HAProxy LoadBalancer Content Pack
HAProxy is an open-source software solution that provides a high-performance and highly available TCP and HTTP load balancer and proxy server. This technology pack will process HAProxy logs, providing normalization and enrichment of common events of interest.
Supported Version(s)
  • Tested with HAProxy version 2.9
  • Logging via syslog (RFC 5424 format recommended) or Filebeat with Graylog Sidecar.
  • HAProxy HTTP/TCP server on a Linux system.
  • A syslog or Beats input configured in Graylog matching the IP, port, and protocol for log reception.
Stream Configuration
  • "Illuminate:HAProxy LoadBalancer Messages"
Index Set Configuration
  • "HAProxy LoadBalancer Messages"
Log Collection
HAProxy supports the following log delivery methods:
  • Syslog (RFC 5424 format recommended)
  • Filebeat with Graylog Sidecar
Syslog Configuration
Configure HAProxy to send logs via syslog to your Graylog server.
  1. Create a Syslog input in Graylog matching the IP, port, and protocol for log reception.
  2. Configure HAProxy to send logs to the Graylog syslog input. Refer to the official HAProxy logging documentation for configuration details.
Please use the official Graylog Sidecar documentation to configure your Graylog server and your client(s).
  1. Create a Beats input in Graylog.
  2. Install Graylog Sidecar on the HAProxy host.
  3. Configure Filebeat to collect HAProxy log files and forward them to the Graylog Beats input.
Log Format Examples
HAProxy supports multiple log formats depending on the proxy mode configuration.
Connection Log (Default)
haproxy[1234]: Connect from 10.0.1.2:33312 to 10.0.3.31:8012 (www/HTTP)
Error Log
haproxy[6103]: 127.0.0.1:56059 [03/Dec/2023:17:35:10.380] frt/f1: Connection error during SSL handshake
TCP Log
haproxy[14387]: 10.0.1.2:33313 [06/Feb/2023:12:12:51.443] fnt bck/srv1 0/0/5007 212 -- 0/0/0/0/3 0/0
HTTP Log
haproxy[14329]: 10.0.1.2:33317 [06/Feb/2023:12:14:14.655] http-in static/srv1 10/0/30/69/109 200 2750 - - ---- 1/2/3/4/5 6/7 {graylog.eu} {} "GET /index.html HTTP/1.1"
HTTPS Log
haproxy[1234]: 10.0.1.2:36317 [06/Feb/2023:12:14:14.655] https-in static/srv1 10/0/30/69/109 200 2750 - - ---- 1/2/3/4/5 6/7 {graylog.eu} {} "GET /index.html HTTP/1.1" 0/0/0/0/0 graylog.eu/TLSv1.3/TLS_AES_256_GCM_SHA384
What is Provided
  • Parsing rules to extract HAProxy logs into Graylog schema-compatible fields.
  • GIM code 180200 (http communication) for HTTP/HTTPS proxy logs.
  • GIM code 120000 (network connection) for TCP proxy logs and default connection logs.
  • Event action detection from HAProxy termination state codes (allowed/blocked).
  • Event severity mapping from syslog priority levels.
  • Termination reason enrichment from HAProxy termination state codes.
  • HAProxy Spotlight dashboards.
GIM Categorization
GIM categorization is provided for the following log types:
Log Type gim_event_type_code gim_event_category gim_event_subcategory gim_event_type
HTTP/HTTPS proxy logs 180200 http http.communication http communication
TCP proxy logs 120000 network network.network connection network connection
Default connection logs 120000 network network.network connection network connection
General Parsing
Connection (Default) Logs
Default Fields for TCP/HTTP and HTTPS Logs
TCP Logs
HTTP/HTTPS Logs
Error Logs
HAProxy LoadBalancer Spotlight
The HAProxy Spotlight offers dashboards with five tabs:
Overview
Default Logs
TCP Logs
HTTP/HTTPS Logs
Error Dashboard
