Palo Alto 9.x Content Pack
Palo Alto Networks next-generation firewalls provide real-time threat prevention, application visibility, and user-based policy enforcement. This technology pack processes Palo Alto PAN-OS 9.1+ logs, providing normalization and enrichment of common events of interest.
Supported Versions
PAN-OS 9.1+
PAN-OS 10.x
A Palo Alto device sending logs to the Graylog input Palo Alto Networks TCP (PAN-OS v9+).
Stream Configuration
- "Illuminate:Palo Alto Messages"
Index Set Configuration
- "Palo Alto Log Messages"
Log Collection
Palo Alto devices forward logs to Graylog via syslog using the dedicated PAN-OS v9+ input.
Configure the Graylog Input
In Graylog, navigate to System > Inputs and launch a Palo Alto Networks TCP (PAN-OS v9+) input.
Note the port number and save the input.
Configure the Palo Alto Device
On your Palo Alto firewall, navigate to Device > Server Profiles > Syslog and create a new syslog server profile.
Set the server IP address to your Graylog server IP and the port to match the Graylog input port.
Set the transport to TCP and the format to BSD.
Navigate to Device > Log Settings and assign the syslog server profile to the log types you wish to forward (Threat, Traffic, GlobalProtect).
Commit the configuration.
Log Format Examples
PAN-OS syslog messages are delivered in BSD syslog format with a CSV-encoded payload, parsed by the Graylog PAN-OS v9+ input.
GlobalProtect Log
<14>1 2021-03-08T14:10:27.137432Z PYTHON_TEST_SENDER - - - - 1,2020/04/01 10:49:58,015351000040055,13,0x0,GLOBALPROTECT,0,2305,2020/04/01 10:49:58,vsys1,portal-auth,login,Local Database,,phillip.price,192.168.0.0-192.168.255.255,WIN-VAL4395SQ3L,192.168.45.33,0.0.0.0,0.0.0.0,0.0.0.0,2c2ec970-de09-444c-b84f-2c0be75e13cd,,Browser,Windows,"Microsoft Windows 7 Service Pack 1, 64-bit",1,,Invalid username or password,"",failure,,0,user-logon,1,gp-portal
Threat Log (Spyware / Vulnerability)
<14>1 2021-03-08T14:08:28.296051Z PYTHON_TEST_SENDER - - - - 1,2020/05/19 07:37:34,007200002536,THREAT,spyware,2305,2020/05/19 07:37:34,10.154.229.167,77.254.254.254,,,General Business Apps,pancademo\andy.miller,,unknown-udp,vsys1,L3-TAP,L3-TAP,ethernet1/2,ethernet1/2,,2020/05/19 07:37:34,140539,1,1024,1024,0,0,0x2000,udp,drop-all-packets,"ZeroAccess.Gen Command and Control Traffic(13235)",13235,critical,server-to-client,6684613427694591054,0x0,10.0.0.0-10.255.255.255,10.0.0.0-10.255.255.255,0,1589874840,0,0,0,,us1,,,, 0,,0,,N/A,spyware,
Threat Log (URL Filtering)
<14>1 2021-03-08T13:35:29.030447Z PYTHON_TEST_SENDER - - - - 1,2020/05/19 07:37:25,007200002536,THREAT,url,2305,2020/05/19 07:37:25,10.154.172.203,74.125.224.99,,,General Web Infrastructure,pancademo\shane.long,,google-analytics,vsys1,L3-TAP,L3-TAP,ethernet1/2,ethernet1/2,ToUS1RAMA,2020/05/19 07:37:25,50003,1,56776,80,0,0,0x0,tcp,block-url,"analytics.google.com/analytics/r/collect (9999)",9999,informational,client-to-server,6684613427694591000,0x0,10.0.0.0-10.255.255.255,United States,0,1589874840,0,0,0,,us1,,,,0,,0,,N/A,computer-and-internet-info low-risk,
Traffic Log
<14>1 2021-03-08T14:09:00.000000Z PYTHON_TEST_SENDER - - - - 1,2020/05/19 07:38:00,007200002536,TRAFFIC,end,2305,2020/05/19 07:38:00,10.154.229.167,77.254.254.254,10.154.229.167,77.254.254.254,General Business Apps,pancademo\andy.miller,,web-browsing,vsys1,L3-TAP,L3-TAP,ethernet1/2,ethernet1/2,ToUS1RAMA,2020/05/19 07:38:00,140540,1,1024,443,0,0,0x400000,tcp,allow,4096,2048,2048,10,2020/05/19 07:37:50,10,any,,6684613427694591055,0x0,10.0.0.0-10.255.255.255,United States,,5,0,n/a,0,0,0,0,,us1,from-policy,
What is Provided
Parsing and normalization rules for Palo Alto PAN-OS 9.1+ logs.
Graylog Information Model (GIM) event type categorization for Traffic, Threat, URL Filtering, and GlobalProtect events.
This content pack supports the following PAN-OS log types:
GlobalProtect - portal authentication events (portal-auth).
