OSSEC HIDS Content Pack
The OSSEC HIDS Processing Pack is designed to extract, normalize, and enrich OSSEC findings for more effective analysis and monitoring. It parses OSSEC HIDS logs into structured fields and adds useful context like event categorization (e.g., authentication). This enables faster search, correlation, and dashboarding across diverse environments.
  • Graylog 7.0.0+ with a valid Enterprise license
  • OSSEC manager configured to generate alerts.json
  • Graylog Sidecar or stand-alone Filebeat agent installed on OSSEC system(s)
  • OSSEC manager and agents use default log file names: ossec.log, alerts.json, firewall.log, active-responses.log
Supported Versions
  • OSSEC 3.7.0+
Log Collection and Delivery
This pack was designed to use the Elastic Filebeat agent for log delivery. This can be configured easily using the Graylog Sidecar. The collection of OSSEC logs should be performed from the manager and all agents.
This configuration requires that the account used to run the Graylog Sidecar/Filebeat agent have the necessary permissions to access the OSSEC log files. When running Sidecar/Filebeat with a non-root service account it will be necessary to grant that service account account access to the log files.
Configuring OSSEC
The OSSEC manager must be configured to generate JSON-formatted alerts.
  1. Edit the ossec.conf file on the OSSEC manager
  2. locate the<global>...</global>section in the OSSEC configuration
  3. Add the entry <jsonout_output>yes</jsonout_output> inside the OSSEC <global> section
  4. The result should look like:
    Copy
    <global>
    <email_notification>no</email_notification>
    </global>
Hint:OSSEC will not rotate the alerts JSON file, it is important to define a good rotation strategy for this file with logrotate.
Configuring Sidecar
  1. Please refer to the official documentation toset up Graylog Sidecar for Filebeat.
  2. Create a matching Beats input in Graylog.
  3. Ensure that the option Do not add Beats type as prefix is disabled.
  4. Add the following example configuration snippet to your Filebeat configuration for Linux systems:
    Copy
    - type: filestream
    enabled: true
    paths:
    - /var/ossec/logs/alerts/alerts.json
    - /var/ossec/logs/active-responses.log
    - /var/ossec/logs/firewall/firewall.log
    - /var/ossec/logs/ossec.log
    fields_under_root: true
    fields:
    event_source_product: ossec
  5. Add the following example configuration snippet to your Filebeat configuration for Windows systems:
    Copy
    filebeat.inputs:
    - type: filestream
    enabled: true
    paths:
    - 'C:\Program Files (x86)\ossec-agent\ossec.log'
    - 'C:\Program Files\ossec-agent\logs\ossec.log'
    parsers:
    - multiline:
    pattern: '^\d{4}/\d{2}/\d{2}'
    negate: true
    match: after
    fields:
Hint:The configuration snippet provided is not a fully functional filebeat configuration, it is only the section that adds OSSEC log ingestion to an existing filebeat configuration using the default OSSEC paths.
Hint:Illuminate does not support sending logs to Graylog using the OSSEC Syslog output. OSSEC sends syslog messages using UDP which can lead to some larger log messages being truncated.
Stream Configuration
  • Illuminate:OSSEC Log Messages
Hint:If this stream does not exist prior to the activation of this pack then it will be created and configured to route messages to this stream and the associated index set. There should not be any stream rules configured for this stream.
Index Set Configuration
  • OSSEC Log Messages
Hint:If this index set is already defined, then nothing will be changed. If this index set does not exist, then it will be created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
What is Provided
  • Rules to parse, normalize, and enrich OSSEC log messages.
  • A Spotlight containing a dashboard which can be used to analyze OSSEC log messages.
  • Graylog Information Model (GIM) categorization for authentication, IAM, network, audit, and detection alert categories.
  • Security Core coverage: 100000 (authentication.logon) for authentication groups with event_outcome distinguishing success/failure; 120000 (network.network_connection) for firewall events; 110000 (iam.object create) for adduser/account_changed alerts; 220500 (audit.policy) for policy_violation alerts; 300001 (detection.network_detection) for web attack, recon, IDS, SQL injection, XSS, and application security alerts; 301000 (detection.host_detection) for rootcheck/rootkit alerts.
