Cisco Meraki Content Pack
Cisco Meraki is a hardware vendor and sells cloud-controlled security appliances (firewalls), switches, and access points via a centralized managed platform. This technology pack processes Cisco Meraki logs, providing normalization and enrichment of common events of interest.
Supported Version(s)
  • Up to MX16.9+
  • Up to MR30.x
Supported Event Types
MR (Wireless): association, disassociation, wpa_auth, wpa_deauth, wpa_client_deauth, 8021x_auth, 8021x_deauth, 8021x_client_deauth, 8021x_eap_success, 8021x_eap_failure, 8021x_guest_auth, 8021x_critical_auth, splash_auth, mac_spoofing_attack, multiple_dhcp_servers_detected, device_packet_flood, rogue_ssid_detected, ssid_spoofing_detected, aps_association_reject, dfs_event
MX (Security Appliance): flows, ip_flow_start, ip_flow_end, firewall, vpn_firewall, cellular_firewall, bridge_anyconnect_client_vpn_firewall, urls, ids-alerts, security_event (ids_alerted, security_filtering_file_scanned, security_filtering_disposition_change), authentication, dhcp, content_filtering_block, nbar_block, anyconnect_vpn_connect, anyconnect_vpn_disconnect, anyconnect_vpn_auth_success, anyconnect_vpn_auth_failure, client_vpn_connect, client_vpn_disconnect, vrrp, vpn_connectivity_change, route_connection_change
  • Configure Cisco Meraki to transmit Syslog to your Graylog server Syslog input.
Stream Configuration
  • "Illuminate:Cisco Device Messages"
Hint: If this stream does not exist prior to the activation of this pack then it is created and configured to route messages to this stream and the associated index set. There should not be any stream rules configured for this stream.
Index Set Configuration
  • "Cisco Devices Event Log Messages"
Hint: If this index set is already defined, then nothing is changed. If this index set does not exist, then it is created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Format Examples
1 1619032507.590967163 ip_flow_end src=1.1.1.1 dst=2.2.2.2 protocol=icmp translated_dst_ip=4.4.4.4
1 1619032507.495518695 DEVICE_NAME flows src=1.1.1.1 dst=2.2.2.2 protocol=udp sport=1900 dport=1900 pattern: 1 all
What is Provided
  • Parsing rules to extract Cisco Meraki logs into Graylog schema-compatible fields.
  • Graylog Information Model categorization and enforcement fields for authentication, network flow, IDS/IPS, HTTP, and DHCP events.
GIM Categorization
