Bitdefender Telemetry Content Pack
Bitdefender telemetry data aggregates threat indicators, system events, and configuration details from endpoints. This pack parses Bitdefender EDR telemetry data from GravityZone and OnPrem systems, providing normalization and enrichment of endpoint activity events including file operations, process events, network connections, registry changes, and authentication events.
  • Graylog Server version 6.1.2 or later with valid Enterprise license
  • TLS 1.2 server configuration enabled
  • Bitdefender GravityZone or OnPrem configured to send Syslog-formatted logs to Graylog
  • Appropriate Bitdefender license for telemetry data generation
Supported Versions
  • GravityZone Version 6.56.0-1 and matching OnPrem versions
Log Collection and Delivery
Bitdefender telemetry events are delivered to Graylog via syslog. Only Syslog-formatted logs are supported. TLS 1.2 is required for the syslog connection.
Graylog Syslog Input Configuration
Configure Graylog to receive Bitdefender telemetry:
  1. Create a Syslog input in Graylog (TCP recommended) with TLS 1.2 enabled
  2. Set 'Store full message' to true for complete message retention
  3. Configure Bitdefender to route logs with application_name 'BitdefenderEdr'
Bitdefender GravityZone Configuration
Configure Bitdefender to export telemetry:
  1. In GravityZone console, navigate to syslog integration settings.
  2. Configure the Graylog server IP address and syslog input port.
  3. Enable telemetry event export for desired event types.
  4. Verify TLS 1.2 connectivity.
Stream Configuration
  • Illuminate:Bitdefender Telemetry Messages
Index Set Configuration
  • Bitdefender Telemetry Logs
What is Provided
  • Parsing rules to extract Bitdefender telemetry events into Graylog schema compatible fields
  • Graylog Information Model message categorization for authentication, network, file, process, and registry events
  • Security Core support for endpoint telemetry categorization
  • Illuminate spotlight dashboard with five tabs: Overview, Network Activity, File Activity, Process Activity, and User Activity
GIM Categorization
GIM categorization is provided for the following event types:
Event Type gim_event_type_code gim_event_category gim_event_subcategory gim_event_type
log_on 100000 authentication authentication.logon logon
log_out 102500 authentication authentication.logoff logoff
network_connection (connect) 120200 network network.open network connection initiated
network_connection (disconnect) 120300 network network.close network connection ended
process_create 190000 process process.execute process started
terminate_process 190100 process process.stop process stopped
file_create 200000 file file.create file created
file_delete 200100 file file.delete file deleted
file_modify 201000 file file.modify file modified
file_read, file_move 209999 file file.default file event
file_access 201500 file file.access file accessed
reg_create_key 250500 registry registry.key_change registry key added
reg_delete_key 250501 registry registry.key_change registry key deleted
reg_delete_value 250002 registry registry.value_change registry value deleted
reg_modify_value 250003 registry registry.value_change registry value modified
Bitdefender Telemetry Spotlight Content Pack
This spotlight offers a dashboard with 5 tabs:
Overview
File Activity
Network Activity
Process Activity
User Activity