  • Field normalization: vendor_srcip to source_ip, vendor_protocol lowercased to network_transport, vendor ports converted to long, host_hostname mapped to destination_reference, vendor_dstuser to user_name for IAM alerts.
  • SSH auth source-log parsing that extracts user_name and source_port from vendor_full_log.
OSSEC Logs Format Examples
OSSEC agents and managers generate multiple log files, each serving a distinct operational or security purpose:
  • alerts.json:JSON-formatted alert records generated by the OSSEC analysis engine. These entries represent detections produced by rules and decoders.Scope: OSSEC manager only.
  • ossec.log:Plain text service log containing messages related to OSSEC component startup, shutdown, internal state changes, errors, and operational warnings.Scope: All OSSEC systems (manager and agents).
  • active-responses.log:Plain text log recording the execution of active response actions (for example, command invocation, target address, and result). This log reflects what OSSEC attempted to do in response to an alert, not necessarily what the underlying system enforced.Scope:Any system with active responses enabled (manager and or agents).
  • firewall.log:Plain text log recording firewall-related activity associated with OSSEC active responses, such as IP blocking actions performed via firewall scripts (for example,firewall-drop.sh). Entries typically reflect actions taken by OSSEC against the local firewall rather than a complete record of firewall traffic. Scope:Systems where firewall-based active responses are executed (typically agents, but may include the manager if configured).
alerts.json
{"rule":{"level":2,"comment":"Unknown problem somewhere in the system.","sidid":1002,"firedtimes":2,"groups":["syslog","errors"]},"id":"1765569701.46775","TimeStamp":1765569701000,"location":"/var/log/syslog","full_log":"2025-12-12T20:01:41.366698+00:00 ossecmgr01 systemd[1]: Finished update-notifier-download.service - Download data for packages that failed at package install time.","hostname":"ossecmgr01","program_name":"systemd","decoder_desc":{},"agent_name":"ossecmgr01","timestamp":"2025 Dec 12 20:01:41","logfile":"/var/log/syslog"}
ossec.log
2025/12/05 23:31:54 INFO: Connected to 203.0.113.100 at address 203.0.113.100:1514, port 1514 2025/12/05 23:31:54 ossec-syscheckd: INFO: Monitoring directory: 'C:\\Windows/System32/at.exe', with options perm | size | owner | group | md5sum | sha1sum.
Thu Dec 4 08:30:14 PM UTC 2025 /var/ossec/active-response/bin/host-deny.sh add - 198.51.100.53 (from_the_server) (no_rule_id)
firewall.log
2025 Dec 05 14:03:47 (osseclabagt02) 198.51.100.254->/var/log/syslog UNKNOWN TCP 203.0.113.5:54321->192.0.2.10:22
GIM Categorization - OSSEC Alerts
Categorization is assigned according to the OSSEC alert signature ID which is stored in therule.sidid field in the source message, or alert_signature_id in the normalized message. These assignments are based on the default source ruleset included with OSSEC. The default rules can be found on the OSSEC manager, typically in the directory /var/ossec/rules/.
OSSEC SIDID/Range or Property Event Description gim_event_type_code gim_event_class gim_event_category gim_event_subcategory gim_event_type
authentication_failed/success/failures, invalid_login groups Authentication events 100000 authentication authentication.logon logon
adduser group New user account created 110000 iam iam.object create account created
account_changed group Existing account modified 111000 iam iam.object modify account modified
Firewall log events Firewall allow/deny events 120000 network network.connection network connection
593, 18118 Windows Audit Log Cleared 220000 endpoint audit audit.integrity audit log cleared
policy_violation group Policy violation alerts 220500 endpoint audit audit.policy audit policy changed
594-598 Windows Registry Integrity Events 259999 endpoint registry registry.default registry event
Registry syscheck events Windows Registry Integrity Events 259999 endpoint registry registry.default registry event
Ossec agent * signature Agent lifecycle events (started/stopped/disconnected) 289999 agent agent.default agent default
web, attacks, attack, ids, recon groups Web attack and recon detection 300001 detection detection.network_detection network_detection
rootcheck/rootkit groups Rootkit and host anomaly detection 301000 detection detection.host_detection host_malware_detection
550-555, File syscheck events File Integrity Finding 301003 detection detection.host_detection fim_detection
All other OSSEC SID IDs Implicit mapping for all other OSSEC alerts 301002 detection detection.host_detection hips_detection
OSSEC Alert Log Field Normalization
OSSEC alerts refer to the messages generated, stored, and collected from the file alerts.json. The OSSEC alerts log file will only be generated on the OSSEC manager.
