Check Point Firewall Content Pack
Check Point Next Generation Firewall (NGFW) is an advanced security solution that combines traditional firewall features with intrusion prevention, antivirus, and application control capabilities to enhance network security. It inspects traffic at both the network and application levels, providing granular control over network traffic and preventing the spread of malware and cyber threats.
This technology pack processes Check Point NGFW logs, providing normalization and enrichment of those events.
Supported Version(s)
Check Point R81.2.0
Check Point NGFW version R81.x.
Graylog Server with a valid Enterprise license, running Graylog version 4.3 or later.
Ensure the Check Point device is configured to export logs in a format compatible with Graylog Illuminate parsers. Refer to the Check Point Log Exporter Administration Guide for setup instructions.
Stream Configuration
- "Illuminate:Checkpoint Messages"
Index Set Configuration
- "Checkpoint Logs"
Log Collection
Sending logs via Syslog
Log Format Example
[flags:"147456"; ifdir:"inbound"; loguid:"{0x5b691e76,0xf,0x670111ac,0xc0000017}"; origin:"192.168.10.75"; originsicname:"cn=cp_mgmt,o=CHKP_R81..b792qm"; sequencenum:"11"; time:"1677752746"; version:"5"; attack:"Security Products Enforcement Violation"; attack_info:"Netis/Netcore Router Hard-Coded Backdoor"; confidence_level:"5"; description_url:"NETIS_R_help.html"; performance_impact:"3"; product:"SmartDefense"; protection_id:"asm_dynamic_prop_NETIS_R"; protection_name:"Netis/Netcore Router Hard-Coded Backdoor"; protection_type:"IPS"; severity:"3"; smartdefense_profile:"Optimized"; src:"192.168.11.55"]
[action:"Drop"; flags:"393216"; ifdir:"inbound"; ifname:"eth1"; logid:"0"; loguid:"{0x641438da,0x1,0x4b0aa8c0,0x13dca7b3}"; origin:"192.168.10.75"; originsicname:"cn=cp_mgmt,o=gw-chkp..2hw9xr"; sequencenum:"2"; time:"1679046874"; version:"5"; __policy_id_tag:"product=VPN-1 & FireWall-1[db_tag={5F246403-00BB-E743-9690-C36A9C7FE416};mgmt=gw-chkp;date=1679046655;policy_name=Standard\]"; dst:"142.250.192.13"; layer_name:"Network"; layer_uuid:"f5cec687-05e5-4573-b1dc-08119f24cbc9"; match_id:"1"; parent_rule:"0"; rule_action:"Drop"; rule_name:"Block Client IP"; rule_uid:"f566bb6e-b41b-4e41-b67d-da0ef3aa1d08"; product:"VPN-1 & FireWall-1"; proto:"6"; s_port:"49243"; service:"443"; service_id:"https"; src:"192.168.11.65"]
[action:"Accept"; flags:"163872"; ifdir:"outbound"; loguid:"{0x63dd128a,0xc3,0x6efea8c0,0xdd49b9f}"; origin:"192.168.10.75"; originsicname:"cn=cp_mgmt,o=CHKP_R81..b792qm"; sequencenum:"1"; time:"1675938823"; version:"5"; administrator:"admin"; client_ip:"192.168.10.71"; machine:"192.168.10.71"; operation:"Log Out"; operation_number:"12"; product:"query-database"; subject:"Administrator Login"]
What Is Provided
We provide parsing rules to normalize and enrich Check Point Next Generation Firewall log messages, including:
URL Filtering
Smart Dashboard
Log Update
Security Management
CPM Server
Smart Console
Query Database
Endpoint Management
Smart Defense
Endpoint Security Console
Web API
VPN-1 & Firewall-1
We provide categorization for the following log types:
SmartDefense Alert logs
Network logs
Authentication logs
The Check Point Next Generation Firewall content pack supports parsing for all fields, and GIM categorization for network events, SmartDefense alert events, and authentication events.
GIM Categorization
| Log Type | gim_event_type_code | gim_event_category | gim_event_subcategory | gim_event_type |
| Log In (success/failure) | 100000 | authentication | authentication.logon | logon |
| Log Out | 102500 | authentication | authentication.logoff | logoff |
| VPN/Firewall traffic | 120000 | network | network.network connection | network connection |
| SmartConsole, SmartDashboard, Management events | 229999 | audit | audit.default | audit event |
| SmartDefense (IPS alerts) | 300000 | detection | detection.network_detection | ids_detection |
| URL Filtering, Application Control, Anti-Bot, Anti-Virus, Threat Emulation, IPS | 300001 | detection | detection.network_detection | network_detection |
Check Point NGFW Spotlight
The Check Point NGFW Spotlight comes bundled with the Check Point Firewall content pack. This spotlight pack contains the following dashboards:
Overview
Network
Alerts
Authentication
