Cisco ISE Content Pack
Cisco Identity Services Engine (ISE) is a robust, centralized network security policy management platform. It enables organizations to enforce secure access policies for endpoints, network devices, and users across wired, wireless, and VPN networks.
Supported Version(s)
- Identity Services Engine 3.2
Graylog 6.1.7+
The default length of remote log target messages configured in the Cisco ISE GUI is set to 1024. This will truncate messages and prevent proper parsing by Illuminate. You MUST configure this value to be 8192 so the full message is sent to Graylog. See the Cisco documentation for more information.
Stream Configuration
"Illuminate:Cisco Device Messages"
Index Set Configuration
"Cisco Devices Event Log Messages"
Log Collection
You can choose to send logs via syslog or raw format (TCP or UDP). Please note that Cisco products often include timestamps in logs that may not be compatible with Graylog. If this occurs, we recommend you send logs to a raw input. See the Graylog documentation for information on different input types.
full_message option in the input if needed.
Log Format Example
<18>Jul 31 03:39:53 DEVICE-01 CISE_Failed_Attempts 0000001161 1 0 2024-12-18 13:10:56.252 +00:00 0045534800 5440 NOTICE RADIUS: Endpoint abandoned EAP session and started new, ConfigVersionId=53, Device IP Address=192.168.1.1, DestinationIPAddress=192.168.1.1, UserName=blah.blah, AcsSessionID=ATH-ISE-POL03/522862485/1041418, SelectedAccessService=RADIUS 802.1X Wireless, RequestLatency=36, FailureReason=5440 Endpoint abandoned EAP session and started new, Step=11001, Step=11017, Step=15049, Step=15008, Step=15048, Step=15048, Step=15048, Step=15048, Step=15048, Step=11507, Step=12500, Step=12625, Step=11006, Step=11001, Step=11018, Step=12301, Step=12300, Step=12625, Step=11006, Step=11001, Step=11018, Step=12302, Step=12319, Step=12800, Step=12805, Step=12806, Step=12807, Step=12808, Step=12810, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12319, Step=12810, Step=12812, Step=12803, Step=12804, Step=12801, Step=12802, Step=12816, Step=12310, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=12313, Step=11521, Step=12305, Step=11006, Step=11001, Step=11018, Step=12304, Step=11522, Step=11806, Step=12305, Step=11006, Step=5440, NetworkDeviceName=HOME-HOME, NetworkDeviceGroups=Location#All Locations#HOME#HOME, NetworkDeviceGroups=Device Type#All Device Types#Wireless Controller, NetworkDeviceGroups=IPSEC#Is IPSEC Device#No, EapTunnel=PEAP, EapAuthentication=EAP-MSCHAPv2, User-Name=blah.blah, NAS-IP-Address=192.168.1.1, NAS-Port=1615, Called-Station-ID=HOME-AP1:Digital, Calling-Station-ID=1e-f7-a9-dd-d3-f7, NAS-Identifier=HOME-HOME:Home Digital, NAS-Port-Type=Wireless - IEEE 802.11, CPMSessionID=0B10A8C000171CA2D9E45D65, EndPointMACAddress=01-01-01-01-01-01, ISEPolicySetName=802.1X Wireless - Digital, StepLatency=84=13745, StepData=4= DEVICE.Device Type, StepData=5= Radius.NAS-Port-Type, StepData=6= Normalised Radius.RadiusFlowType, StepData=7= Radius.Called-Station-ID, StepData=8= DEVICE.Location, TLSCipher=ECDHE-RSA-AES256-GCM-SHA384, TLSVersion=TLSv1.2, DTLSSupport=Unknown, RadiusFlowType=Wireless802_1x, Network Device Profile=Cisco, Location=Location#All Locations#HOME#HOME, Device Type=Device Type#All Device Types#Wireless Controller, IPSEC=IPSEC#Is IPSEC Device#No, Response={RadiusPacketType=Drop; },
The Cisco ISE content pack supports the following event IDs. Generic processing will be provided for event IDs not listed.
Parsed Fields
| Event Code | Event Message |
| 5200 | Authentication succeeded |
| 5201 | Authentication succeeded |
| 5202 | Command Authorization succeeded |
| 5203 | Session Authorization succeeded |
| 5205 | Dynamic Authorization succeeded |
| 5238 | Endpoint authentication problem was fixed |
| 5240 | Previously rejected endpoint was released to continue authentications |
| 5400 | Authentication failed |
| 5405 | RADIUS Request dropped |
| 5411 | Supplicant stopped responding to ISE |
| 5435 | NAS conducted several failed authentications of the same scenario |
| 5436 | RADIUS packet already in the process |
| 5440 | Endpoint abandoned EAP session and started new |
| 5441 | Endpoint started new session while the packet of previous session is being processed. Dropping new session. |
| 5449 | Endpoint failed authentication of the same scenario several times and was rejected |
GIM Categorization
| Vendor Event Message | GIM Category | GIM Subcategory | GIM Event Type Code |
| Authentication succeeded | authentication | authentication.default | 109999 |
| Command Authorization succeeded | authentication | authentication.default | 109999 |
| Dynamic Authorization succeeded | authentication | authentication.default | 109999 |
| Previously rejected endpoint was released to continue authentications | authentication | authentication.default | 109999 |
| Endpoint authentication problem was fixed | authentication | authentication.default | 109999 |
| Session Authorization succeeded | authentication | authentication.default | 109999 |
Cisco ISE Spotlight Content Pack
Cisco ISE offers a dashboard with 3 tabs:
Cisco ISE Overview
Authentication
Network
