Microsoft DHCP Content Pack
DHCP is a network protocol used to assign IP addresses and other network configuration parameters dynamically to devices on a network. Microsoft provides DHCP server software as a component of its Windows Server operating system. The Microsoft DHCP server manages the automatic assignment of IP addresses to client devices on a network, reducing the need for manual configuration and helping to ensure a consistent and correct IP addressing scheme. This technology pack processes Microsoft DHCP server audit log files collected with the Filebeat agent, providing normalization and enrichment of DHCP lease and service lifecycle events.
Supported Versions
Windows Server 2016
Windows Server 2019
Windows Server 2022
Windows Server 2025
Windows DHCP Server.
Graylog Server with a valid Enterprise license, running Graylog version 4.3 or later.
Filebeat agent configured to collect DHCP audit logs and forward them to a Graylog Beats input.
Stream Configuration
- "Illuminate:Windows Event Log Messages"
Index Set Configuration
- "Windows Event Log Messages"
Log Collection
The DHCP audit log is stored in C:\Windows\System32\DHCP. A log file is created for
each day of the week. Filebeat is used to collect these files and forward them to a Graylog Beats input.
Create a Beats Input in Graylog
In Graylog, navigate to System > Inputs and launch a Beats input.
Configure the desired port number, then save and start the input.
Configure Filebeat
Edit the Filebeat configuration file (filebeat.yml) to collect DHCP logs. The fields section is required so Graylog routes logs to the correct processing
pipeline.
Set the
pathsentry toC:\Windows\System32\dhcp\*to collect all daily log files. -
Add
event_source_product: microsoft_dhcpunderfieldswithfields_under_root: true. -
Configure the
output.logstashsection to point to your Graylog server IP and Beats input port. -
Start Filebeat:
Start-Service filebeat
Log Format Example
10,01/27/23,12:44:33,Assign,192.168.1.10,DESKTOP-P423Q1J,C025A54DB363,,4092471859,0,,,,0x4D53465420352E30,MSFT 5.0,,,,0
11,01/27/23,14:38:40,Renew,192.168.1.11,DESKTOP-P423Q1J,C025A54DB363,,2272135476,0,,,,0x4D53465420352E30,MSFT 5.0,,,,0
12,01/30/23,15:27:28,Release,192.168.1.11,DESKTOP-P423Q1J,C025A54DB363,,3451374721,0,,,,,,,,,0
00,11/18/22,12:20:06,Started,,,,,0,6,,,,,,,,,0
01,11/18/22,12:20:06,Stopped,,,,,0,6,,,,,,,,,0
55,01/30/23,12:04:08,Authorized(servicing),,,,,0,6,,,,,,,,,0
56,11/18/22,12:20:06,Authorization failure, stopped servicing,,,,,0,6,,,,,,,,,0
15,01/30/23,16:58:03,NACK,172.16.14.67,,F8B156BAB90C,,0,6,,,,,,,,,0
13,01/27/23,12:44:36,Conflict,192.168.1.10,BAD_ADDRESS,,,0,6,,,,,,,,,0
What is Provided
Parsing rules to normalize and enrich Microsoft DHCP server audit log messages.
GIM categorization for DHCP lease events, service lifecycle events, and DHCP error conditions.
Field extraction for all standard DHCP audit log columns including client IP, hostname, MAC address, transaction ID, and vendor class information.
The Microsoft DHCP content pack supports parsing and GIM categorization for the following event types:
GIM Categorization
| Message Type | gim_event_type_code | gim_event_category | gim_event_class | gim_event_subcategory | gim_event_type |
| Service started (event ID 00) / Authorized servicing (event ID 55) | 210000 | service | endpoint | service.start | service started |
| Service stopped (event ID 01) / Stopped servicing (event ID 56) | 210100 | service | endpoint | service.stop | service stopped |
| IP address assigned to client (event ID 10) | 290300 | dhcp | protocol | dhcp.acknowledgement | dhcp acknowledgement |
| IP address lease renewed by client (event ID 11) | 290300 | dhcp | protocol | dhcp.acknowledgement | dhcp acknowledgement |
| IP address released by client (event ID 12) | 299999 | dhcp | protocol | dhcp.default | dhcp default event |
| IP address conflict detected (event ID 13) | 299999 | dhcp | protocol | dhcp.default | dhcp default event |
| DHCP scope address pool exhausted (event ID 14) | 299999 | dhcp | protocol | dhcp.default | dhcp default event |
| DHCP lease request denied / NACK (event ID 15) | 299999 | dhcp | protocol | dhcp.default | dhcp default event |
| Lease deleted from database (event ID 16) | 299999 | dhcp | protocol | dhcp.default | dhcp default event |
| All other audit log entries (audit log paused / DNS updates / cleanup / informational) | 000000 | message | message.log_message | message |
Fields Extracted by This Pack
Event IDs
Event IDs supported with parsing and GIM categorization.