Normalized Field Name OSSEC Source Property Notes
alert_category rule.groups
alert_signature rule.comment or rule.description The alert_signaturefield will be copied from the rule comment or description property, in that order.
alert_signature_id rule.sidid
file_hash_md5 SyscheckFile.md5_after File integrity events only.
file_hash_md5_previous SyscheckFile.md5_before File integrity events only.
file_hash_sha1 SyscheckFile.sha1_after File integrity events only.
file_hash_sha1_previous SyscheckFile.sha1_before File integrity events only.
file_path SyscheckFile.path File integrity events only.
host_hostname agent_name
host_ip agentip
registry_hash_md5 SyscheckFile.md5_after Registry integrity events only.
registry_hash_md5_previous SyscheckFile.md5_before Registry integrity events only.
registry_hash_sha1 SyscheckFile.sha1_after Registry integrity events only.
registry_hash_sha1_previous SyscheckFile.sha1_before Registry integrity events only.
registry_path SyscheckFile.path Registry integrity events only.
source_ip srcip
user_name various This will either be pulled fromsrcuser, dstuser, or extracted depending upon the OSSEC source message.
vendor_alert_severity_level rule.level
vendor_event_description rule.comment or rule.description For log cleared alerts only.
vendor_full_log full_log For log-based OSSEC alerts, a copy of the log used for the detection.
vendor_rule_firedtimes rule.firedtimes
vendor_source_user (parsed from full_log) SSH source log parsing: extracted user name from Failed/Accepted password logs.
vendor_source_port (parsed from full_log) SSH source log parsing: extracted source port.
vendor_source_ip (parsed from full_log) SSH source log parsing: extracted source IP.
vendor_dstuser dstuser Target user for IAM events (e.g. user being created).
source_user_name (mapped) Set to SOURCE_USER_NAME_NOT_DEFINED for IAM events.
event_outcome (mapped) Set to failure for authentication_failed alerts and blocked firewall actions.
application_name (mapped) Set to ossec for authentication events.
destination_reference (mapped) Set from host_hostname or host_ip for all alerts.
OSSEC System Log Field Extraction
The OSSEC system log messages are saved to the file ossec.log on the manager and all agents.
Normalized Field Name Example values Description
destination_hostname ossecmgr01 Hostname assigned to the target of an action described in the log.
destination_ip 203.0.113.24 Network IP address of the target system of an action described in the log.
destination_port 1514 Network service port of the target system of an action described in the log.
service_name OSSEC HIDS OSSEC service name.
vendor_event_action Starting OSSEC-defined action described in the log.
vendor_subtype system The log subtype for system messages.
OSSEC Firewall Log Field Extraction
The OSSEC firewall log messages are saved to the file firewall.logon the OSSEC systems were the activity is observed.
Field Name Description
destination_ip The IP address targeted by the network connection recorded in the firewall log entry.
destination_port The destination port number associated with the recorded network connection.
event_observer_ip The OSSEC-registered IP of the OSSEC agent that observed and reported the originating log event.
source_ip The remote IP address that initiated the network connection.
source_port The source port number used by the initiating host for the connection.
vendor_action The firewall action classification assigned by OSSEC (e.g., DROP, REJECT, UNKNOWN).
vendor_agent_name The OSSEC agent name reporting the event as recorded in the firewall log.
vendor_logfile The path to the original log file on the agent that triggered the firewall active response.
vendor_protocol The transport protocol (e.g., TCP, UDP, ICMP) extracted from the triggering event.
vendor_subtype The log subtype for OSSEC firewall log messages.
vendor_timestamp The timestamp applied by OSSEC when writing the firewall log entry.
event_action Normalized action: allowed for Allow actions, blocked for Drop/Deny/Block/Reject.
event_outcome Set to success for allowed actions, failure for blocked actions.
network_transport Normalized transport protocol (lowercased from vendor_protocol).
gim_event_type_code Set to 120000 (network connection) for all firewall events.
OSSEC Spotlight
overview
