F5 BIG-IP Content Pack
F5 BIG-IP is an application delivery controller platform that combines load balancing, traffic management, and security services to optimize, secure, and scale networked applications.
Supported Versions
  • F5 BIG-IP ASM 17.5.1
  • F5 BIG-IP AFM 17.5.1
Supported Log Types
  • ASM, AFM
  • For TMM logs: HTTP_RESPONSE, HTTP_REQUEST
  • Configure F5 BIG-IP to transmit Syslog to your Graylog server Syslog input.
Stream Configuration
  • Illuminate:F5 Messages
Hint: If this stream does not exist prior to the activation of this pack then it is created and configured to route messages to this stream and the associated index set. There should not be any stream rules configured for this stream.
Index Set Configuration
  • F5 Bigip Messages
Hint: If this index set is already defined, then nothing is changed. If this index set does not exist, then it is created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Collection
This pack parses logs from the following sources:
  • Filebeat
  • Syslog (beta support)
  • CEF (beta support)
Filebeat Configuration
  1. Refer to the official documentation to set up Graylog Sidecar for Filebeat.
  2. Create a matching Beats input in Graylog.
  3. Ensure that the option Do not add Beats type as prefix is disabled.
  4. Create an API access token and custom Windows Filebeat collector.
  5. Configure the collector to ship messages to Graylog (select the right path). The Filebeat input must add the field event_source_product: f5_bigip for the parser to identify the log source as F5 BIG-IP.
  6. The option fields_under_root must be set to true for message identification to work. See the following example:
    Copy
    filebeat.inputs:
    - type: log
    enabled: true
    paths:
    - /var/log/f5/*.log
    fields:
    fields_under_root: true
  7. Adjust the file path in the configuration file if needed.
  8. Install Graylog Sidecar on the client host.
  9. Edit the Graylog Sidecar client configuration with your Graylog server API URL and API access token.
Sending Logs via Syslog
F5 BIG-IP supports Syslog. This content pack may support F5-BIG-IP Syslog for the modules ASM and AFM.
Sending Logs in CEF Format
F5 BIG-IP supports the CEF format. This content pack may work with CEF and Graylog's CEF Input, but due to a lack of example logs, the full function cannot be guaranteed. If you want to use CEF and you have test logs, please provide us with some sanitized samples.
Log Format Examples
Apr 10 09:25:46 172.16.1.2 ASM:unit_hostname="f5_01",management_ip_address="192.168.1.10",management_ip_address_2="N/A",http_class_name="/Common/App_WAF",web_application_name="/Common/App_WAF",policy_name="/Common/App_WAF",policy_apply_date="2025-04-08 2:29:51",violations="N/A",support_id="142371702665",request_status="passed",response_code="200",ip_client="11.10.5.46",route_domain="0",method="GET",protocol="HTTPS",query_string="",x_forwarded_for_header_value="11.10.5.2",sig_ids="N/A",sig_names="N/A",date_time="2025-04-10 2:25:46",severity="Informational",attack_type="N/A",geo_location="RO",ip_address_intelligence="N/A",username="N/A",session_id="C3c1eaf29ce05e59",src_port="51124",dest_port="443",dest_ip="172.16.1.11",sub_violations="N/A",virus_name="N/A",violation_rating="0",websocket_direction="N/A",websocket_message_type="N/A",device_id="N/A",staged_sig_ids="",staged_sig_names="",threat_campaign_names="N/A",staged_threat_campaign_names="N/A",blocking_exception_reason="N/A",captcha_result="not_received",microservice="N/A",tap_event_id="N/A",tap_vid="N/A",vs_name="/Common/vs-443-2021-apptest1.dom.ro-bkp",sig_cves="N/A",staged_sig_cves="N/A",uri="/notif/summary",fragment="",request="GET /notif/summary HTTP/1.1\r\nHost: apptest.dom.ro\r\nConnection: keep-alive\r\nsec-ch-ua-platform: %22Windows%22\r\nUser-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36\r\nsec-ch-ua: %22Google Chrome%22;v=%22135%22, %22Not-A.Brand%22;v=%228%22, %22Chromium%22;v=%22135%22\r\nsec-ch-ua-mobile: ?0\r\nAccept: */*\r\nSec-Fetch-Site: same-origin\r\nSec-Fetch-Mode: cors\r\nSec-Fetch-Dest: empty\r\nAccept-Encoding: gzip, deflate, br, zstd\r\nAccept-Language: en-US,en;q=0.9,ro;q=0.8\r\nCookie: _ga=GA1.1.845057894.1744101172; SESSION=6dceff56-9d1e-421c-ab0e-820e91591bf8; _ga_X2KD43T4E2=GS1.1.1744263.4.1.14265953.0.0.0; TS67d45652027=08fbd28c49065a7bf1423084f5cc3e81130007f7d872e9d324682b29696
Apr 10 2:25:46 172.16.1.2 AFM:acl_rule_name="",action="Open",hostname="bigip-3.pme-ds.f5.com",bigip_mgmt_ip="192.168.73.33",context_name="/Common/topaz3-all3",context_type="Virtual Server",date_time="Oct 04 2012 13:18:04",dest_ip="10.3.1.200",dest_port="443",device_product="Advanced Firewall Module",device_vendor="F5",device_version="11.3.0.2095.0",drop_reason="",errdefs_msgno="23003137",errdefs_msg_name="Network Event",ip_protocol="TCP",severity="8",partition_name="Common",route_domain="0",source_ip="10.3.1.101",source_port="39329",vlan="/Common/external"
Apr 10 2:24:59 172.16.1.2 1 2025-04-10T2:25:46.854685+03:00 f5_short tmm 8545 23003147 [F5@12276 hostname="f5_01" bigip_mgmt_ip="192.168.1.10" bigip_mgmt_ip2="::" client_ip="46.97.34.38" client_ip_geo_location="RO" client_port="28220" client_request_uri="/version.json"]
What Is Provided
  • Parsing rules to extract F5 BIG-IP logs (AFM, ASM) into Graylog schema compatible fields.
  • Simple dashboard with a general Overview and an Overview for ASM logs.
GIM Categorization
vendor_event_type gim_event_type_code
DNS Event 149999
Network Event 120000
General Parsing
F5 BIG-IP Spotlight Pack
This F5 BIG-IP spotlight has a general overview and an ASM overview dashboard
F5 BIG-IP: Overview Tab
F5 BIG-IP ASM Overview Tab
