NetFlow Content Pack
NetFlow is a network protocol that collects and monitors IP traffic flow data, providing insights into network usage, security threats, and performance. It helps analyze traffic patterns, detect anomalies, and troubleshoot network issues by capturing details such as source/destination IPs, ports, protocols, and bandwidth usage.
Supported Versions
NetFlow v5
NetFlow v9
IPFIX
Graylog Enterprise version 6.0.1+
Stream Configuration
- "Illuminate:NetFlow Messages"
Index Set Configuration
- "NetFlow Logs"
Log Format Example
NetFlowV5 [192.168.81.254]:67 <> [192.168.81.134]:68 proto:17 pkts:1 bytes:328
{"_destinationTransportPort":53,"_gl2_receive_timestamp":"2025-07-22 10:36:44.649","_sourceIPv4Address":"192.168.40.222","_ipClassOfService":0,"_gl2_processing_timestamp":"2025-07-22 10:36:44.670","_samplerId":1,"_egressInterface":0,"_octetDeltaCount":86,"_sourceTransportPort":33859,"_flowEndMilliseconds":"2025-07-22T10:30:48.527Z","_gl2_processing_duration_ms":21,"_destinationIPv4Address":"8.8.8.8","_tcpControlBits":0,"message":"Ipfix [192.168.40.222]:33859 <> [8.8.8.8]:53 proto:17 pkts:1 bytes:86","_ingressInterface":0,"_packetDeltaCount":1,"_ipVersion":4,"_flowDirection":0,"_protocolIdentifier":17,"_flowStartMilliseconds":"2025-07-22T10:30:48.514Z","host":"graylog","level":6,"version":"1.1","_replayed_log":"true"}
{"_destinationTransportPort":80,"_gl2_receive_timestamp":"2025-07-22 10:36:44.649","_sourceIPv4Address":"192.168.40.222","_ipClassOfService":0,"_gl2_processing_timestamp":"2025-07-22 10:36:44.686","_samplerId":1,"_egressInterface":0,"_octetDeltaCount":356,"_sourceTransportPort":35196,"_flowEndMilliseconds":"2025-07-22T10:31:24.921Z","_gl2_processing_duration_ms":37,"_destinationIPv4Address":"185.125.190.49","_tcpControlBits":27,"message":"Ipfix [192.168.40.222]:35196 <> [185.125.190.49]:80 proto:6 pkts:5 bytes:356","_ingressInterface":0,"_packetDeltaCount":5,"_ipVersion":4,"_flowDirection":0,"_protocolIdentifier":6,"_flowStartMilliseconds":"2025-07-22T10:31:24.519Z","host":"graylog","level":6,"version":"1.1","_replayed_log":"true"}
{"_destinationTransportPort":59236,"_gl2_receive_timestamp":"2025-07-22 10:34:44.594","_sourceIPv4Address":"91.189.91.49","_ipClassOfService":0,"_gl2_processing_timestamp":"2025-07-22 10:34:44.610","_samplerId":1,"_egressInterface":0,"_octetDeltaCount":405,"_sourceTransportPort":80,"_flowEndMilliseconds":"2025-07-22T10:16:25.342Z","_gl2_processing_duration_ms":16,"_destinationIPv4Address":"192.168.40.222","_tcpControlBits":27,"message":"Ipfix [91.189.91.49]:80 <> [192.168.40.222]:59236 proto:6 pkts:4 bytes:405","_ingressInterface":0,"_packetDeltaCount":4,"_ipVersion":4,"_flowDirection":0,"_protocolIdentifier":6,"_flowStartMilliseconds":"2025-07-22T10:16:24.513Z","host":"graylog","level":6,"version":"1.1","_replayed_log":"true"}
What is Provided
Rules to normalize and enrich NetFlow log messages.
Graylog Information Model categorization and enforcement fields for flow record and network connection events.
Log Collection
NetFlow utilizes the NetFlow input that ingests multiple NetFlow product type logs in JSON format.
The IPFIX UDP input can be configured in Graylog to receive flow data from a Linux-based exporter using PMACCT with NFPROBE support.
Configuring an IPFIX Input
For Graylog to receive IPFIX data, you must prepare the Linux source and configure the input:
Install PMACCT and NFPROBE on the Linux system. Verify installation and plugin support using:
pmacctd -V -
Create
/etc/pmacct/pmacctd.confand specify:-
Interface: The network interface to monitor.
Exporter IP: IP address of the Linux source.
Collector Address: Graylog server IP.
Port Number: Standard IPFIX port (4739).
Format: IPFIX.
Start the exporter using:
sudo /usr/local/sbin/pmacctd -f /etc/pmacct/pmacctd.conf -
Launch an IPFIX UDP input in Graylog and configure:
Bind Address: IP address of the Graylog node.
Port: Use standard port 4739.
Recv Buffer Size: Adjust as needed based on expected flow volume.
Generate network events from the Linux system and confirm that Graylog's IPFIX input is receiving messages.
Inspect the exported fields to ensure completeness and accuracy.
GIM Categorization
GIM categorization is provided for the following NetFlow log types:
| NetFlow Logtype | gim_event_type_code | GIM Category | GIM Subcategory | gim_event_type |
| All flow records | 120500 | network | network.flow | flow record |
| All flow records | 120000 | network | network.network connection | network connection |
NetFlow Overview Spotlight
The Illuminate Core Network Overview spotlight can be used to view NetFlow data.