| Event ID | Description | GIM Category |
| 00 | The DHCP audit log was started (service start) | service.start (210000) |
| 01 | The DHCP audit log was stopped (service stop) | service.stop (210100) |
| 02 | The audit log was temporarily paused due to low disk space | message (000000) |
| 10 | A new IP address was leased to a client | dhcp.acknowledgement (290300) |
| 11 | A lease was renewed by a client | dhcp.acknowledgement (290300) |
| 12 | A lease was released by a client | dhcp.default (299999) |
| 13 | An IP address was found to be in use on the network (conflict) | dhcp.default (299999) |
| 14 | A lease request could not be satisfied — scope address pool exhausted | dhcp.default (299999) |
| 15 | A lease was denied (DHCPNAK sent to client) | dhcp.default (299999) |
| 16 | A lease was deleted from the database | dhcp.default (299999) |
| 17 | A lease expired and DNS records have not been deleted | message (000000) |
| 18 | A lease expired and DNS records were deleted | message (000000) |
| 20 | A BOOTP address was leased to a client | message (000000) |
| 24 | IP address cleanup operation has begun | message (000000) |
| 25 | IP address cleanup statistics | message (000000) |
| 30 | DNS dynamic update request sent to DNS server | message (000000) |
| 31 | DNS dynamic update failed | message (000000) |
| 32 | DNS dynamic update successful | message (000000) |
| 55 | DHCP server authorized in AD DS and actively servicing clients | service.start (210000) |
| 56 | DHCP server stopped servicing clients (authorization failure or revocation) | service.stop (210100) |
| 61 | Server found that belongs to DS domain | message (000000) |
| 64 | No static IP address bound to DHCP server | message (000000) |
Parsed Fields
Fields extracted from all Microsoft DHCP audit log messages.
| Field Name | Description |
| event_id | Numeric DHCP audit log event ID (e.g. 10 = Assign / 11 = Renew / 12 = Release) |
| vendor_event_description | Human-readable event description from the DHCP audit log (e.g. Assign / Renew / Release / Started) |
| source_ip | IP address of the DHCP client involved in the event |
| source_hostname | Hostname of the DHCP client as recorded by the server |
| source_mac | MAC address of the DHCP client (format: hex without delimiters e.g. C025A54DB363) |
| user_name | Username associated with the client request (if present) |
| vendor_transaction_id | DHCP transaction ID for the lease operation |
| vendor_qresult | Query result code returned by the DHCP server |
| vendor_probation_time | Probation time value from the log entry (if present) |
| vendor_correlation_id | Correlation ID for the DHCP transaction (if present) |
| vendor_dhcid | DHCP unique identifier (DHCID) for the client (if present) |
| vendor_class_hex | Vendor class identifier in hexadecimal (e.g. 0x4D53465420352E30) |
| vendor_class_ascii | Vendor class identifier decoded as ASCII (e.g. MSFT 5.0) |
| vendor_user_class_hex | User class identifier in hexadecimal (if present) |
| vendor_user_class_ascii | User class identifier decoded as ASCII (if present) |
| vendor_relay_agent_information | Relay agent information option (Option 82) value (if present) |
| vendor_dns_reg_error | DNS registration error code (0 = no error) |
| event_log_path | Full path of the DHCP audit log file from which the event was read |
| event_reporter_hostname | Hostname of the Windows server running the Filebeat agent |
| event_reporter_ip | IP address of the Windows server running the Filebeat agent |
| event_reporter_mac | MAC address of the Windows server running the Filebeat agent |
| event_reporter_id | Unique identifier of the Filebeat host |
| event_uid | Unique event identifier assigned by the Filebeat agent |
| event_source_product | Source product identifier (value: microsoft_dhcp) |
| file_type | Log file type as identified by Filebeat |
| service_name | Name of the DHCP service (value: Microsoft DHCP Server — set for service lifecycle events 210000 / 210100) |
| gim_event_type_code | Assigned GIM event type code(s) (e.g. 210000 / 210100 / 290300 / 299999) |
| gim_event_type | Human-readable GIM event type label corresponding to the assigned code |