Threat - intrusion detection alerts including spyware and vulnerability subtypes.
Threat (URL Filtering) - URL filtering block and alert events.
Traffic - network session events.
GIM Categorization
GIM event type categorization is provided for the following message types:
| Message Type | gim_event_type_code | gim_event_category | gim_event_class | gim_event_subcategory | gim_event_type |
| GlobalProtect portal-auth (login stage) | 100000 | authentication | authentication.logon | logon | |
| GlobalProtect portal-auth (login stage) | 100500 | authentication | authentication.credential validation | credential validation | |
| Traffic logs | 120000 | network | network.network connection | network connection | |
| Threat logs (spyware / vulnerability / url-filtering) | 300000 | detection | detection.network_detection | ids_detection |
Field Normalization
Fields extracted and normalized for each PAN-OS 9.x log type. The Graylog PAN-OS v9+ input pre-parses the CSV payload; pipeline rules rename and enrich fields to Illuminate standard names.
GlobalProtect Log Fields
| Illuminate Field | Vendor Field |
| event_observer_uid | Serial Number |
| event_observer_hostname | Device Name |
| vendor_subtype | Type (GLOBALPROTECT) |
| event_received_time | Generated Time |
| host_virtfw_id | Virtual System |
| vendor_event_name | Event ID (pan_event_name) |
| vendor_tunnel_stage | Stage (pan_tunnel_stage) |
| vendor_auth_method | Authentication Method (pan_auth_method) |
| user_name | Source User (source_user) |
| vendor_source_region | Source Region (pan_source_region) |
| source_hostname | Machine Name |
| source_ip | Public IP / Private IP (vendor_public_ip / vendor_private_ip) |
| vendor_gp_hostid | Host ID (pan_gp_hostid) |
| vendor_gp_client_version | Client Version (pan_gp_client_version) |
| host_type | Client OS |
| host_type_version | Client OS Version |
| event_repeat_count | Repeat Count |
| vendor_event_outcome_reason | Error (pan_gp_error) |
| vendor_event_outcome | Status (vendor_event_action) |
| event_outcome | Status (derived from vendor_event_outcome) |
| vendor_gp_connect_method | Connect Method (pan_gp_connect_method) |
| destination_hostname | Portal (pan_gp_hostname) |
| application_name | Application (set to "Global Protect") |
| gim_event_type_code | GIM Code (set to ["100000" "100500"]) |
Threat Log Fields (Spyware / Vulnerability)
| vendor_subtype | Type (THREAT) |
| vendor_log_subtype | Threat/Content Type (spyware / vulnerability) |
| source_ip | Source Address |
| destination_ip | Destination Address |
| rule_name | Rule Name |
| source_user_name | Source User (source_user — domain stripped) |
| source_user_domain | Source User Domain (extracted from domain\user) |
| destination_user_name | Destination User (destination_user — domain stripped) |
| destination_user_domain | Destination User Domain (extracted from domain\user) |
| application_name | Application |
| source_zone | Source Zone |
| destination_zone | Destination Zone |
| network_interface_in | Inbound Interface |
| network_interface_out | Outbound Interface |
| session_id | Session ID |
| source_port | Source Port |
| destination_port | Destination Port |
| network_transport | IP Protocol (network_protocol) |
| vendor_event_action | Action |
| event_action | Action (normalized via lookup) |
| alert_signature | Threat Name (alert_signature_id — name portion) |
| alert_signature_id | Threat ID (alert_signature_id — numeric portion) |
| vendor_alert_severity | Severity |
| alert_severity | Severity (normalized via lookup) |
| alert_severity_level | Severity Level (numeric) |
| vendor_alert_direction | Direction |
| event_uid | Sequence Number |
| source_location_name | Source Location |
| destination_location_name | Destination Location |
| vendor_threat_category | Threat Category |
| gim_event_type_code | GIM Code (set to ["300000"]) |
Threat Log Fields (URL Filtering)
| vendor_log_subtype | Threat/Content Type (url) |
| alert_indicator | URL/Filename |
| http_uri_category | Category (expanded to array) |
Traffic Log Fields
| vendor_subtype | Type (TRAFFIC) |
| vendor_log_subtype | Traffic Type (start / end / drop) |
| source_nat_ip | NAT Source IP |
| destination_nat_ip | NAT Destination IP |
| application_name | Application (network_application) |
| source_nat_port | NAT Source Port |
| destination_nat_port | NAT Destination Port |
| network_bytes | Total Bytes |
| source_bytes_sent | Bytes Sent (network_bytes_tx) |
| destination_bytes_sent | Bytes Received (network_bytes_rx) |
| network_packets | Total Packets (source + destination packets) |
| source_packets_sent | Packets Sent |
| destination_packets_sent | Packets Received |
| event_start | Start Time |
| event_duration | Elapsed Time |
| http_uri_category | Category |
| source_location_name | Source Country |
| destination_location_name | Destination Country |
| vendor_session_end_reason | Session End Reason |
| gim_event_type_code | GIM Code (set to ["120000"]) |
