pfSense Firewall Content Pack
pfSense and OPNsense are free, open-source firewalls and router software based on FreeBSD. They provide advanced networking features and can be used in a variety of network configurations. This technology pack processes pfSense and OPNsense messages.
Supported Versions
pfSense CE edition 2.6
OPNsense 23.1
Graylog Server with a valid Enterprise license, running Graylog version 5.0.3+.
pfSense or OPNsense device configured with remote syslog forwarding (RFC 5424) to the Graylog server.
Stream Configuration
- "Illuminate:pfsense_firewall Messages"
Index Set Configuration
- "pfsense_firewall Logs"
Log Collection
The pack supports two routing methods to identify pfSense/OPNsense logs in Graylog. Choose either option.
Option 1: Route by Device Name
The name of the pfSense/OPNsense device must start with pfSense or OPNsense. These titles are case sensitive.
Option 2: Route via a Specific Syslog Input
In Graylog, create a new Syslog input on an unused port (or reuse an existing input dedicated to pfSense/OPNsense).
From the input, click Show received messages to obtain the input ID via the
gl2_source_inputvalue. -
Navigate to Enterprise > Illuminate > Customization.
Locate
lookup_adapter_input_routingand select Edit. -
Set content_name to
pfsense_firewalland input_id to thegl2_source_inputvalue copied earlier. -
Click Configure value to confirm. All logs sent to that input are processed by Illuminate as pfSense/OPNsense.
Configure pfSense / OPNsense
Enable remote logging on pfSense/OPNsense and configure the logging target.
Select the log sources to forward. Some services require setting changes to produce logs; most are not activated by default.
Set the Hostname to the IP of the Graylog server.
Set the Port to match the Syslog input in Graylog. The default protocol is UDP.
Enable syslog rfc5424.
Log Format Examples
Example logs for the core supported sources.
dhcpd (DHCP logs)
DHCPREQUEST for 192.168.1.50 from 52:54:00:06:aa:11 (tsterkal) via vtnet1
filterlog (Firewall logs)
71,,,1eb94a38e58994641aff378c21d5984f,vtnet0,match,block,in,4,0x0,,255,43376,0,DF,17,udp,73,192.168.122.40,224.0.0.251,5353,5353,53
nginx / lighttpd (Traffic logs)
192.168.1.50 192.168.1.10 - [23/Mar/2023:14:48:28 +0000] "GET /api/core/system/status HTTP/2.0" 200 317 "https://192.168.1.10/services_dhcp.php?if=lan" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
unbound (DNS logs)
[98871:0] query: 192.168.1.100 safebrowsing.googleapis.com. A IN
[61142:0] info: reply from <cnn.com.> 205.251.192.47#53
sshguard (SSHGuard logs)
Attack from "192.168.7.1" on service 100 with danger 10.
sshd (Login/Logout via SSH)
Accepted keyboard-interactive/pam for admin from 192.168.1.100 port 53214 ssh2
audit / php-fpm (Authentication)
/index.php: Successful login for user 'root' from: 192.168.1.50
login (Login to a shell)
login on ttyv0 as root
What is Provided
Rules to normalize and enrich pfSense and OPNsense log messages.
Field extraction, normalization, and message enrichment for pfSense/OPNsense log messages.
GIM Categorization for the supported event types.
Supported Logs
The pack parses logs from the following sources. Some are core supported sources; others have beta-level support.
dhcpd (DHCP logs)
nginx / lighttpd (Web traffic logs)
unbound (DNS query logs)
sshd (SSH login/logout)
GUI login (Web UI authentication)
sshguard (SSHGuard intrusion detection)
audit / php-fpm (Authentication and user management)
suricata (Intrusion detection, beta)
snort (Intrusion detection, beta)
kea-dhcp4 (Kea DHCP, beta)
openvpn (OpenVPN, beta)
charon (IPSec, beta)
dnsmasq, Bind/named (Alternative DNS, beta)
squid (Proxy server, beta)
tailscaled (Tailscale connections, beta)
GIM Categorization
GIM event type categorization is provided for the following messages:
| Event Type | GIM Category | GIM Subcategory |
| DHCPACK | dhcp | dhcp.acknowledgement |
| DHCPREQUEST | dhcp | dhcp.request |
| DHCPOFFER | dhcp | dhcp.offer |
| DHCPDISCOVER | dhcp | dhcp.discovery |
| DHCP4_INIT_REBOOT | dhcp | dhcp.default |
| DHCP4_LEASE_ADVERT | dhcp | dhcp.offer |
| DHCP4_LEASE_ALLOC | dhcp | dhcp.acknowledgement |
| ALLOC_ENGINE_V4_DISCOVER_ADDRESS_CONFLICT | dhcp | dhcp.discovery |
| EVAL_RESULT | dhcp | dhcp.default |
| network traffic | http | http.communication |
| GUI login | authentication | authentication.logon |
| GUI logout | authentication | authentication.logoff |
| ssh login | authentication | authentication.logon |
| login_failed | authentication | authentication.logon |
| pw_admin_change | iam | iam.object modify |
| pw_user_change | iam | iam.object modify |
| created user | iam | iam.object create |
| deleted user | iam | iam.object delete |
| snort alert | detection | detection.network_detection |
| suricata alert | detection | detection.network_detection |
| sshguard attack alert | detection | detection.network_detection |
| sshguard alert | detection | detection.network_detection |
| ipv4 traffic | network | network.network connection |
| ipv6 traffic | network | network.network connection |
| tailscale connection | network | network.network connection |
| ipv4 icmp traffic | network | network.default |
| ipv6 icmp traffic | network | network.default |
| ipv4 igmp traffic | network | network.default |
| snmpd connection | network | network.default |
| squid connection | http | http.proxied |
| dns query | name resolution | name resolution.dns request |
| dns response | name resolution | name resolution.dns answer |
pfSense/OPNsense Spotlight Content Pack
The pfSense/OPNsense Spotlight content pack offers two dashboards: an overview dashboard and a filterlogs and alerts dashboard.
Overview
Filterlogs and Alerts
