WHERE sale_date < '2025-01-01'; 2026-02-13 05:02:38.447 GMT [1492] user=etl_user db=warehouse app=psql - CONN:1332777 client=10.10.5.23 LOG: statement: INSERT INTO sales_archive SELECT * FROM sales WHERE sale_date < '2025-01-01';
status.messages
connection authorized: user=postgres database=postgres application_name=pgAdmin 4 - DB:postgres
What Is Provided
  • Rules to parse, normalize, and enrich PostgreSQL log messages.
GIM Categorization - PostgreSQL logs
Categorization is assigned according to the vendor_event_action value.
vendor_event_action Event Description gim_event_type_code gim_event_category gim_event_subcategory gim_event_type
ALTER ROLE Database role database was modified 111000 iam iam.object modify account modified
ALTER TABLE Database table structure was modified 159999 database database.default database message
authentication failed Database user authentication attempt failed 100500 authentication authentication.credential validation credential validation
authorization denied Database authorization request was denied 100000 authentication authentication.logon logon
connection authenticated Database connection was successfully authenticated 100500 authentication authentication.credential validation credential validation
connection authorized Database connection was successfully authorized 100000 authentication authentication.logon logon
connection received Incoming database connection was received 120200 network network.open network connection initiated
CREATE Database object creation was performed 159999 database database.default database message
CREATE DATABASE New database was successfully created 151002 database database.add create database
CREATE ROLE New database role was successfully created 110000 database iam.object modify account modified
CREATE TABLE New database table was successfully created 151001 database database.add add table
DELETE FROM Database records were deleted from table 151500 database database.delete delete rows
disconnection Database client disconnected from server 102501 authentication authentication.logoff session disconnect
DROP DATABASE Existing database was permanently removed 151502 database database.delete drop database
DROP ROLE Existing database role was removed 110500 database iam.object modify account modified
DROP TABLE Existing database table was removed 151501 database database.delete drop table
DROP USER Existing database role was removed 110500 database iam.object modify account modified
failed authentication Database authentication attempt was unsuccessful 100500 authentication authentication.credential validation credential validation
GRANT Database privileges were granted to role 111000 iam iam.object modify account modified
INSERT INTO New records were inserted into table 151000 database database.add insert rows
log in User successfully logged into database 100501 authentication authentication.credential validation error
permission denied Database permission request was denied 100501 authentication authentication.credential validation error
RESET Database session database was reset 159999 database database.default database message
REVOKE Database privileges were revoked from role 159999 database database.default database message
SELECT Database records were queried from table 150000 database database.query database query
SET Database session database was changed 159999 database database.default database message
shut down Database system was shut down 210100 service service.stop service stopped
terminating connection Database connection was forcibly terminated 120300 network network.close network connection ended
TRUNCATE Database table contents were truncated 151500 database database.delete delete rows
TRUNCATE TABLE Database table contents were truncated 151500 database database.delete delete rows
UPDATE Database records were updated in table 150500 database database.update update rows
Most relevant PostgreSQL fields are listed below.
PostgreSQL Log Field Normalization
Used Database Fields:
Original Field Name Field Name Example Value Field Type Description
action vendor_event_action INSERT, SELECT string Native action
application_name application_name pgAdmin 4 string Client application name
client source_ip ::1 string Client source IP address
db db_database_name postgres string The database name
db_aggregate db_aggregate sum string The database aggregate function name
db_column db_column customer_id string The column name referenced in a database statement
db_constraint db_constraint orders_pkey string The database constraint name
db_constraint_type db_constraint_type PRIMARY KEY string The type of database constraint such as PRIMARY KEY or FOREIGN KEY
db_datatype db_datatype VARCHAR(255) string The data type defined or modified in a database statement
db_default db_default now() string The default value defined for a column
db_extension db_extension hstore string The database extension name
db_foreign_table db_foreign_table remote_orders string The foreign table name defined via foreign data wrapper
db_function db_function calculate_tax string The database function name
db_index db_index idx_orders_created_at string The database index name
db_new_column db_new_column tracking_id string The new column name after rename or creation
db_new_database_name db_new_database_name inventory string The new database name after rename
db_new_owner db_new_owner app_user string The new owner assigned to a database object
db_new_table db_new_table orders_archive string The new table name after rename
db_old_column db_old_column old_status string The previous column name before rename or alteration
db_old_table db_old_table orders_backup string The previous table name before rename
db_parameter db_parameter log_statement string The configuration parameter name modified in a statement
db_policy db_policy user_isolation string The row-level security policy name
db_procedure db_procedure update_account_balance string The database procedure name
db_publication db_publication orders_pub string The logical replication publication name
db_schema db_schema public string The database schema name
db_sequence db_sequence order_id_seq string The database sequence name
db_server db_server foreign_srv_1 string The foreign server name used for external connections
db_source_table db_source_table sales string The source table used in statements like INSERT ... SELECT or CREATE TABLE AS
db_subscription db_subscription orders_sub string The logical replication subscription name
db_table_name db_table_name orders string The database table name
db_trigger db_trigger update_timestamp string The database trigger name
db_type db_type status_enum string The database type name such as ENUM or composite type
db_view db_view active_users string The database view name
db_where_column db_where_column sale_date string The column referenced in a WHERE clause
db_where_value db_where_value 2025-01-01 string The value used in a WHERE clause condition
db_with_options db_with_options fillfactor=70 string The WITH clause options defined in a statement
error_severity vendor_event_severity ERROR string PostgreSQL native severity level
file_line_num source_file_line 1072 long Source code line number
file_name file_name postgres.c string Source code file generating log
func_name source_function exec_simple_query string PostgreSQL internal function name
Mapped event_category database string Normalized event category
Mapped event_error_description invalid_password string
Mapped event_outcome failure string Derived event outcome
Mapped event_severity error string Normalized event severity
Mapped event_severity_level 3 long Mapped numeric severity level
pid process_id 2310 long PostgreSQL backend process ID
port source_port 58806 long Client source port
query_id db_query_id 123456789 long PostgreSQL query identifier
remote_host source_ip 10.10.5.21 string Remote client IP address
remote_port source_port 55151 long Remote client port
session_id session_id 6971a5f3.1898 string PostgreSQL session identifier
session_start session_start 2026-01-22 04:22:11 GMT string Session start time
sql_state_code event_error_code 42804 string PostgreSQL SQLSTATE error code
target_user target_user_name John string If an administrator changes the user John, John is the target_user_name
timestamp event_created 2026-01-13 07:01:11.112 GMT string Original PostgreSQL log timestamp
txid transaction_id 0 long Transaction ID
user user_name postgres string It is the user that does an activity.
vtxid virtual_transaction_id 1/7 string Virtual transaction ID
